Old 12-13-2014, 12:30 AM   #1
crossland1962
crossland1962's Avatar
Gas Tank Relocate HELP PLEASE!!!
I have been searching the forum and looking for hours!! I have a bagged 62 I have just pulled my leaking behind the seat tank. I am looking at moving the tank to the rear but everything I am seeing hangs down below the frame pretty far. What are you guys using?? Pics please. Thinking of maybe just using a fuel cell under raised bed floor??
crossland1962 is offline   Reply With Quote
Old 12-13-2014, 02:12 AM   #2
Kenfuzed
Kenfuzed's Avatar
Re: Gas Tank Relocate HELP PLEASE!!!
I thought that despite hanging below the frame many of the frame mount tanks are still high enough not to drag.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-13-2014, 02:21 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think some have had good results with a 69 or 70 mustang tank.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-13-2014, 02:33 AM   #4
LostMy65
LostMy65's Avatar
Here's a thread you might look at:
http://67-72chevytrucks.com/vboard/s...12#post6737212
Old 12-13-2014, 08:30 AM   #5
Mr Bear
Consider this. Measurements.
On my 65, the lower sidewall of the spare tire is 13" down from the bed cross sill. The bolts/bracket add another few inches.
A 21 gallon side fill tank (LMC Trucks) is typically 13" from bottom to top.
So, if you cut out the spare tire cross bar and tuck it up in between the frame rails (whether or not you cut out a notch in the associated bed sill) such a tank should hang no lower than your existing spare tire/bracket assembly.
If your spare ain't dragging, your tank shouldn't either. But if you are one of the folks that are crazy low, all bets are off and you might need a skid plate anyway.
Naturally, the smaller capacity bed fill tanks will tuck up in between the frame rails even neater.
I think most folks simply object to the potential for dragging as the visual from the rear (especially with no bumber) is a bit scary.
I'll let ya know how a 21 gallon goes in. I'll be putting one in place on my truck in the next few weeks. I am tired of fumes in the cab too and it'll be nice to have the safety margin and the extra space behind the seat.
Mr Bear is offline   Reply With Quote
Old 12-13-2014, 11:50 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.tanksinc.com/index.cfm/pa...rod/prd173.htm This one is only 8 1/2". Down side is, it is only 16 gal
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-13-2014, 04:58 PM   #7
57chevy406
I used a 69 Camaro tank with the Camaro big block fuel sending unit and the Camaro spring loaded tag bracket in my 61 short bed fleet side. Nothing visabile from the back and the filler is centered behind the tag so it doesn't matter which side of the pump you pull up to. I saw the idea on this forum and it had pictures. I cannot figure how to post pictures of mine.
57chevy406 is offline   Reply With Quote
Old 12-13-2014, 05:07 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Here are some threads that should help:
http://67-72chevytrucks.com/vboard/s...light=gas+tank
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-13-2014, 09:25 PM   #9
AcampoDave
AcampoDave's Avatar
Here's one I started where many members were kind enough to post pics http://67-72chevytrucks.com/vboard/s...d.php?t=621177
AcampoDave is offline   Reply With Quote
Old 12-14-2014, 05:33 PM   #10
Jimal
Jimal's Avatar
I'd like to see your install. I'm on the verge of taking my LMC sourced tank and relocating the filler to come out the back using a neck from a '61-'63 full size Chevy. I've seen a couple '69 Camaro tank installs on here but I wasn't happy with the look.
Jimal is offline   Reply With Quote
Old 12-14-2014, 06:14 PM   #11
crossland1962
I am looking on the really cheap!! What has anybody bought at the junkyard and used??
Old 12-14-2014, 11:56 PM   #12
verdell
verdell's Avatar
I'm running a 22 gallon 70s chevy van gas tank. I didn't like how low the blazer tanks hung and ran across this after doing a little research. Fits pretty good into the 60-62 frame rails and doesn't hang too low even with my rear bags aired out. Check out gastanks.com p/n GM-8A or the salvage yards..hope this helps
verdell is offline   Reply With Quote
Old 12-15-2014, 12:05 PM   #13
crossland1962
Thanks for all the input guys. Verdell I am going to see what I can come up with.
Old 12-16-2014, 02:27 AM   #14
slepysal
slepysal's Avatar
Any pictures of your tank ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-16-2014, 11:08 AM   #15
McCoyAZ
McCoyAZ's Avatar
'53 chevy sedan tank will work also
McCoyAZ is offline   Reply With Quote
Old 12-16-2014, 11:17 AM   #16
verdell
verdell's Avatar
Smile Re: Gas Tank Relocate HELP PLEASE!!!
Sal,
I'll post a couple as soon as I can. Between work and being a soccer dad, I haven't had a lot of play time lately...
Old 12-16-2014, 11:23 AM   #17
crossland1962
Verdell did you use the van sending unit?
Old 12-16-2014, 12:08 PM   #18
verdell
verdell's Avatar
Yes, I used the van's sending unit with a set of aftermarket "Dolphin" gauges.
Old 12-16-2014, 12:14 PM   #19
crossland1962
Thanks man I really appreciate the help!!!!!!!!
Old 12-16-2014, 03:18 PM   #20
57chevy406
Some pictures of my 69 Camaro tank on my work truck. Probably not what someone would want on a show truck but it was easy and inexpensive. Plenty of clearance but my truck is only lowered 2 inches.
Old 12-16-2014, 05:19 PM   #21
Jimal
Jimal's Avatar
That is actually pretty sharp. What year is your truck?
Old 12-16-2014, 05:25 PM   #22
slepysal
slepysal's Avatar
Sal,
I hear you.... no rush and thanks
Old 12-17-2014, 01:49 PM   #23
Chevystep
THERE!!!! That's the install I've been looking for, with a filler hole that don't mess with the bed! How tough was the fitting on that jewel, and what sending unit worked with it....??? Heck, Classicparts has a steel Camaro tank for $85...
http://www.classicparts.com/1969-Gas.../#.VJHAtCvF98E
Chevystep is offline   Reply With Quote
Old 12-17-2014, 02:34 PM   #24
par4tom
While not a lower cost option, the folks at Performance On Line have a tank specific for the 60-62 trucks. I was going to go the lower cost option but wanted to make sure I got something that was really safe....
Good luck on this and Merry Christmas!!!
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 12-17-2014, 02:51 PM   #25
Lokin4AReason
Lokin4AReason's Avatar
informative thread and liking the idea(s) being thrown around .... =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
