Old 02-23-2016, 11:25 AM   #1
Papa Smurf
Active Member
tailgate rust out
Can anyone give me suggestions on how to keep a tailgate from rusting out from the inside. I just found a 71 GMC tailgate that has been on a shelf for 25 years. Looks great with just a little surface rust on outside. I have one now on my GMC that rusted to shreds from the inside after I had it painted. Don't want that to happen again.
72 Sierra Grande 2500 BB
72 Sierra 2500, 42K miles, factory buckets
72 Cheyenne 20
72 Chevy SWB, Factory BB, Leaf Spring
Papa Smurf is offline   Reply With Quote
Old 02-23-2016, 06:31 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: tailgate rust out
Short of cutting a hole on the inside and coating the entire inside with rust inhibitor I don't think you have any options. Other than don't drive it in the rain and store it in a humidity-controlled environment.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-23-2016, 08:24 PM   #3
dozerbill72
dozerbill72's Avatar
Take it off and dump a little diesel fuel in it and slash it around do this about once a year. It will stink for a bit but as the fuel dries it leaves behind a paraffin base. A few old farmers around here do the entire under side of their trucks and they seem to last forever.
dozerbill72 is offline   Reply With Quote
Old 02-23-2016, 10:04 PM   #4
72MARIO
72MARIO's Avatar
Product like Rust Check Krown Fluid Film and Corrosion Free are well knowan in Canada for providing rust proofing products thats work very well at preventing inner pannel deterioration.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-23-2016, 10:08 PM   #5
72MARIO
72MARIO's Avatar
http://www.fluid-film.com/shop/
My favourite. Smells funny at first but work amazing.
2005 TAHOE DD
Old 02-23-2016, 11:19 PM   #6
Coley
Coley's Avatar
Smile Re: tailgate rust out
BINGO!
I was just going to write up on this product and process.
Each can comes with a small squirter tube (like WD40) so I take that and insert it up around the tailgate latch handle and let fly in there...all directions. If memory serves correct...you might also have a very small access at the left/right inner panel join points...can't quite remember. All you need is enough space for that little tube to fit in.
The rustcheck runs down and spreads out in there...at some point you can see it leaking out a bit.
Its a great product tho'....it has rust stabilizer/etchers in it as well as creep agents, repellents, etc...and it works well. It looks a lot like pinkish/red transmission fluid and it is not unpleasant to work with.
Regardless...after several cans of that put into the truck every fall......I know I'm good to go, no more rust or winter storage/moisture worries.
I do this exact same process with both rocker panels...from below!! It is messy but there are a few small rocker drain holes on the underside of the rocker area that allow for that little squirter tube to fit up in and I fill both those rockers with this spray (all directions)...and then....sleep like a baby in the Canadian winter...lol.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-24-2016, 09:00 AM   #7
70STOVEBOLT
Why do you have to put it on more than once?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-24-2016, 09:55 AM   #8
72MARIO
72MARIO's Avatar
In Ontario people that want to drive there new truck/cars for more than 5 years have there cars undercoated yearly. There is always a oilly residue that has to be wiped from the panel bottoms but thats easier to deal with than rust.
Careful using the straws that come with the can of spray i have one inside my rocker it flew out while spraying. No way to get it out now !!
2005 TAHOE DD
rust, tailgate problems
