04-01-2016, 01:23 PM | #1 |
Is my 4L80E the first ever done?
I doubt it. Is there anyone aboard here that might have done it before?
All the wiring and the TCU and SCU boxes are all in, the trans goes in today. I know we'll need to shorten the driveshaft and tweak the cooler lines, but am wondering how the linkage lines up relative to the TH400. For the 200-4R I was able to get it almost dead on by flipping the factory frame bracket upside down, but I'm hoping that since the 4L80E is derived from the TH400 (in fact the latter was renamed the 3L80 by GM) that they're the same, and it'll just work if I put the bracket back to factory. But if someone had done this before, I could ask instead of guessing!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-01-2016, 02:42 PM | #2 |
Old member
Re: Is my 4L80E the first ever done?
Mine was pretty much the same. I think we ended up using a long pivot point brace because of the exhaust though. I ran the B&M cable around the back of the transmission and have it pulling it into gear instead of pushing it into gear. Just make sure it's in the right gear.
The gears are just like a 400 as far as the selector other than it being over drive.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-01-2016, 09:15 PM | #3 |
That's because you have the rare cable shift option, but I don't!
Everything is in, linkage winds up being a couple of inches back from the stock location, so it will take some ingenuity.
04-01-2016, 11:04 PM | #4 |
Lokar shift rod and the 4L80E works great with the stock column shift. Eliminates a lot of slop too, it's one of the few aftermarket parts I readily recommend.
That being said, I'm running the 4L80E in my truck controlled by the Holley EFI. It's a bit of a different application but nonetheless quite effective. The 4L80E is a great trans and incredibly durable.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
04-02-2016, 08:52 AM | #5 |
I have the lokar linkage and it's pretty straightforward. I've noticed it's almost too easily moved to another gear though...normal?
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
