Old 01-26-2015, 02:46 AM   #351
LSX408
Re: Restoring Rusty
Nice progress! Love the updates with pics.
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 01-26-2015, 05:36 PM   #352
rusty76
rusty76's Avatar
Re: Restoring Rusty
Making progress!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-26-2015, 06:56 PM   #353
green72s
green72s's Avatar
Re: Restoring Rusty
Thanks for all your efforts to document this process so well, with descriptions, humor, and photos. This will be handy for my son and I one day.
green72s is offline   Reply With Quote
Old 01-26-2015, 08:46 PM   #354
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
X2. I enjoy following this thread.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-27-2015, 12:37 AM   #355
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank you, figure I'm taking pics anyway so I document how the bits go back on, might as well share em, maybe help somebody out, I'm no expert, learning as I go
Gregski is online now   Reply With Quote
Old 01-27-2015, 12:38 AM   #356
Gregski
Gregski's Avatar
Re: Restoring Rusty
you're welcome, hope to see your and your son's build pics real soon!
Old 01-27-2015, 12:40 AM   #357
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank your, your feedback motivates me to keep going
Old 01-27-2015, 12:55 AM   #358
Gregski
Gregski's Avatar
Re: Restoring Rusty
well my day started out with cleaning and spinning my wheels
first I removed the hard fuel line to get better access to things
Old 01-27-2015, 12:59 AM   #359
Gregski
Gregski's Avatar
Re: Restoring Rusty
then I took some more pics of the old OEM intake manifold realizing I done never flipped it on it's back to take a pic of it's there belly
now if you look close you might could just see how the EGR port is all carbon dipossited shut right there in the middle of it, completely shut to the point of ineffectiveness
Old 01-27-2015, 01:05 AM   #360
Gregski
Gregski's Avatar
Re: Restoring Rusty
so here are some before and after pics of the cleaned lifter valley (wish they turned out better - my garage faces West and the sun shines right on my back and cast shadows over the engine bay, poor me a river! right)
Old 01-27-2015, 01:09 AM   #361
Gregski
Gregski's Avatar
Re: Restoring Rusty
again nothing to write home about but for now it will do (the plan is to come into some aluminuminum heads come fall - complements of the Curse Jar, hee hee)
Old 01-27-2015, 01:15 AM   #362
Gregski
Gregski's Avatar
Re: Restoring Rusty
figure one more point of view of this gutter since it's not like we can admire it none once it's all sealed up
Old 01-27-2015, 01:18 AM   #363
Gregski
Gregski's Avatar
Re: Restoring Rusty
ok this is what we are working for, out with the old and in with the new
(the old manifold being the one on the left, LOL)
Old 01-27-2015, 01:21 AM   #364
68post
Re: Restoring Rusty
You did an excellent job of crud removal !! That wasn't easy I know. Kudos
68post is offline   Reply With Quote
Old 01-27-2015, 01:31 AM   #365
Gregski
Gregski's Avatar
Re: Restoring Rusty - Intake Manifold
I want to point out something to you that I learned
the new aluminum intake manifold is thinner than the old one, at the pint where the bolts go one is 1/16 of an inch thicker if not a bit more
also I am not planning on putting on the bracket back on so I noticed that those bolts were an inch and a quarter and the other ones were inch and an eighth
also some of the bolts don't screw all the way in
the two that surprised me were the bolt above the #4 exhaust port (third bolt in the passenger side head) it interferes with the exhaust push rod
and the bolt above the #5 intake port (fourth bolt in the driver side head) it inteferes with the intake push rod
Old 01-27-2015, 01:33 AM   #366
Gregski
Gregski's Avatar
Re: Restoring Rusty
now maybe with the gasket and a prayer these components would never meet, but that was a chance I was not willing to take, so I picked up some shorter 3/8th grade 5 bolts, only one inch long and some washers to remedy this situation, I used these in these two places plus on all the outer corners as those bolts bottom out (blind I guess it is called)
Old 01-27-2015, 01:35 AM   #367
68post
Re: Restoring Rusty
Excellent info , and something to watch for doing swaps !
Old 01-27-2015, 01:39 AM   #368
Gregski
Gregski's Avatar
Re: Restoring Rusty
so first a dry fit, just to see if the holes align and what the gaps are like
Old 01-27-2015, 01:46 AM   #369
Gregski
Gregski's Avatar
Re: Restoring Rusty
at this point it was getting late, I was cold and hungry, but there was no way I was going to stop here
so we will be using another FelPro gasket (but not all the pieces just the blue sides, per Weiands instructions we are NOT to use the middle pieces)
I could not find any gasket adhesive maybe I was looking for the wrong stuff, I imagined it would be in an aerosole spray can, anyway I needed some stick-to-it-avness so I just gently coated the heads with RTV silicone
then I ran a 1/4 inch beed of RTV down the middle as per the instructions
I used carb cleaner to clean all the grease off of all the maiting surfaces (AutoZone was all sold out of Brake cleaner, can you believe that that's like an Irish bar running out of booze)
Old 01-27-2015, 01:50 AM   #370
Gregski
Gregski's Avatar
Re: Restoring Rusty - New Intake Manifold
torqued all 12 bolts in the super special sequence using a torque wrench first to 10 ft lfbs then to 15 and finally to 25 ft lbs
only one bolt gave me trouble to torque to spec that pesky third bolt from the front on the passenger side, the intake stack is perfectly in the way on that side, it seems to be set more to that side than the driver's side, oh well I eye balled it in the end
and the money shot
Old 01-27-2015, 01:56 AM   #371
Gregski
Gregski's Avatar
Re: Restoring Rusty
at this point I hit a Mechanics High, I had to keep going I had to see the carb on there tonight...
so first the studs went in...
then the split down the middle carb base gasket...
then the crown jewel... the Holley Carburetor
Old 01-27-2015, 01:58 AM   #372
Gregski
Gregski's Avatar
Re: Restoring Rusty
still far from being done with this phase, got to put the dizzy back, connect the vacuum hoses, thermostat, coolant hoses, throttle linkage, even a bit of electrical to do ~ but it's so rewarding at this point!
Old 01-27-2015, 02:09 AM   #373
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank you, found myself climbing into the engine bay and squatting under the hood, being 6' tall has its perks but this wasn't one of them
I literally chisled the cross/bypass ports in the cylinder heads (what I call the EGR ports) open, they were completely welded shut with carbon deposits, or what I can only imagine is carbon
Old 01-27-2015, 02:12 AM   #374
Gregski
Gregski's Avatar
Re: Restoring Rusty
Yeah you won't get that on Car Fix as they do an LS swap in 30 minutes, with no problems or issues, everything just bolts right up!
Old 01-27-2015, 04:41 AM   #375
y5mgisi
y5mgisi's Avatar
Re: Restoring Rusty
Awesome! While I am partial to the old quadrajets for daily driver rides, that carb does look quite at home up there.
