Old 04-20-2015, 01:08 PM   #1651
61K10
61K10's Avatar
Re: 1963 C-10 in NC
Color match looks good as everybody has said. When i bought my paint (2gal) i was going to put both in a 5gal bucket and mix it together, just to make sure both gals would be the same. Never did it lol--but it's the only way to make sure it's the same. my outdoor booth worked ok like yours too! Looking better every post.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-20-2015, 01:09 PM   #1652
mattbert56
mattbert56's Avatar
Re: 1963 C-10 in NC
That's smart when I paint my hood I will try that
mattbert56 is offline   Reply With Quote
Old 04-20-2015, 01:15 PM   #1653
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Yes....thankfully I was able to locate where the paint shop moved and changed names under the new owner. Color match looks spot on. Just hood and bed left now. Its also important to use the same color primer and I use the same number of base coats each time.
I have seen trucks painted inside that don't hold a finish to my outdoor paint project. People always seem so shocked to see it was painted outside. Hell, the whole trucks been built under the carport. Fleetside will be done in the barn though.
But, I think the finish speaks for itself....
1964 Short bed trailer
Old 04-20-2015, 05:24 PM   #1654
Re: 1963 C-10 in NC
The respray came out great. As TJ said, almost 1 color!
Old 04-20-2015, 06:35 PM   #1655
Eric15chevys
Eric15chevys's Avatar
Re: 1963 C-10 in NC
Looks much better. I got a lot done this weekend. New front control arms and hung the engine.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 04-20-2015, 07:14 PM   #1656
dwcardfan
dwcardfan's Avatar
Re: 1963 C-10 in NC
Glad you had a productive weekend.
dwcardfan is offline   Reply With Quote
Old 04-20-2015, 07:15 PM   #1657
dwcardfan
dwcardfan's Avatar
Re: 1963 C-10 in NC
The paint looks good. You are knocking it out of the park.
Old 04-20-2015, 07:17 PM   #1658
northern 85
northern 85's Avatar
Re: 1963 C-10 in NC
Looking great!
northern 85 is offline   Reply With Quote
Old 04-21-2015, 06:54 AM   #1659
Nacho_Paras N.L.
Re: 1963 C-10 in NC
Originally Posted by 1963c-10 View Post
Rcvd a couple PM's about the headers I used. Hedman HTC #69136 2" primaries. I used them with POL tubular mounts. Will require frame trimming for both mounts and headers.
http://www.hedman.com/site/?d=118&dt...keID=&ModelID=
Do the headers you went with hang below the frame?
Nacho_Paras N.L. is offline   Reply With Quote
Old 04-21-2015, 08:07 AM   #1660
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks.....much better match than what we had before!!
Old 04-21-2015, 08:08 AM   #1661
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks Eric. I hate going backwards on a project, but I was the right way to fix the issue.
Yeah, been keeping up on your thread. Looking good. Glad to see the boys turning some wrenches with you!!
Old 04-21-2015, 08:09 AM   #1662
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Yeah me too, was about due for one. Takes a lot to get where it is and progress seems slow at times, but I just keep on keeping on!!
Old 04-21-2015, 08:10 AM   #1663
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by northern 85 View Post
Looking great!
Thank you sir!!
Old 04-21-2015, 08:15 AM   #1664
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Just barely....I had to go look through my pics to see if I had any good shots of them on the frame. I'll have to get some better pics tonight to show their orientation for you. This one shows them, but not real good.
Old 04-21-2015, 08:19 AM   #1665
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Not much progress last night. Was a late night off from work. Did get the vintage bug screen in. Its not an OEM GM part, but it is a vintage early 60's aftermarket and American made.
Old 04-21-2015, 08:21 AM   #1666
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Also got the passenger side cast iron mirror arm and head ready to install. Door is marked, just need to drill and mount.
Went ahead and showed the markings cast in the bottom for the die hard gurus. These numbers don't mean much to me, but I know a lot of the purist keep up with stuff like that and since the passenger side arms rarely come up figured I'd document it.
Old 04-21-2015, 08:24 AM   #1667
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
And finally the tank cover that I've spent two days trying to fold right. And a week with boxes on top to get flat as it came rolled up. Does clean it up quite a bit.
If I had to do it again I would source a siding brake to make the top line straight. I'm not unhappy with it, but did sustain a 1" tear at the top center where the fuel sending unit wire comes through. Best I could get it to look and it'll stay. Have considered getting some speaker carpet and covering it......50/50.
I looked at all the factory pics in the thread on these and they show the tabs on the back of the cab facing down. I took mine and ran them up the cab. I just think it looks better. This one didn't come out bad, but a straighter fold would have eliminated the wavy line.
Old 04-21-2015, 08:27 AM   #1668
pimpston65
pimpston65's Avatar
Re: 1963 C-10 in NC
wheres your reproduced build sheet for the back of the seat?
pimpston65 is offline   Reply With Quote
Old 04-21-2015, 08:30 AM   #1669
Nacho_Paras N.L.
Re: 1963 C-10 in NC
Kool... The headers I currently have come out the frame big time. I'm talking about a full 3.5"!! This is going to be a problem for me when I go that extra inch lower, so I'm trying to plan ahead and purchase some new headers.
Old 04-21-2015, 08:36 AM   #1670
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Haha....I have to quit adding factory options before I can print it. I do have a list assembled of the options and factory codes and do eventually plan to do one though.
Old 04-21-2015, 08:37 AM   #1671
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Yeah, mine aren't that bad. Haven't taken a measurement of how far they hang. But I can get some pics and numbers for you tonight.
Old 04-21-2015, 10:15 AM   #1672
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Looks nice...Ya know, I remember when this build thread only had 13 pages....what happened?
Old 04-21-2015, 10:19 AM   #1673
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
haha....yeah, me too. Its turned into a trilogy.
Old 04-22-2015, 10:57 AM   #1674
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Your comment had me looking back through my own thread TJ. 1st pic is June 2009, just brought her home, new tires and got her running.
Next two pics are April 2009.... a year from today when I started the resto....and last two are from where it sits today.
Old 04-22-2015, 11:03 AM   #1675
pimpston65
pimpston65's Avatar
Re: 1963 C-10 in NC
hell when i started my resto, i sandblaster the numbers 98' in the inside of the cowl extension... so now 17years later and my body is still incomplete!!! and now i have 2 builds cooking, how time flies!!!
