11-14-2015, 11:00 AM | #1 |
Clutch pedal stop
Starting to clean up a few parts and noticed that the clutch pedal stop on my truck is bent and the metal is torn. Looks like the pedal isn't even resting against the rubber but next to it.
To clarify, this is part of the bracket that bolts under the steering column and has a rubber stop to keep the clutch pedal from coming up too far. On the right side of the first picture. Does anyone have a pic of what this area should look like so I can repair it? Thanks!
Jeremy |
11-14-2015, 06:37 PM | #2 |
Re: Clutch pedal stop
I have a couple of those brackets. I'll get a pic in the morning.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-14-2015, 06:48 PM | #3 |
That would be great. Thank you Jimmy.
Jeremy |
11-15-2015, 06:17 PM | #4 |
Here are two angles on the bracket.
Jimmy
11-15-2015, 07:31 PM | #5 |
Thanks for the pictures. I can't see the pedal causing that damage. Maybe someone pried it open for some reason. Probably better off finding another one instead of trying to repair it. I'll see what I can do with it.
Jeremy |
11-15-2015, 08:34 PM | #6 |
I have a few of these and the first one I grabbed was cracked. Crack starts at the corner of the bend and runs about a 1/4". They may crack when made and the crack runs over time. You are also missing part of the pad.
Jimmy
11-15-2015, 09:13 PM | #7 |
I didn't notice the pad... good eye. I guess that explains why the pedal wasn't touching it. I just figured the bracket was bent too far out from being cracked.
Jeremy |
11-15-2015, 09:34 PM | #8 |
If fixing yours does not work out let me know.
Jimmy
11-16-2015, 09:42 PM | #9 |
I will. Thanks.
Jeremy |
11-17-2015, 10:31 AM | #10 |
Common issue to find them bent back towards the seat or cracked as your was. Normally the biggest factor I've seen in the pedal being to far off the floor.
Install good rubber bumper and make sure the bracket ear is in the correct position if bent.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-17-2015, 08:54 PM | #11 |
I'd say bend her back and weld and a new rubber stop and it should be good to go...
1964 BBC 402 4x4 |
11-17-2015, 09:45 PM | #12 |
I'm gonna give it a shot. Can't make it any worse than it is.
Jeremy |
