![]() Join Date: Apr 2013
Rear Axle Questions
I am working in refurbishing my '72 K10 and I am in need of some help with identifying my rear axle. The only numbers I can find are the ones pictured. It looks like it is obviously not the original axles since spring perches have been moved. Also wondering if the u bolt setup is right. I just ordered a skyjacker 2.5" soft ride. If not what would I need to correct and will I have any other issues with staying with this axle setup.
Thanks Nathan
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Re: Rear Axle Questions
Pretty standard Chevy 12 bolt.
![]() Join Date: Mar 2003
Minnesota sure takes its toll on steel doesn't it
Depends on where you are in Minnesota. But yes we have rust.
Yeah its a 12 bolt if you ever need help iding a axle http://coloradok5.com/axleguide.shtml
I know it is a GM 12 bolt looking for answers on specifics. As stated above. By looking through threads the axle seems to be modify correctly.
Thanks Nathan
Look on top of the passenger side axle tube for a stamping code.
