Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-02-2015, 10:47 PM   #526
IronCanine
I'm trying....
IronCanine's Avatar
Re: 70 Blazer Frame Off
Originally Posted by DeadheadNM View Post
Almost done man!
I know...but I gotta make that odometer move. I'm tired of staring at 5/10ths of a mile.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 06-02-2015, 10:49 PM   #527
scf100
scf100's Avatar
Folks you gotta see this thing in person......wow!
The attention to detail is over the top.....
Brad is one happy and lucky guy I can tell you.....
Can't wait to see the big smile on his face when he starts rolling down the road....
Stuart
PS any car guy would gladly jump under this thing to help out.....looks as good on the bottom as the top!
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 06-02-2015, 10:56 PM   #528
IronCanine
I'm trying....
IronCanine's Avatar
Stuart
Thanks Stuart for the help and the kind words.
Old 06-02-2015, 11:03 PM   #529
Blown06
Blown06's Avatar
Every time I check in on your thread I have to go back and just drool on how clean the work is. You're doing an amazing job can't wait to see a rolling shot.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 06-02-2015, 11:10 PM   #530
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Jarrod. I can't wait either.
Old 06-03-2015, 12:41 AM   #531
Jurassic-1
Jurassic-1's Avatar
Some day I would love to do this to my 72 CST. Nice work. Love the attention to detail.
Jurassic-1 is offline   Reply With Quote
Old 06-03-2015, 09:35 AM   #532
IronCanine
I'm trying....
IronCanine's Avatar
Thanks.
Old 06-03-2015, 09:18 PM   #533
tristan
You are giving me a serious case of undercarriage envy. I can already feel my checking account deflating.
tristan is offline   Reply With Quote
Old 06-03-2015, 09:30 PM   #534
IronCanine
I'm trying....
IronCanine's Avatar
Well...I guess we're even then, because I'm super jealous of your flawless sheet metal.
Old 06-05-2015, 10:11 PM   #535
IronCanine
I'm trying....
IronCanine's Avatar
Since I always take The Facts of Life approach with this thread and post the Good with the Bad...I thought you'd get a kick out of this pic. We were topping off the transmission...literally minutes from putting her in gear for the first time and pulling her out under her own power when we sprang a leak in that brand new radiator core, that had taken two attempts to get rebuilt right. After staring in disbelief for a while and doing the math, considering the mess we were going to have to manage...we bit the bullet and pulled her out. Amazingly, they were able to get it neatly repaired today and the radiator was getting re-prepped and re-painted by 4pm. This is after a late call last night when the brake situation finally got solved. We went through about 5 unions, hand to bend and flare a new hard line (the main long one on the frame), and bought a new rear flex line before we got her dry and bled. In the end I am happy the frame got powder coated. It weathered that unnecessarily arduous and frustrating episode unscathed.
Even though the old girl doesn't seem to want this party to end...there is a silver lining. We needed to clean and detail the engine bay anyway, she'd gotten a little dusty of late...and I had ordered a replacement crank pulley set earlier in the week. I realized a while ago that the set I had powdered coated was from a later model and didn't allow us to run the A/C off the crank and water pump....only the water pump, which wasn't going to be a good long term solution. I just wasn't looking forward to biting that bullet either. Well there's no better time than now to make that swap too.
Maybe she drives tomorrow...maybe not. I'll keep you posted.
Old 06-05-2015, 11:11 PM   #536
scf100
scf100's Avatar
Brad what did you guys find wrong with bleeding the brakes?
1970 2WD Blazer 454
Old 06-05-2015, 11:30 PM   #537
IronCanine
I'm trying....
IronCanine's Avatar
Well...we just had leaks we couldn't beat. As you know the long line leaked at both ends and the flex line leaked at the back. All of my stuff came from InLine. We'd tighten leaking joints, bleed, check, leak still there, change union, bleed, check, leak still there, re-flare line, bleed, check, leak still there, change union, bleed, check, leak still there, bend new line, replace flex line, replace all unions, bleed, check, no leaks, light on, bleed, bleed, bleed...no air, no leaks, no light.
We were power bleeding it on Thursday...probably still be there if we hadn't. I don't know why those joints leaked. We basically just threw new parts at it until it stopped. Only one of the flares on the original long line looked remotely suspicious....so I'm at a loss, other than it just wanted to be a pita. And then it was just tough getting all the air out. There was not a small amount of frustration there...if for no other reason than I was freaking out (silently of course) about maintaining our finishes...no scratches, or brake fluid blemishes.
But luckily we got it done, it all works as it should and she's still shiny and nice.
Old 06-05-2015, 11:51 PM   #538
TBONE1964
Cluster King
TBONE1964's Avatar
You have the 3 main ingredients of doing a build like this Brad.
Patients, Attitude and Understanding.
A great attitude will allow the patients you need to be understanding that sometimes things will not go as planed. You are taking everything in great stride. If the dog could talk, we might hear a different tone
It will all pay off and yes it is nice that the brake fluid did not attack anything.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-06-2015, 01:13 PM   #539
IronCanine
I'm trying....
IronCanine's Avatar
Old 06-06-2015, 01:37 PM   #540
IronCanine
I'm trying....
IronCanine's Avatar
Today is a good day.
Old 06-06-2015, 01:42 PM   #541
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by IronCanine View Post
Today is a good day. I want to hug everyone. I think I'll call my mother in law.
Very cool
Old 06-06-2015, 02:39 PM   #542
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Success!!!! Big congrats!! An inspiring build - thanks for the ride! Beautiful! Absolutely among the handful of the very best K5's in the USA and Canada. Rushing to have a beer in your honor. Can we start sending other rigs for you guys to restore ?
Old 06-06-2015, 04:24 PM   #543
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by TBONE1964 View Post
Very cool
It does feel cool.
Thanks Pete. I've just been trying to emulate you and others. It would not have turned out so well without all the generosity of knowledge and spirit that you and others on here are so quick to show....but we're not done. Even though today was a big step, I've still got to get the anti-rattle set in on the doors, we did a rough alignment which needs to be dialed in, and there's the whole matter of the top that'll move into the shop next week...so there's more to come before we put a period on this thread....I'm also still one decal short. I gotta start working on that next week too.
Old 06-06-2015, 07:12 PM   #544
scf100
scf100's Avatar
Daylight!
Awesome Brad........you taking it to the Varsity tonight?
1970 2WD Blazer 454
Old 06-06-2015, 07:27 PM   #545
IronCanine
I'm trying....
IronCanine's Avatar
Daylight!
No Stuart...we're gonna hold off. Eric had a baseball tourney he had to go to and we've still got some minor loose ends. First time out, we're gonna show it together. Probably the July 4th show. That's what we're planning right now.
Old 06-06-2015, 10:39 PM   #546
Advanced Design
Advanced Design's Avatar
Congratulations on rolling up some miles! The Blazer looks spectacular. Wow, the brake lines were really fighting you. Would have been pretty stressful...
Advanced Design is offline   Reply With Quote
Old 06-06-2015, 10:40 PM   #547
Blown06
Blown06's Avatar
Looks awesome sitting at the gas station with miles on the odometer.
Me: Jarrod
Old 06-06-2015, 11:15 PM   #548
OLDYELLOW
OLDYELLOW's Avatar
It was a good day. Finally got to ride in a great Blazer!
OLDYELLOW is offline   Reply With Quote
Old 06-07-2015, 06:27 PM   #549
IronCanine
I'm trying....
IronCanine's Avatar
Thanks...they did...and it was. But all's well that ends well (as they say).
Thanks. Do you think it'll start to depreciate when it rolls over double digits?
Yes it was and yes we did.
Old 06-08-2015, 01:22 PM   #550
mtully79
mtully79's Avatar
Hell yeah!
Here's wishing you many happy miles!
mtully79 is offline   Reply With Quote
1970, blazer, k5 blazer, restoration, silver
