fuel sending unit
recently bought a unit from Bobs on ebay it only worked for a week was wondering what others have used with success its for a 69 c10 thanks
Re: fuel sending unit
I replaced mine last year. I got the replacement from Summit and it has worked
good. If you check them out, be careful that you get the right one. The first one I ordered looked right. When I went to install it, I found it different and would not work. I went back and found the right one. They were great on the return. EdB |
trucks72
Check the float. They are known to go bad and fill up with gas. If it is reading empty. That probably is the problem.
