08-30-2015, 06:56 PM | #1 |
separating engine from tranny
replacing the engine in my 72 have everything unbolted ready to pull... any magic trick to separating the engine from the tranny? thanks
08-30-2015, 07:02 PM | #2 |
Re: separating engine from tranny
08-30-2015, 07:19 PM | #3 |
it's an automatic. never dealt with an auto before always dealt with manuals in the past.
08-30-2015, 07:26 PM | #4 | |
Posted via Mobile Device |
08-30-2015, 07:27 PM | #5 |
take the bolts out of the bellhousing and pull it apart
08-30-2015, 07:31 PM | #6 |
Just one of many ways, I like to take torque converters bolts out and leave converter in trans. Just an option
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. |
08-30-2015, 07:41 PM | #7 |
Support the rear of the engine with a jack or a jackstand, remove the bolts in the bell housing. Remove the rear transmission mount. If you can remove the transmission cross member do so but if you can't you'll just have to jack it a bit higher to clear it. The transmission will be hanging off the guide pins in front so raise it up with a trans jack or a trolley jack just enough to remove the pressure on the guide pins and roll it back.
08-30-2015, 10:16 PM | #8 |
08-30-2015, 10:38 PM | #9 |
take a ratchet strap and strap up the trans just in front of the pan hook cherry picker to the engine and take it out
08-31-2015, 12:37 AM | #10 |
Funny that nobody mentioned about unbolting the torque converter first, then unbolt the bell housing
08-31-2015, 01:27 AM | #11 |
This is the correct way to do it. Unbolt the torque converter then push the torque converter slightly back towards the transmission. Support the transmission and then unbolt the bellhousing. You may have to pry a little to get it apart, but make sure all the bolts are out first!
08-31-2015, 06:19 AM | #12 | |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
08-31-2015, 06:27 AM | #13 |
Notice 3 torque converter bolt to flex plate holes and supported transmission. Also if it still has the flywheel dust cover on it has to be removed..
08-31-2015, 08:46 AM | #14 |
I "SEPARATED" my new powerglide from the engine in my '70 Nova a couple of weeks ago. Easy removal, didn't have to mess with those pesky bell housing bolts. Rotated the trans about 30deg. behind the engine on the launch.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
08-31-2015, 09:57 AM | #15 |
Makes those flex plate bolts easy to get to.
"Life is too short to drive a boring vehicle". Later, Wayne |
08-31-2015, 10:46 AM | #16 |
Ouch!!!
