Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 06-23-2015, 12:44 AM   #1
Coupeguy2001
Coupeguy2001's Avatar
55-59 chevy truck parts
I just have a bunch of stuff I need to move out of my garage.......call me, text me, or email me, takes less time if I get fast questions, you get fast response
inside top door trim, left and right.
lower door bolt covers,
vent grills
brand new front engine mount rubber cushions, $4 each
original black plastic vent pulls /cables $10 ea
vent doors $10 ea
headlight switch $15
ignition switch, 6 cyl. $25
original air filters, oil bath, one with smog hose, one without $30 ea
brake drums 3 sets
brake shoes and parts new shoes, one new rear cylinder, 2 inch and 1 3/4 for eliminating rear brake lock-up
backing plates $15 ea
rear axles, one set, R&L $75 ea
rear pumpkins need bearings, complete $50 ea
set of spider gears with shims $100
front axle $45
front axle u bolts and wedges $10
rear axle housing $45
inside rear view mirror, new $30
inside cab light----new $40
57 steering wheel, needs restoration, but not bad $50
gas tank $45
rams horn manifolds 2 sets $100 each set
steering box for parts $35
tie rod with late model tie rod ends $50
front wheel bearings, taper and roller
front hubs $30 ea
original 55 horns, don't know if they work, just had them a long time. $50
735/70/15 BFG radial new, hasn't touched asplhalt still has dots on tread $75
left head light bucket $35
headlight rings 3 sets $40/set
deluxe heater bezel $10
glove box door slides $19
glove box lock $10
glove box door, needs fixing a little $15
alternators, fresh rebuilt, one used, 45 amp, $45 one wire alternator $65, and a one wire kit $40
leaf springs, front $100
original jack tie down $15
original under bed heat deflector plate $10
windshield wiper transmission arms $50
windshield wiper arms (no blades) $20
little arm bracket that goes between X in front of radiator to V-8 cross bar for radiator stability $20
various cab stainless, most of it has small dents where someone tried to press them on too hard. $15 each piece. Windshield piece has hail damage
hillenger512@cox.net
602-510-2519
Chris
Coupeguy2001 is offline   Reply With Quote
Old 06-23-2015, 12:33 PM   #2
fredos59
Re: 55-59 chevy truck parts
Hi Price on headlight switch, shipped too 91945? Thanks in advance.
fredos59 is offline   Reply With Quote
Old 06-23-2015, 01:37 PM   #3
Chuckuss
any brake pedals?
Chuckuss is offline   Reply With Quote
Old 06-26-2015, 03:34 PM   #4
fredos59
Beuller? Beuller?
Old 06-27-2015, 02:14 AM   #5
mdpaulson1
mdpaulson1's Avatar
how much for the vent covers and vent cables?
Mark
mdpaulson1 is offline   Reply With Quote
Old 06-28-2015, 04:55 PM   #6
Coupeguy2001
ok
vent covers, and plastic knob pull cables, $45 plus shipping
No brake pedals but I have a clutch pedal
ignition switch $30 shipped
Beuller, Ferris? day off?
Old 09-13-2015, 07:40 PM   #7
sleepindawg
Hey Chris,
I spoke with you on the phone Sunday evening.
My email is sleepindawg@hotmail.com
sleepindawg is offline   Reply With Quote
Old 03-24-2016, 04:33 PM   #8
michael bustamante
michael bustamante's Avatar
you still have the rear axle shafts? looking for 6 lug 14 spline
1967custom
michael bustamante is offline   Reply With Quote
Old 04-21-2016, 11:32 AM   #9
michael bustamante
ok i just got the money. ill take that shorter axle shaft from you. just PM me your pp info and ill send you the address at my work so we n shiop it here. (less expensive)
1967custom
