Old 05-05-2015, 09:17 PM   #201
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: 1960 chevy parkwood wagon!
Wagon is sweet Taylor. Great job on everything.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 05-10-2015, 10:39 AM   #202
chevyrestoguy
chevyrestoguy's Avatar
What was the deal with your transmission issue? Hopefully, you got through it without killing your wallet.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-02-2015, 10:17 PM   #203
68basket
Thanks for all the kind comments.
I Took the wagon on the Hot rod power tour and did the long haul!! I put 3000 miles on the car in one week! Ran into a great board member crawdadfox and his wife, It was awesome to run into you guys in baton rouge. No major issues during the trip other than a cracked wheel and another bent one.
A little feedback on the unisteer rack kit is don't buy one. It leaks like crazy and seems to be pretty twitchy at higher speeds. I am now getting parts together to put a gearbox back on the car.
68basket is offline   Reply With Quote
Old 07-02-2015, 10:18 PM   #204
68basket
Took all 3 kids to a local cruise in last sunday. Fun stuff.
Old 07-02-2015, 10:38 PM   #205
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I did the tour from Memphis the rest of the way. Saw your car but didn't make the connection. Next time we need to meet up.
Zoomin is offline   Reply With Quote
Old 07-03-2015, 09:46 AM   #206
68basket
We for sure should meet up when we do the tour again. Its very hard to pick out all the different cars and trucks in all the thousands on the tour.
Old 07-07-2015, 09:57 PM   #207
Pro Performance
Pro Performance's Avatar
Wagon looks awesome man!
Pro Performance is offline   Reply With Quote
Old 10-27-2015, 09:15 PM   #208
68basket
Thanks!! ALso thanks for getting that ac compressor and bracket coming.
New things happening to the wagon. I bought a 1999 z28 as a doner car. I pulled the engine and trans last weekend and have just ordered a cam and 3200 stall convertor and all associated parts. Still need to get more stuff coming. Cant wait, i should have gone ls from the beginning.
Old 10-27-2015, 09:34 PM   #209
Advanced Design
Advanced Design's Avatar
Cool direction for your wagon. A friend just went the same route for his 65 Pontiac wagon by buying a decent Firebird for the goodies.
Advanced Design is offline   Reply With Quote
Old 12-06-2015, 01:54 PM   #210
68basket
Got the engine and trans out of the camaro. Pulled down to a short block, all new gaskets, TSP 228r cam and all new lifters, pushrods, springs, seals and gaskets etc. Cut off the coil mounts and smoothed valve covers. Painted up everything.
Old 12-06-2015, 01:55 PM   #211
68basket
Took the engine and trans home from work where i did the work to it. Pulled the old 283 and test fit the ls1. Little bit of work to make it fit.
Old 12-06-2015, 01:57 PM   #212
68basket
My son loves to help. This was the test fit and what i had to do to make it fit in there.
Old 12-06-2015, 01:59 PM   #213
68basket
Took the steering rack out and went with all new stuff from CPP a new 500 gearbox that looks like it just barely clears the radiator and all new steering links etc.
Old 12-06-2015, 09:19 PM   #214
Zane M
Just found this project post.
Love everything about the car! Congrats on a sweet ride!
Zane M is offline   Reply With Quote
Old 12-08-2015, 09:33 PM   #215
68basket
Thanks Zane!
Old 12-09-2015, 03:08 AM   #216
tommys72
tommys72's Avatar
Coming along nicely
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 12-11-2015, 01:57 PM   #217
KevsClassics
TILT COLUMN GURU
I'm really digging the LS swap!!
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 12-11-2015, 02:18 PM   #218
68basket
Originally Posted by tommys72 View Post
Coming along nicely
Thanks Guys!
Old 12-11-2015, 02:23 PM   #219
68basket
Little update, Ran the BP automotive harness through the firewall. Set the engine in for the last time and put on all the accessories. Mounted the coils on the from next to the trans and custom made my own MSD plug wires for it. Keeping everything tidy is the goal.
Old 12-11-2015, 06:01 PM   #220
Advanced Design
Nice and clean installation! Where did the accessory drive come from?
Old 12-11-2015, 06:06 PM   #221
68basket
Thanks for the kind words.
The ac bracket is a kwik performance from vintage air and the ps/alternator bracket is from lsbrackets.com
Old 12-12-2015, 07:56 AM   #222
see ten
WTB this ad
see ten's Avatar
Great looking wagon!
Would a different oil pan been an option as opposed to modifying the crossmember? Asking because this swap is in the future of my 59.
see ten is offline   Reply With Quote
Old 12-12-2015, 09:27 AM   #223
bondo510
I love your wagon! Great job. What was the primer you used on the original engine?
bondo510 is offline   Reply With Quote
Old 12-13-2015, 10:43 PM   #224
68basket
From what i have found out you can use some spacers under the engine stands to raise it up enough to clear, but its possible there could be driveline angle issues. I decided to go this route so i can have full adjustability to make my angles correct. Its really pretty easy to slice out the middle of the frame and re weld it.
Old 12-13-2015, 10:44 PM   #225
68basket
Thanks! That was just some high temp engine primer. nothing special
accuair, bagged, elevel, parkwood, wagon
