Closed Thread
Old 03-02-2016, 10:01 PM   #851
1958Warrior
1958Warrior's Avatar
Re: What did you do with your truck today, take 2
Sat. I removed my windshield ,I expected the worst, weather stripping was all cracked in the lower corners and rock hard.
I was surprised to only find one bad spot in the upper pass. side corner , about 1" x 1/4" hole along the lip. looked like it was caused by a mouse nest up in the corner. The rest of the lip around the windshield looked new no surface rust whatsoever. I made a little patch for it but wasn't able to weld it in due to being a little to windy for my liking.
Scored a nice used windshield off CL, last night. The guy was asking $100, he also had a pair of door he was asking $350 for the pair, both needed the bottoms repaired, got all for $250 pkg. deal couldn't pass it up.
My windshield was marginal, had a 4" crack, and about 5 chips. My doors are ok but the drivers looked like it had been sprung open and someone had tried to straighten the edge with a pair of vice grips.
Hope the wind will be calm and cooperate this weekend , I'm at the mercy of the weather out in the driveway .
1958Warrior is offline
Old 03-06-2016, 10:02 PM   #852
nvrdone
went to a jeep show & found some led replacement bulbs for the pickup. 1157 super bright led's for 20.00 each. man are they bright !! much better than regular 1157's
nvrdone is online now
Old 03-07-2016, 08:53 PM   #853
47AD
Went over to the body shop today that I had taken my cab to for the rust repair and removed it from that shop to save it from the hack job they were starting to perform on it. Can't tell you how upset I was with the work they had started. Took the cab outta there and is now in another shop closer to my house that I should have went to in the first place. They know what is needed to be done and at least I'm close enough that I can check on their work at any time.
1947 AD 3100
47AD is offline
Old 03-07-2016, 09:43 PM   #854
Tesone
Made it run!
http://vid469.photobucket.com/albums...01F12A51B4.mp4
Tesone is offline
Old 03-08-2016, 04:08 AM   #855
oldman3
oldman3's Avatar
Sweet...Jim
oldman3 is offline
Old 03-12-2016, 09:59 PM   #856
Atommik
Atommik's Avatar
Took it out of winter storage and got it on the road for 2016!
Atommik is offline
Old 03-13-2016, 09:50 AM   #857
47 Fasttoys
47 Fasttoys's Avatar
Wired up my reverse lights using a relay only to find out the ground is back feeding through the indicator bulb when the ignition is turned off causing the indicator light to light dim. Maybe time to kill the power source to the relay or use a diode.
Rob
My '47 C.O.E build
47 Fasttoys is offline
Old 03-13-2016, 07:36 PM   #858
Coupeguy2001
Coupeguy2001's Avatar
Well, after 23 years, my aluminum radiator is starting to leak.
I bought an Ebay radiator, and a shroud with a 16 inch fan on it so I spent a few hours making them fit each other and got them ready to install. I bought an air conditioning hose kit, and had some fun installing the binary switch on the dryer, and planning locations and hose routing.
I bought the condenser, but it hasn't arrived yet, so just biding my time right now.
Drove it to work, and cleaned the truck while waiting for an airplane to arrive.
All in all, just another truck week.
Last week I gave the new tailgate and roll pan to the painter, and so I am still waiting for those pieces to arrive so I can install them.
Since I drive the truck a lot, it's a little embarrassing to drive it around not assembled all the way.
Coupeguy2001 is offline
Old 03-14-2016, 12:41 AM   #859
wolffcub
wolffcub's Avatar
I put a stereo / speakers in my 52 on Friday night and installed some under dash courtesy lighting tonight. its finally nice to have something to listen to and not have to use my cell phone blasting out the tunes.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline
Old 03-15-2016, 12:54 AM   #860
oldman3
oldman3's Avatar
Well, here in Missouri it still 3/14 so this is what it did. Today is my 70th birthday, it was a nice 70 degrees in the Ozarks today, so I took a 20 mile trip down the road. Was great to drive the truck again, after a few months of bad weather. Here's a couple pics...Jim
oldman3 is offline
Old 03-15-2016, 05:30 AM   #861
crossfire84
crossfire84's Avatar
happy late b-day!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 03-15-2016, 07:26 AM   #862
Advanced Design
Advanced Design's Avatar
Fun day Jim, Happy Birthday!
Advanced Design is offline
Old 03-15-2016, 09:41 AM   #863
Rude Dude
Rude Dude's Avatar
Modified a Jeep brake pedal to use on the 1955 Big Window cab see my build for detail instructions.
Rude Dude is offline
Old 03-15-2016, 10:19 AM   #864
Rude Dude
Rude Dude's Avatar
Forgot the completed picture, total cost was $85 = pedal $20, 8 inch booster $35 and corvette brake master cylinder 1977-1980 $35.
Old 03-19-2016, 12:38 PM   #865
crossfire84
Stopped at the body shop today and they are spraying paint!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 03-19-2016, 08:25 PM   #866
lynx5653
lynx5653's Avatar
went to new hampshire and picked up a donor chassis 86 shortbed, starting my build from scratch again !!!!!!!!!!!!
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline
Old 03-19-2016, 08:45 PM   #867
OrrieG
OrrieG's Avatar
Minor progress got the fender corner patch done. Glad I noticed it before paint.
OrrieG is offline
Old 03-19-2016, 10:37 PM   #868
b-mac
b-mac's Avatar
Vacuumed out the cab after blasting it last week with my HF pot blaster. I said f' it on the roof...encapsulator here I come.
b-mac is offline
Old 04-03-2016, 10:46 PM   #869
iowaboynca
iowaboynca's Avatar
did a little clean up in the garage and began working on a tool to straighten brake lines. Will post pics when done.
Build: "1950" GMC -Charlotte
iowaboynca is offline
Old 04-04-2016, 06:55 AM   #870
Michel
Michel's Avatar
Hood was not closed securely, each road bump was moving the Hood by 2 inches up and down at least.
So welding applied to the latch plus replacement of the rubbers solved the problem. Much more quiet too!
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle
Michel is offline
Old 04-10-2016, 07:59 PM   #871
mphudak
Went from a 350 to a 283. Now just waiting on a high mount alternator bracket to be delivered and find where I put my power steering pump bracket. It was a 2 day project due to a few issues (needing a new torque converter and a few other items.) It's good to have a summit near by...but not so good making a 70 mile 1 way trip on a friday evening from N. Atlanta to S. Atlanta (3.5-4hr round trip due to traffic). Was all worth it firing up with just the headers. Fortunately i warned the wife and daughter...but my poor neighbors. My cal-custom valve covers are still out being polished and I will have my late 50's corvette air cleaner tomorrow. Going for a 60's style build vibe.
55.1 GMC Suburban Hydramatic
mphudak is offline
Old 04-13-2016, 08:01 PM   #872
la hi
I removed the swb bed on my 57. I will now look at a 4-link
la hi is offline
Old 04-13-2016, 09:13 PM   #873
Advanced Design
The 60's vibe will be very cool. Love your Burb!
Old 04-13-2016, 10:23 PM   #874
Layedoutsonoma91
Layedoutsonoma91's Avatar
Drove it around town!
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline
Old 04-14-2016, 03:15 AM   #875
RockinKees
RockinKees's Avatar
^^ very nice truck!!
Bet you had Some fun today!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline
Closed Thread
