![]() Join Date: Jun 2007
Original NAPCO hubs or No? Guru input needed
So my 57 Chevy NAPCO truck has these WARN brand 4" front hubs on it - another board member says he has 2 NAPCO 4x4's and a set of normal 6 lug 1/2 ton truck wheels will fit on either of his trucks, but mine has 4" hubs that will not fit through the center of a normal 6 lug wheel because the opening is like 3 3/4" or something instead of 4". So now I am wondering if these WARN brand hubs are not correct original NAPCO equipment at all, and instead have been changed over the years - if so, I want someone among you who knows his stuff to point this out, and tell me what its supposed to have, and if possible, where to get the correct ones, because at this moment, this problem is preventing me from being able to mount the correct wheels and hubcaps.
Is there a NAPCO guru on this board who can say one way or another?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
Re: Original NAPCO hubs or No? Guru input needed
http://www.napco4x4.org/ should have some info.
#3 | |
These pictures show a slightly different hub:
http://www.napco4x4.org/gallery/napc...oded-view.html Also this auction: http://www.ebay.com/itm/1955-1956-Na...p2047675.l2557 This page also claims to show regular hubs: http://horn-relay.dvautoparts.com/di...w-miipmkoiplmj |
This might help too.
http://67-72chevytrucks.com/vboard/s...highlight=hubs
you guys are the best - thank you. I did finally find a NAPCO guru who explained that what I have are correct 56-57 WARN M18 hubs and that from the factory they only had driving flanges that still fit under stock hubcaps even - any locking hubs are an extension to the driving flange as a bolt-on accessory. So according to this guy, I do not need to be looking for special wheels because all 55-59 wheels fit over these M18's (despite the 63-66 rims I already tried not fitting) so once I have a chance to try this out, I should be A-OK and good to go - thanks a bunch guys!
