Old 01-19-2016, 01:10 PM   #551
knomadd
knomadd's Avatar
Re: Knomadd '71 SWB C-10
Originally Posted by aboesec10 View Post
ooohhhh shiny!!!!
You ought to know, you painted it, and buffed it out! Thanks again for your help with that, and helping me get it on and lined up the best we could.
Originally Posted by Mikem_72 View Post
Wow .... that looks really good man. It gives it a tough look.
Originally Posted by Bennett68C10 View Post
New hood looks great! I've always been a fan of cowl hoods.
Thanks guys, I really like it. I've liked the cowl hood look since before I owned a C10, so I knew I wanted it eventually. I'm pretty happy with it out of the box.
I do have a small issue. Aaron and I installed the Eddie Motorsports hood hinges and the entire hood sits too far to the passenger side. There is relatively no adjustment side to side, so I'm not sure exactly how I'm going to get it lined up perfectly, but I do know the entire truck needs some panel alignment done, so I'm not worried about it yet. After an hour of adjustment, we have it the best we could get it without going through and aligning the rest of the panels.
I'm wanting to take it to LST with the C/10 Club at the end of February, so I won't be pulling it apart before then, but I think I'll be doing it shortly after that. At least getting the panels lined up better.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-19-2016, 01:12 PM   #552
knomadd
knomadd's Avatar
Page flip pic...
This one's from last week... Took the little girl out for a ride.
-Duane
Old 01-31-2016, 03:26 PM   #553
knomadd
knomadd's Avatar
I printed out a little semi-transparent sticker template for my sport mirrors. Sticker part didn't work, so I taped it on.
drilled the holes (sorry for the side swap, forgot to take a pic without the mirror installed on the same side)
and mounted the sport mirrors
-Duane
Old 02-01-2016, 07:40 AM   #554
71Sleeper
71Sleeper's Avatar
New mirrors look so much better. what's you plans on filling the holes?
71Sleeper is offline   Reply With Quote
Old 02-01-2016, 05:59 PM   #555
mcbassin
Still Learning
mcbassin's Avatar
Digging the new mirrors and the copilot Duane!
Old 02-01-2016, 08:40 PM   #556
aboesec10
aboesec10's Avatar
now i gotta weld up those holes....lol
aboesec10 is offline   Reply With Quote
Old 02-02-2016, 09:08 PM   #557
knomadd
knomadd's Avatar
Thanks Mike! She's definitely a good copilot. Not much for directions though The mirrors just fit so much better. Now I can actually use my wing windows and SEE the mirrors!!!
Nah Aaron, I'll weld them up. No need to have you do more than necessary. I have a good little Lincoln MIG welder here at the house.
-Duane
Old 02-03-2016, 05:56 PM   #558
Raleighswb
I changed my front clip on my 72 to 67 and I have EMS hinges as well but I am using a flat hood. Spending a lot of time trying to get my hood lines right too will probably start from scratch this weekend,before you latch the hood how much does the hood stick up mine is at least 6 inches.Have not put the grill and latch on,but wonder if you could take a picture of your hood as it sits before you latch it.
Raleighswb is offline   Reply With Quote
Old 02-22-2016, 07:14 PM   #559
knomadd
knomadd's Avatar
It sits up pretty high. I had to change to 360 lb hood struts since the 340 lb struts couldn't keep it open. I'd say it's probably 6-10" up from the latched position.
-Duane
Old 02-22-2016, 07:19 PM   #560
knomadd
knomadd's Avatar
So I welded up the old mirror holes and got some filler on it for temporary fix. This will all be stripped to do the body work on the door when I start to prep for a new paint job.
Name:  2016-02-19 21.04.28.jpg
Spot primer
Name:  2016-02-20 11.11.41.jpg
after color sanding to blend it back in. Not the greatest match, but at least it's not gray. This should do for a little bit.
Name:  2016-02-21 18.49.08.jpg
Now I just need to polish it and reinstall the mirrors.
-Duane
Old 02-23-2016, 08:56 AM   #561
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the doors Duane. I can see where those extra holes would bother you. Hope to see your truck soon.
Old 02-23-2016, 10:47 AM   #562
knomadd
knomadd's Avatar
Thanks Mike. Does that mean you'll be making the trip down on Saturday? Are you bringing your truck?
-Duane
Old 02-23-2016, 03:40 PM   #563
mcbassin
Still Learning
mcbassin's Avatar
I'm working on a plan right now. Everything will have to line up perfect for me to be able to make the trip. I've another plan for Friday for months I can't get out of. If I go it will probably mean getting up super early or driving straight through Friday night.
Old 02-23-2016, 10:09 PM   #564
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on installing your new mirrors and repairing the holes on the old ones.
Ryan
1969 Chevy milk truck
Old 02-24-2016, 12:02 AM   #565
Raleighswb
Thanks Duane, my hood doesn't want to stay up all the way and closes down right around where your hood does-- will change out my 300 lb struts for something stronger mirrors look good now you can see,Everette
Old 02-29-2016, 09:40 PM   #566
knomadd
knomadd's Avatar
I thought I had a close-up of the chipped paint on the passenger bedside, but I don't. Regardless, I fixed the chips with a skim coat of filler, and painted it with the color matched spray paint. It's not perfect, but it was good enough for the Lone Star Throwdown show this past weekend.
I sanded, filled, sanded, filled, sanded, primed, sanded, painted, cleared, color sanded, buffed and polished in a roughly 20 hour period. Not bad for spray paint.
-Duane
Old 02-29-2016, 09:44 PM   #567
knomadd
knomadd's Avatar
And Ruben (poweredbychevy79) snapped this picture at LST on Saturday. Looks a lot better in the pic than it does in person. Makes me really want to get this painted.
-Duane
Old 03-01-2016, 09:13 AM   #568
mcbassin
Still Learning
mcbassin's Avatar
Look good from here Duane. I hope to see you guys down there next year. I didn't get home till after 1:00 on Friday. That would have put me down there way late.....
Old 03-01-2016, 09:15 AM   #569
Bennett68C10
Bennett68C10's Avatar
Truck is looking good Duane
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-01-2016, 09:21 AM   #570
Mikem_72
We were having a serious conversation back there lol...... Truck looks great.
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 03-01-2016, 10:18 AM   #571
aboesec10
aboesec10's Avatar
Holy cow my hair is getting crazy gray!......
Old 03-21-2016, 11:37 AM   #572
knomadd
knomadd's Avatar
It's been a while since I've done anything to the truck, so it's about time for an update. My wife went out of town with her mom on spring break. With that time alone I was able to do a few things to the truck without having to worry about honey-do's she might have for me.
So I installed the Digi-Tails LED panels... First, I must say that the Fesler lenses don't leave any room for an LED panel so I had to order the Marquez lenses. They are TIGHT, but the LED panels fit inside the Marquez lights. Here's a comparison of both lenses; Fesler on the right, Marquez on the left...
Fesler on top Marquez below
Digi-Tails LED panel installed
New Marquez lights installed
-Duane
Old 03-21-2016, 11:50 AM   #573
knomadd
knomadd's Avatar
I also extended my exhaust, although I had to finish it up after my wife returned.
The old exhaust dumped before the trailing arm cross member which was extremely loud and resonated a lot in the cab. It now dumps right in front of the rear axle.
Modified "s" bend to allow exhaust tube to pass through trailing arm cross member (don't mind the road grime, grease and dirt accumulation... it's been used as a truck for a very long time. It won't be a frame off resto for some time).
Pass through the cross member (this is the old dump location)
Another "s" bend to get the mufflers between the frame rails. I have heat shields coming to keep the heat away from the air management stuff (the black metal piece above the exhaust).
Not too bad for my first exhaust job. I think I'd do it differently if I had more space and time to do this in. It definitely cut down on the resonation and I don't anticipate any more ringing ears on long trips. It still sounds good outside the cab, which is awesome.
-Duane
Old 03-21-2016, 12:07 PM   #574
roushinator
roushinator's Avatar
Nice Work!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-21-2016, 01:23 PM   #575
mcbassin
Still Learning
mcbassin's Avatar
Excellent work as always Duane! Digging the new tail lights
