Old 01-02-2016, 04:30 AM   #151
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
02
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 01-02-2016, 07:53 PM   #152
62stepside longbox
Cut a new hole for the shifter and patched the old hole with new metal.
Once I get the driveshaft shortened I should be ready for the road
Of course I still need to wait a month till I'm 16 and then get my licence.
Old 01-02-2016, 07:58 PM   #153
goatless
goatless's Avatar
Nice. Mine is open, and, boy does it get cold!
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 01-02-2016, 09:58 PM   #154
65sub
65sub's Avatar
Quick work on the trans install. Driving that truck should be a lot of fun with a 5 speed
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-02-2016, 10:46 PM   #155
62stepside longbox
Thanks, I bet it gets cold and loud! I plan on putting some kind of insulation/ sound detonator under the rubber mat to solve this problem.
Thanks, it should be fun and functional . I can already tell even without driving it that it shifts so much smoother than the old sm420. And I'll get better gas mileage
Old 01-03-2016, 01:21 PM   #156
Zane M
Your progress is great! Looking forward to future updates.
Zane M is offline   Reply With Quote
Old 01-03-2016, 02:57 PM   #157
62stepside longbox
Thanks zane
Old 01-03-2016, 04:56 PM   #158
62stepside longbox
I thought this was the original shifter boot the whole time but when I looked on the bottom side of it I read f*rd! Hopefully the disease hasn't spread to the rest of the truck already!
Old 01-03-2016, 09:07 PM   #159
TJ's Chevy
TJ's Chevy's Avatar
Looks good! Better ditch that ford shifter boot though. lol
Old 01-12-2016, 10:59 PM   #160
62stepside longbox
Been busy with school lately but have still been getting a bit done on the truck. I've been having troubles starting it. First I thought it was the carb then I thought It was the ignition but then I found out I had a big vaccum leak that seems to be the problem. So I ordered a new gasket that should be here soon. Hopefully it will solve the problem.
Old 01-14-2016, 01:23 AM   #161
chevy.c10
chevy.c10's Avatar
I have that problem with school taking up to much of my time also. Ive been watching the progress and it looks good! Keep it up!
chevy.c10 is offline   Reply With Quote
Old 01-14-2016, 08:00 PM   #162
62stepside longbox
Thanks, for the next couple of weeks I have exams and have no truck time at all!
Old 01-14-2016, 10:51 PM   #163
65sub
65sub's Avatar
Good luck on your exams Nik. We'll be waiting for updates when your done.
Dale
Old 01-14-2016, 11:35 PM   #164
62stepside longbox
Thanks a lot, hopefully I can concentrate on studying instead of spending all my time on the forums
Old 01-15-2016, 11:12 AM   #165
TJ's Chevy
TJ's Chevy's Avatar
Feel yer pain bud. lol School and then work 6 days a week takes most of my time. And now the bad weather don't help anything either. haha
Old 01-15-2016, 04:44 PM   #166
62stepside longbox
When I get my license my plan is to bring it in to the auto class so I can work on it during school.
Old 01-15-2016, 09:28 PM   #167
TJ's Chevy
TJ's Chevy's Avatar
That sounds like fun. lol I plan on getting my license in March.
Old 01-17-2016, 04:30 PM   #168
62stepside longbox
Got my intake/exhaust gasket installed and now there are no leaks but I'm still having a problem. Still won't fire unless I really flood it, then it just pops and backfires. could the cold have something to do with it? Any idea's?
Old 01-17-2016, 05:57 PM   #169
Cape Codder
Cape Codder's Avatar
Does your choke work? without a choke you will have to pump it full of fuel to start and then light pump to keep it going till it warms up.
Cape Codder is offline   Reply With Quote
Old 01-17-2016, 09:56 PM   #170
62stepside longbox
Yep the choke works
Old 01-17-2016, 10:38 PM   #171
namloc
namloc's Avatar
Yep the choke works
Nik .Had you opened up the carb. and checked float and needle and seat? Did you also check the initial timing to line up at tdc on the harmonic balancer timing mark?
The Snortin' Bull
namloc is offline   Reply With Quote
Old 01-17-2016, 10:43 PM   #172
goatless
goatless's Avatar
Funny. That's exactly how I start my truck without a functioning choke.
MECHANIC: "ME"
Old 01-17-2016, 11:03 PM   #173
62stepside longbox
When I have the choke off nothing really happens. When it's on it fires, It's not actually running, just lots of popping.
Old 01-17-2016, 11:06 PM   #174
62stepside longbox
Yes the float and needle are good and the rubber is in good shape and seats correctly. But I haven't checked the timing yet. It ran fine before and I didn't touch the timing at all but I'll still check
Old 01-25-2016, 09:09 PM   #175
62stepside longbox
Been busy with school lately but got some work done on the truck today. Made a filler panel to cover up where the gas filler neck used to be. Still needs to be welded in place.
