Old 12-31-2015, 07:16 PM   #1
Moin
1972 1 ton project
Hey everyone I picked up a new project also completely new to trucks. It's a 1972 c30 with a flatbed. The truck is in very good shape and also drives. My plans are to lower the front with drop spindles and leaf over axle for the rear. For the drive train I got rid of the 4 speed and Chevy small block and picked up a 2002 duramax setup. The one thing I didn't understand is the rear is a dually and the front isn't. I believe someone must of swapped spindles and rotors to a 3/4 ton. I know it's a true 1 ton because of the vin.
Thanks everyone
Moin is offline   Reply With Quote
Old 12-31-2015, 07:19 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 1972 1 ton project
Looks good. Welcome aboard!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-31-2015, 07:31 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice truck! It'll be a real nice ride with a Duramax in it!
Ryan
1969 Chevy milk truck
Old 12-31-2015, 07:59 PM   #4
flashed
Very nice truck ,Im in to see more.
flashed is offline   Reply With Quote
Old 12-31-2015, 08:07 PM   #5
cypressbog
Go Pack Go!
Nice looking truck. I'm confused by your question about the front end.
cypressbog is offline   Reply With Quote
Old 12-31-2015, 08:13 PM   #6
Moin
Thanks everyone for the comments. On the front the rims are different. They are not dually wheels. Did the trucks ever come this way?
Old 12-31-2015, 08:32 PM   #7
Moin
Posted up some more pictures of the progress. I fab up some rear frame notches, purposely made them big so I can eventually bag it with a 4 link. Still have cut more into the frame and box the notches in.
Old 12-31-2015, 09:31 PM   #8
franken
It does seem odd that the front doesn't have dual type wheels and in the pics it seems the front isn't a dual setup. My guess is someone converted the rear. Maybe the SPID has clues?
That said it seems a bit sad that someone would take a one ton and bag it, or remove the capacity it was meant to have. Your truck.
Old 12-31-2015, 09:49 PM   #9
Mike C
Mike C's Avatar
I agree that most likely the rear was swapped in, but could have gone either way. Glad to see you are using the truck whether it's bagged and lowered or not!
I have an '02 Duramax and it's pretty awesome. Just be aware, all the LB7 need injectors eventually, and some sooner and more often than others. This is a $$$ proposition when you get around to doing it BTW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-31-2015, 09:50 PM   #10
Moin
With the frame reinforced and with large air bags I will be able to tow a lot more then the truck was designed for. I'm building air ride trailer to tow my other build.
Old 12-31-2015, 09:51 PM   #11
hugger6933
I see quite often the 69 70 hood on the 71 72 truck[two hood emblems]My one ton was that way as well. Jim
hugger6933 is offline   Reply With Quote
Old 02-26-2016, 01:32 PM   #12
Moin
Hey everyone its been a while since I got to work on the truck. I manage to find a wrecked truck for the swap.
1969 GTO 455 TKO600 Air Ride
1972 Chevy Ton Duramax
Old 02-26-2016, 03:43 PM   #13
flashed
That took some major surgery to fit in there ,staying tuned for more .
Old 02-26-2016, 08:37 PM   #14
Mike C
Mike C's Avatar
Nice. Amazing how big that transmission is! Most of the guys who swap the Duramax into cars run either a 4L80E or a TH400 with a Gear Vendors OD on the rear, and you can see why!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-26-2016, 11:55 PM   #15
jeff.d
i saw a 66 1 ton on kijiji the other day, dreamed about lowering and swapping a duramax into it. pretty much exactly what you are doing. then i remembered i dont have any use for a tow vehicle just yet, maybe some day. will be following this build for sure!
jeff.d is offline   Reply With Quote
Old 02-27-2016, 09:29 AM   #16
cooperhw
cooperhw's Avatar
Now I'm in.
Kinda thought about doing that to Homer some day if I kept him. I have a 2006 Duramax I daily drive since 2006. Great motors especially with that Allison behind em.
Yeah
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 02-27-2016, 10:39 PM   #17
Moin
The transplant in the 66 would look awesome, got some more progress done today. I didn't have to cut to much, I trimmed the fire wall a bit but thats about it. Since the truck is going to be on air I wanted to keep the engine above the frame as much as I could. I know will have to make a transmission tunnel to make room for the drive shaft. I ended up using the stock engine mounts just had to modify them a bit also modified the transmission cross member.
Old 02-28-2016, 10:36 AM   #18
63chevyll
gets board easy.......
63chevyll's Avatar
This is going to be good.
Are you converting the Column and Hydro boost from the duramax to the 72?.
Great build
63chevyll is offline   Reply With Quote
Old 02-28-2016, 03:56 PM   #19
Sicksty8
Sicksty8's Avatar
Nice truck! I remember looking at this one on Kijiji! Glad it found a good home. Looking forward to the dmax swap! Keep on givin' er
Sicksty8 is offline   Reply With Quote
Old 02-28-2016, 04:28 PM   #20
Moin
Yup I was thinking of using the steering column and hydro boost for this truck. That's awesome yeah when I found the truck I jump on it asap. I also found out the truck was an old provincial truck for 12 years in the environment department. I guess rolling coal would be kinda cool in an x environment truck.
Old 02-28-2016, 10:45 PM   #21
Thanos
Thanos's Avatar
The 2500 HD 8.1 with allison I had came with a 2 inch body lift from the factory, supposedly I was told anyway it was to help clearance on the transmission with some of the first gen HD trucks..
I do recall the trans cover to be slightly wider as well though.
Thanos is offline   Reply With Quote
Old 02-29-2016, 11:10 PM   #22
jeff.d
I just noticed youre from ontario, im originally from ottawa. where abouts are you from if you dont mind me asking
Old 03-01-2016, 11:15 PM   #23
Moin
Yeah no problem. I'm on the other side. I'm located in Kitchener
Old 03-14-2017, 08:30 PM   #24
Moin
Hey guys its been awhile,
just wanted to post some more pictures of the truck. I did get around welding up some cab corners and rockers, and finished up my rear 4 link I designed.
Old 03-14-2017, 09:01 PM   #25
Dieselwrencher
That is looking very nice! Do you plan to change the hubs out up front and put dually wheels up there?
Ryan
