Old 12-06-2014, 12:49 AM   #251
cst350
cst350's Avatar
Re: Serpentine belt conversions
Sounds good,
If you PM your PayPal info, I can give you my shipping address...
cst350 is offline   Reply With Quote
Old 12-06-2014, 07:55 AM   #252
jjzepplin
jjzepplin's Avatar
Originally Posted by tll74 View Post
Did you buy a system from me?
PM coming
I can do one less the alt and AC. 150.00 plus 50.00 shipping
Thanks, Tom
I did not buy a system from you. I got it on the forum from another member and it did not come with a water pump. The brackets are identical to the ones on my other truck and they came off a 92 Caprice. So I ordered a pump for the same car. On my truck that is running there is enough room to get the belt on and off without removing the fan pulley but not on this one. The one that works fin is a 400 and the the one that is not is a 307. Perplexing.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-07-2014, 12:45 AM   #253
tll74
"Junkyard Dog"
tll74's Avatar
Sorry, I'm not familiar with the 92 Caprice system. I do know they are different than the systems I sell though. The engine size will not make a difference. Are the pulleys the same diameter between both systems?
Thanks,Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 12-07-2014, 04:50 AM   #254
jjzepplin
jjzepplin's Avatar
Thanks,Tom
Yes pulleys are identical sizes.I know in this pic that the belt is running wrong but this is the system on the running truck. I dont have a pic of the one that is too close yet.
Old 01-02-2015, 09:22 PM   #255
NC_John
NC_John's Avatar
Have any small block kits available? no AC. Shipping would be to 28138.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-02-2015, 11:27 PM   #256
tll74
"Junkyard Dog"
tll74's Avatar
Yes, Do you need the AC delete pulley or just without a AC pump? Thanks, Tom
Old 01-03-2015, 09:08 AM   #257
NC_John
NC_John's Avatar
Sadly, (tragically come spring), I would need the delete as I do not have AC yet.......
1970 C-10 LWB "Blu"
Old 01-03-2015, 11:54 AM   #258
tll74
"Junkyard Dog"
tll74's Avatar
225.00 with the delete pulley (new). The cost on the pulley and the value on the pump are equal to me so the cost is the same. 75.00 shipping. Thanks, Tom
Old 01-03-2015, 03:54 PM   #259
jjzepplin
jjzepplin's Avatar
If you don't mind me asking- What are the part #'s for the water pump and crank pulley. I may need to purchase them from you.
Old 01-03-2015, 08:46 PM   #260
NC_John
NC_John's Avatar
OK, thanks. I just have to decide if I want all that on the front of my engine. I'd like the serpentine setup and to get PS but look under the hood of our 5.3 yukon, see all that stuff and think "ugh."
1970 C-10 LWB "Blu"
Old 01-04-2015, 12:40 AM   #261
tll74
"Junkyard Dog"
tll74's Avatar
The water pump application is 88-95 C/K with 5.7L, 5.0L, and 4.3L. The same with the pulleys. Not sure what the part numbers are. I would have the pulleys and suggest a new water pump. 25.00 plus 10.00 shipping on the pulleys.
Ok..JLMK.
Thanks, Tom
Old 01-10-2015, 03:58 AM   #262
jjzepplin
jjzepplin's Avatar
The reason for asking part #'s is that I have pulley's but they almost touch each other. I don't want to buy them and have the same problem. Everything is good on my 400ci but my 307ci is almost touching making it very difficult to install the belt as I would have to remove the pump pulley to even get it betwenn the two. PERPLEXED!
Old 01-10-2015, 04:18 AM   #263
Steve68
JJzepplin
I have all the part # from Gm but can't seem to post the picture with all the numbers.
I'm new to this forum have up loaded the picture with all the numbers in the Gallery but can't seem to post it here.
I have not installed one of these on my truck but plan to do it.
Here is the part numbers and a link
Description GM Kit # 12497698.........88 to 95 C/K trucks with SB
This deluxe serpentine belt drive system with air conditioner includes all the components to install on small-block Chevrolet engines. The bolts, nuts, spacers, and braces are included with the following major items:
10055800 - Secondary Air Injector Pump Bracket.
88894005 - Water Pump Kit
10129569 - Idler Belt Pulley Bracket
10055879 - Crankshaft pulley
10463172 - Generator Assembly (Reman.)
12117361 - Generator connector (with lead)
10055798 - Drive Belt Tensioner Assembly
10085752 - Belt (fan, water pump, A/C pump, and generator)
10105212 - Generator & Power Steering Bracket
26010328 - Power Steering Pump
14102096 - Power Steering Pulley
http://paceperformance.com/i-6255268...-with-air.html
Does not include reverse rotation fan or fan clutch, or electrical connector for A/C compressor - order connector seperately # 12101937
Note: The compressor in this kit is shipped dry. 6 Oz of PAG 150 oil need to be added when used with R134A refrigerant or 6 Oz of 525 oil added if using R12 refigerant. Total system oil capacity is generally 8 Oz so if system is dry, an additional 2 OZ of oil should be added to the accumulator, evaporator etc.
http://www.chevrolet.com/content/dam...m-12497698.pdf
Steve68 is offline   Reply With Quote
Old 01-11-2015, 01:51 PM   #264
tll74
"Junkyard Dog"
tll74's Avatar
Hey Steve, Thanks! As I do your conversion on your the new engine I'll post pics here. Hope these part numbers and info help jjzepplin out.
Thanks, Tom
Old 01-11-2015, 01:59 PM   #265
Steve68
Tom,
Ok, I can give U my email address also.
I was trying to upload pictures here but failed.
Steve
Old 01-12-2015, 06:22 AM   #266
jjzepplin
jjzepplin's Avatar
Thanks guys. I sure appreciate your help. I will go out there today and check it out. I might have to take you up on that deal.
Old 01-26-2015, 11:12 PM   #267
mnwilliams
Hello:
I'd like a SBC setup.
No AC compressor, but AC delete pulley if you can supply that.
PS pump with inverted flare fitting.
Cleaned up but not detailed.
Shipping to 30303.
Can you tell me if you still have parts, and what total and shipping would be?
Thanks, Mark
mnwilliams is offline   Reply With Quote
Old 01-27-2015, 02:01 AM   #268
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by mnwilliams View Post
Hello:
Shipping to 30303.
Thanks, Mark
Mark, I just got one it. The price stays the same as the new delete pulley cost me the same as the value of the pump. For the kit as you requested 225.00 plus 75.00 shipping. Thanks, Tom
Old 02-01-2015, 08:01 PM   #269
Skerbs1
Skerbs1's Avatar
Hello,
I am interested in a sbc kit.
What would shipping be for 53149
Skerbs1 is offline   Reply With Quote
Old 02-02-2015, 01:30 PM   #270
sb69chevy
sb69chevy's Avatar
Pm sent
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 02-03-2015, 09:25 AM   #271
Krex
pm sent
Krex is offline   Reply With Quote
Old 02-03-2015, 11:12 AM   #272
jjzepplin
jjzepplin's Avatar
What water neck are you guys using to clear the alternator?
Old 02-03-2015, 01:57 PM   #273
Lee H
Lee H's Avatar
45 degree with 360 degree swivel housing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-03-2015, 10:11 PM   #274
t-n-t fields
t-n-t fields's Avatar
Can I get a price for one for a BB without A/C
Does your key work all your lock or would you like a locking glove box or would you like a New OEM Locksets for your truck?
Locksmith building his first C10
1968 Chevrolet C10 SWB Step side
t-n-t fields is offline   Reply With Quote
Old 02-04-2015, 02:54 AM   #275
sb69chevy
sb69chevy's Avatar
Tom, payment sent, and pm sent with ship-to address.
