04-20-2015, 06:58 PM | #1 |
how to weld on leaf spring perches
I really want to flip my axle on my 86 when I get home.
I'm looking at a set of perches however I see many different kinds. Where is a link to one's with three pin holes drilled in them for proper placement of the axle within the wheel well? I have access to a welder but the above question stumps me? Is resetting pinion angle necessary? Posted via Mobile Device |
04-20-2015, 07:16 PM | #2 |
Re: how to weld on leaf spring perches
You will have to set the pinion angle. Its not hard though. Buy an angle finder from the hardware store. Use the same angle that you had before. Make sure you measure it with the weight of the bed on there though.
You can buy a flip kit for around $75 which will include the shock extenders and you don't have to worry about the pinion angle. That might be easier way to go.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-20-2015, 08:31 PM | #3 |
More importantly. What kind of welder and what is the amperage? How much welding experience do you have. The perches take a lot of stress and I have seen improperly welded perches break off letting the axle spin causing all sorts of fun things to happen.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-21-2015, 01:03 PM | #4 |
Welding on the tubes can also bend the housing from the heat. A flip kit solves this issue also.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-22-2015, 08:19 AM | #5 |
Flip kit. As mentioned above, takes all of the questions out of the job. I used a DJM on my truck and it is a pretty neat setup that allows for adjustable pinion anagle so you can set it correctly once you know the ride height.
04-24-2015, 09:04 PM | #6 |
04-24-2015, 09:05 PM | #7 |
Hey guys thanks for the advice. I've decided not to to with the axle perches. However can anyone recommend me a kit that is decent hit on the wallet and relative easy installation? Pics would be awesome
04-25-2015, 08:30 PM | #8 |
I went with the DJM kit and would do that again. Summit Racing was my source and it was in the $120 range if memory serves.
