![]() Join Date: Oct 2014
BB motor mounts
Will I need to trim the frame rails in order to get these to mount?
![]() Join Date: Jan 2007
Re: BB motor mounts
never seen that before. are you sure your main crossmember is installed correctly?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Sep 2015
Re: BB motor mounts
I'm eyeballing the mount itself it looks like it is bent at the one bolt hole something cant be right aside from the mount don't go cutting her up just yet
Roadtrip!
![]() Join Date: Feb 2003
Re: BB motor mounts
Factory BB mounts should bolt right in. Almost looks like you have it on the wrong side? Something isn't right...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: BB motor mounts
interesting. my truck is a factory big block with the original towers. were the frames notched like this from the factory?
Re: BB motor mounts
Well I had small block motor mounts on the frame and just bought these from another member on here as my plan is the put a big block in the truck. Any other thoughts they certainly don't line up without trimming?
Your post tells me that I need to trim the frame rail? |
Re: BB motor mounts
here's another pic i had saved of a factory big block truck. it sure seems like you need to trim the frame. i learned something new today.
Re: BB motor mounts
Thank you, it looks like we both learned something!
Re: BB motor mounts
you peaked my curiosity so i did some digging. found a thread with some good info. my guess (i could be wrong) is you have a 67 frame. 68 was the first year of big blocks, the frames may have all been clearanced for both sbc and bbc engines 68 and up.
http://67-72chevytrucks.com/vboard/s...d.php?t=578644
member #16
![]() Join Date: Dec 1999
Re: BB motor mounts
Your truck must be a 67. The 67's have to trim for BB mounts, BB's first came on 68 models.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
So,, what else you got???
![]() Join Date: May 2010
Re: BB motor mounts
correct....
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
Re: BB motor mounts
I remember reading about the wider frames on the front of the 67's in a header fitment thread. Could that mount slip in and bolt from the underside of the frame.
Re: BB motor mounts
I know I'm new here, but have done a ton of framework. Make sure if you do trim the rails, you don't use heat, AND make sure you radius the cuts like they did at the factory. Sharp angles gather stresses, and then cracks...you don't want that.
