Closed Thread
Old 03-24-2016, 02:38 PM   #3426
70sLover
Re: What did you do to your truck today? Chapter II
Originally Posted by OregonNed View Post
I've been doing some little things while I am waiting for the wood bed to get finished that need done. While the rear bumper is off I polished it up, and removed some light surface rust pitting on the underside with Coke and aluminum foil. I also restored the license plate holder, and all brackets - then painted with POR 15 top coat. Great paint!
So what steps and tools did you use to get that bumper to a mirror finish?
70sLover is offline
Old 03-24-2016, 03:07 PM   #3427
OregonNed
OregonNed's Avatar
Well, the outer surface of the bumper was already like new - really only metal polish and some wax on it.. the inner had the start of rust and that is where I really cleaned things up. After the Coke and foil there, I used metal polish and wax as well.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-24-2016, 06:01 PM   #3428
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Installed the Lokar billet gas pedal and the brake cover for the truck. I also installed a new chrome rear diff cover for the 12 bolt.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 03-24-2016, 09:06 PM   #3429
Boyd67
Boyd67's Avatar
Installed new bumper, front and rear lenses, rebuilt doors with all new rubbers, added armrest, matching ignition and door locks, and new outside door handles. Busy day. Only have pics of bumper. Started getting dark, so I didn't get look real good but I think I may need to adjust my bumper.
Boyd
-67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie
Boyd67 is offline
Old 03-25-2016, 11:30 PM   #3430
Possmguts
Possmguts's Avatar
Just looked at it for a bit wondering what color its going to end up being when I get to that part... my garage is in shambles... where the heck is my cleaning lady??
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 03-26-2016, 07:47 AM   #3431
OregonNed
OregonNed's Avatar
I'm in the middle of changing my differential oil and cover (old one was a nice, rusted chrome unit). Draining overnight. Now I can see my gear ratio. Wife just loves that gear oil smell in the garage! Well, not really!
Old 03-26-2016, 08:33 AM   #3432
Possmguts
Possmguts's Avatar
Now is the time for that posi unit
Old 03-26-2016, 05:47 PM   #3433
mud.man.rj
mud.man.rj's Avatar
3.07 ratio, not the best unless a lot of highway, so gear set and posi.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 03-26-2016, 09:31 PM   #3434
CST10
CST10's Avatar
Took ol Samson to a car show today to stretch his legs and let the B horses run free. Been a great day.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 03-26-2016, 10:30 PM   #3435
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Took my evap. out and cleaned up the box to see what I've got. Apparently when more careless (ha!@) and dropped the engine in 1993, I sprayed along the outer edge of the box when I painted the firewall. Really a good five inches worth on the RH truck side. At any rate, it's a great box otherwise, so I'll try removing the paint. From what I've seen, I prefer not to paint the box. Worst "case" scenario I'll have to. Any suggestions how to remove that paint with no affect on the plastic evap. case is appreciated.
Also appears the A/C-Heater door in the evap. box doesn't want to close all the way. Don't know if that's common, but sure was a lot of dirt in there despite being garaged and little use.
BEAUTIFUL truck CST10
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 03-26-2016, 11:38 PM   #3436
kilrcady
How are leaves always findinf there way in my cab?
kilrcady is offline
Old 03-26-2016, 11:52 PM   #3437
71CHEVYSHORTBED402
What is the A/C-Heater door and Drain Tube in the Evap. box, and the Air Shut Off Valve Door in the cowl, for $300 Alex.
Tony
Old 03-27-2016, 02:14 AM   #3438
tommy3horse
tommy3horse's Avatar
Hauled way too much gravel...from just down the road.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 03-27-2016, 09:09 AM   #3439
Possmguts
Possmguts's Avatar
wow.. how did you keep it in the bed with it upside down like that? lol
Its a good looking worker
Old 03-27-2016, 09:56 AM   #3440
88fordf150
88fordf150's Avatar
Down force and speed. lol
Brad handshoe
88fordf150 is offline
Old 03-27-2016, 06:15 PM   #3441
Howitzer
Installed upper trim holding and some interior work.
I give up, i can't get the pictures right side up.
Howitzer is offline
Old 03-27-2016, 06:21 PM   #3442
flashed
Even upside down it looks great .
flashed is offline
Old 03-27-2016, 06:24 PM   #3443
DBK81
DBK81's Avatar
Installed my 3/5 static drop
1972 C10 - It might be old, but it's not slow
DBK81 is offline
Old 03-27-2016, 06:26 PM   #3444
Andy4639
Old member
Andy4639's Avatar
If using a I phone and you turn your phone long ways. Bottom of phone pointing right with volume buttons pointing down. Use the regular button for pictures and they should be right side up when you upload them.
Andy4639 is offline
Old 03-27-2016, 06:29 PM   #3445
RINC
RINC's Avatar
Pulled out my radiator on the 69 to get checked out.
Buncha parts on order.
Got cleaned up an spent time with the family.
Happy Easter.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 03-27-2016, 06:30 PM   #3446
Andy4639
Old member
Andy4639's Avatar
Here you go!
Andy4639 is offline
Old 03-27-2016, 06:33 PM   #3447
Howitzer
Thanks!
Howitzer is offline
Old 03-27-2016, 06:57 PM   #3448
Andy4639
Old member
Andy4639's Avatar
Originally Posted by Howitzer View Post
Thanks!
Your welcome!
Andy4639 is offline
Old 03-27-2016, 07:02 PM   #3449
Dlm11
Dlm11's Avatar
Took my cargo light out to find this great work
Dlm11 is offline
Old 03-27-2016, 07:06 PM   #3450
JMD
JMD's Avatar
Made a temporary electrolysis tank, seems to be working ok so far!
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Closed Thread
