Old 08-11-2015, 09:17 PM   #1
Isaiah92260
Isaiah92260's Avatar
What are these plates for? I6
The two plates under the spark plugs, what are they covering and they're purpose? I noticed I'm getting alot of oil leakage around these plates and on the bell housing, I tighten the two bolts a couple good turns thinking possibly that they need to be. I didn't want to go too tight because I don't want to damage the seals that I could see that were under. Btw I just replaced the valve cover gasket but I'm having oil leaks still, but not as bad as before. I used a fork gasket because that's all NAPA had and I used silicon on both sides of the gasket. I just did a little patching with the sealant on areas I saw where too much oil was leaking.
Isaiah92260 is offline   Reply With Quote
Old 08-11-2015, 09:18 PM   #2
Isaiah92260
Re: What are these plates for? I6
The plates
Old 08-11-2015, 09:33 PM   #3
hotrod66
hotrod66's Avatar
Lifter covers
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 08-11-2015, 10:31 PM   #4
T and S
T and S's Avatar
Over tightening is just as bad or worse than not tight enough. Sounds like you have distorted your valve cover and lifter covers.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 08-11-2015, 10:39 PM   #5
Lugnutz65
Lugnutz65's Avatar
This is what is under those covers. Push rods that move the valve lifters.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-11-2015, 10:43 PM   #6
ACK
ACK's Avatar
There's a few reason's you can be leaking oil, most are simple fixes and inexpensive:
- Worn out lifter cover gaskets
- Faulty PCV
- PCV isn't hooked up properly
- Need to clean or purchase a breather style oil filler cap
If the PCV isn't hooked up properly, the engine is going to suffer big time. If it's not connected from the valve cover to the manifold, gotta fix it right away. If that's the culprit, you may still have a small leak after it's hooked up, but you won't be leaving an oil slick everywhere you go.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 08-11-2015, 11:28 PM   #7
Isaiah92260
- Faulty PCV
I recently bought a oil breather cap from auto zone. The PCV valve and hose are all connected just as you stated. I believe it is probably just time at start replacing parts. The valve cover is pretty damn worn already around the eyes and holes for the screws. I was thinking about getting that Oppenhuase aluminum valve cover, but I saw it doesn't have a hole milled in for the PCV valve and grommet to go into.
Old 08-11-2015, 11:29 PM   #8
Isaiah92260
I gave it two turns on that one side, I've never touched it before. I think it's just time for the gasket to be replaced.
Old 08-12-2015, 04:41 PM   #9
Isaiah92260
If anyone has experience with those aluminum valve covers, please let me know.
