Ok have a horn problem change everything but it continues to go off changed the horn sensor changed the horn assembly changed the wires but when i plug the horns in it keep just sounding
![]() Join Date: Dec 2012
Re: Dang horn
Horn Relay?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: Dang horn
the silver square thing with 3 prong about two inches from fuse panel it was buzzing something fierce when i turned on my lights and when it not plugged in no horn sound at all???
Re: Dang horn
i said horn sensor before meant to say relay whoops
Re: Dang horn
Ah. I thought you meant button. If the wire from the column isn't connected on the relay, does the horn still sound? I think it's a small brown wire on the relay. There is a big red as well as a dark green that goes to the horns. the third wire.....brown?
Re: Dang horn
nope it black was brown till i cleaned it off lol
Re: Dang horn
no longer beeps with the black (brown) wire connected?
Re: Dang horn
A short in the steering column
Re: Dang horn
that would be my guess...
![]() Join Date: Nov 2013
Re: Dang horn
Most likey........the wire in the column that goes up to the horn button simply grounds the horn relay in order to energize it and blow the horn. Check to see if it's shorted to ground when you wiggle around on the steering column harness.
Re: Dang horn
sorry got called into work couldn't finish it up. so ran a couple of leads to the the switch to bypass the black wire. i ( no no random horn sound) already changed out the harness that comes down the steering column. because i had no tail tight flashers (switched to led) and thanks who ever said ground the one that wasn't working. any way now when i check my switch with my light i have no power. at the horn button.
