Old 05-07-2015, 07:08 PM   #1
thejangler2013
Question what differential is this?
newbie here looking to order some parts for this differential on my 1969 c20. can anyone tell me any details about this?
what is this tension screw with the arrow and how do i adjust it?
oh and heres a pic of my project THANKS!!
can u guys see my pics here?
thejangler2013 is offline   Reply With Quote
Old 05-07-2015, 07:13 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: what differential is this?
Welcome to the board! That is an Eaton HO52. I believe that is called a load bolt, or a pinion preload bolt. Can't tell you what to do with it, hopefully someone else will chime in. In 38 years I've never needed to mess with mine.
Eatons are tough as nails but some parts can be hard to come by. Try your local NAPA or other parts store if you need anything for it.
Edit: If you need to do brakes, check this link: http://67-72chevytrucks.com/vboard/s...d.php?t=660022
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-07-2015, 07:13 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Looks like an Eaton HO52 to me. Parts can be hard to find for them depending on what you need.....
LockDoc
Leon
Old 05-07-2015, 07:34 PM   #4
thejangler2013
thanks so much for the info!
Old 05-07-2015, 08:02 PM   #5
thejangler2013
Question Re: what differential is this?
anyone care to comment as to how you adjust that spring tension screw with the arrow?
Old 05-07-2015, 08:24 PM   #6
kwmech
There is really no "maintenance adjustments" to be made. The bolt rubs on the inside edge of the ring gear to prevent deflection imposed from the pinion under heavy load
Old 05-07-2015, 08:44 PM   #7
bronze 72 super
bronze 72 super's Avatar
Too bad you don't live close to me here in Oregon, I'll give you two of these for spares!! Yes hard to get parts and all of them low geared. DANA 60's much better. Yes they can be swapped over, with minimal problems.
bronze 72 super is offline   Reply With Quote
Old 05-08-2015, 12:33 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Lil more reading & info for you with part numbers & pics: http://ramchargercentral.com/axle-te...on-ho5272%27s/
- Mike -
RIP El Jay
Old 05-08-2015, 02:24 AM   #9
swamp rat
swamp rat's Avatar
If the loc nut has been loosened my thoughts would be to screw the bolt in until it just lightly touched the ring gear, then tighten the loc nut. I have yet to find a spec on it, mine has never been loosened.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-09-2015, 12:35 AM   #10
El Dorado Jim
Like others have said, it is an Eaton, hard to find parts for and expensive, change it out to a corporate 14 bolt,they are excellent and can be found in any wrecking yard,
El Dorado Jim is offline   Reply With Quote
c20, differential, rear end
