Old 06-26-2016, 03:14 PM   #2076
realvc
realvc's Avatar
Re: Donz '65 SWB Stepper Budget Build...
Looking good in the tent dude.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 06-27-2016, 07:50 AM   #2077
Ta2Don
Ta2Don's Avatar
Originally Posted by clemdaddy View Post
good work Don. beating the heat this year has been a problem but the seven day forecast has cooler weather ahead, maybe even a shower.
did you get the wiring close to completion? i don't have a taste for spaghetti but sure admire someone who does. fortunately for me Pete loves the stuff.
you are right about that old guy-get up early thing… I do the same.
Thanks Clem... no real progress with the spaghetti yet, getting sidetracked with honeydew and other thingz... see next post...
Thanx Vince... Hope to see some Garage Journal entries on your shop updates...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 06-27-2016, 08:09 AM   #2078
Ta2Don
Ta2Don's Avatar
Planned on some spaghetti time the past couple of nites... between evening Thunderstorm Saturday and other complications last night... no wiring progress... Arkansas summer has arrived Full Force, the last week or so has seen the heat index hovering between 105 and 115F, no shop w/ AC and working on truck out in heat equals little truck time for this old guy...
While browsing fb yesterday morning, I ran across a truck guy in GA with this dilemma... seems the PO of his '64 hacked up the heater box for some unknown reason...
Untitled by Donald Olivo, on Flickr
I happen to have a spare thanks to Jonathan (1963C10)... so this week this will be on it's way to GA... I also pointed the guy here...
While digging through my parts stash, to pull out the aforementioned heater box, I found this license plate bracket...
Complete with glass lens...
Disassembled
Bulb socket clean and in working order...
I even found the cork gasket for the lens is pliable and ready for service...
After a little hammer and dolly work I masked off the socket and began the paint process...
Painted the inside of the lens cover white...
Here's a pic of the back of my gauge cluster, with a new box of bulbs for illuminating it... prepping for more spaghetti work...
I will post pics of the re-furbbed License plate bracket as soon as the paint dries (humid so sloooooow process)
That's all for now guyz...
DON
Proverbs 27:17
Old 06-27-2016, 10:20 AM   #2079
TJ's Chevy
TJ's Chevy's Avatar
Looks great brotha! Looking forward to the finished results!
Old 07-08-2016, 05:15 PM   #2080
Ta2Don
Ta2Don's Avatar
Worked through the holiday weekend... and in the evenings I've been accomplishing some honey-dooz, in order to facilitate some truck time...
Over the past few days, I've started getting back after the wiring and also addressing the issue of the clutch pedal being about an inch and a half or more taller than the brake pedal... The wiring in the cab and front end is almost complete... the alternator still needs to be wired and the front and rear lights are not hooked up due to the fact that the front clip and bed are still separate from the cab and frame... I also need to purchase a fuel sending unit from LMC, as that is where the tank came from... On to the pics...
This was the temp when I called it a day today... thankful for a tent and fan and plenty of ice water...
for me mates across the pond...
Hard to tell from this angle, but the clutch peal is now about 3/4 of an inch taller than the brake... more better in my world...
The Gauge Cluster wired and in place, need to clean up bezel and find the screws...
The copper line to feed the oil pressure gauge waiting for hookup...
Next up is to wrap all this and put in it's home up under the dash... Gonna remove the seat so I can get myself in the proper position to make this job a tad easier...
Once I get the wiring settled under the dash, I'll be focusing on the brake lines, clutch pedal linkage, and then getting the front clip and bed installed...
Been pondering the bed floor, and think I'm going to steal Coulter's hinge idea...
DON
Proverbs 27:17
Old 07-08-2016, 11:19 PM   #2081
TJ's Chevy
TJ's Chevy's Avatar
Woohooo! Spaghetti time!
Old 07-09-2016, 03:57 AM   #2082
mjh1965
mjh1965's Avatar
Looking good Don . At this rate I think you might be driving to Clem's this year . Look on the bright side with that temperature at least you have a pool .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 07-09-2016, 08:18 AM   #2083
She's almost ready to roll Don!
Old 07-09-2016, 11:20 AM   #2084
realvc
realvc's Avatar
You got it going your way now.
It has been on the warm side around here.
Do you have a rubber bump stop for your clutch pedal? It mounts like the brake light switch in front of the pedal. Back in the day a lot of times it was missing and the clutch pedal would be higher than the brake.
Vince
Galatians 6:14
Old 07-09-2016, 01:31 PM   #2085
likaroc13
Rollin' Old Skool
Keep it up Don, & you'll be rolling before you know it! It's been really hot around here as well. Be safe out there.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-12-2016, 08:14 PM   #2086
Ta2Don
Ta2Don's Avatar
Thanx guyz... I am getting ready to drive this soon...
I posted this question and look forward to wiring help... If you have info on this subject, please click this link and reply...
http://67-72chevytrucks.com/vboard/s...=1#post7651171
I picked up this connector today and need some advice on how it should be wired...
Thanx again for looking in...
DON
Proverbs 27:17
Old 07-13-2016, 03:43 PM   #2087
Ta2Don
Ta2Don's Avatar
Thanx to member Notsolo I now have the info I need to wire the alternator correctly...
I have a resistor on order and know which wires need to be hooked where on the regulator plug... Resistor should be here Friday...
So this morning I rolled the truck outta the tent, removed the seat, so I can fit myself under the dash to finish sorting the cab wiring... After removing the seat, the in-cab fuel tank disappeared...
The filler hose, probably original equipment pulled apart upon tank removal...
I then cut part of the brackets in lieu of drilling spot welds...
...they are now ground smooth and waiting for me to paint in order to finish covering any and all yellow from the previous paint scheme...
Not sure how I'm going to deal with this hole, notice the spaghetti waiting to be tucked away up under the dash... As for the hole, I've an idea up me sleeve, just not a complete idea...
Waiting for the temp to start on the downward trend a bit later today before tackling the spaghetti... Here's an Arkansas sunflower who's decided to wear dreads...
98% of the cab and engine wiring is complete...please don't ask for the formula to reach the %age point... Couldn't answer that one anyway...
till next time...
DON
Proverbs 27:17
Old 07-13-2016, 04:34 PM   #2088
Grizz1963
Grizz1963's Avatar
Surprised you did not post up the other pic you shared......
Progress again.
Love the sunflower, as you know, love my garden too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-13-2016, 05:06 PM   #2089
Ta2Don
Ta2Don's Avatar
Look for the other one on Bomp's Selfie thread... Here's a link, join the fun...
http://67-72chevytrucks.com/vboard/s...84#post7652184
DON
Proverbs 27:17
Old 07-13-2016, 05:48 PM   #2090
TJ's Chevy
TJ's Chevy's Avatar
Truck is looking great brotha!
And the "other" picture......
Just started blasting on mine....have some tweaking to do with my blaster. lol And lot's of little holes to fix, but soon I should be priming the bottom I hope. Probably next weekend.
Old 07-15-2016, 10:06 PM   #2091
Ta2Don
Ta2Don's Avatar
The resistor showed up today, as well as the helm joint needed for my clutch linkage...
Time to start gathering my brake lines...
DON
Proverbs 27:17
Old 07-18-2016, 10:23 AM   #2092
Ta2Don
Ta2Don's Avatar
I'd have to look through my thread for the exact number, but over the past 50 years the floor of my cab accumulated in excess of 42 holes...
DON
Proverbs 27:17
Old 07-18-2016, 02:00 PM   #2093
clemdaddy
clemdaddy's Avatar
Stay cool and near the pool, brother... we got a hot week ahead.
Looks good and great to see the progress.
clemdaddy is offline   Reply With Quote
Old 07-18-2016, 03:48 PM   #2094
dwcardfan
dwcardfan's Avatar
Coming right along! Looking good. Stay in the shade this week brother. It's gonna be a hot one.
dwcardfan is offline   Reply With Quote
Old 07-18-2016, 08:47 PM   #2095
rusty76
rusty76's Avatar
Looking good Don.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-18-2016, 08:49 PM   #2096
Ta2Don
Ta2Don's Avatar
Just got outta the pool...
See the reply to Clem!
Thanks guys... Today was a warm one for sure...
Rian was texting me pics of his car thermometer reading 27C in Jolly Ol' England, so I had to reply with an Arkansas summer reading...
Here's the thermometer reading in my shed... Thank goodness for fans...
This is the resistor and heim joint that showed up Friday...
Earlier in the day I dropped by a muffler and welding shop in town and picked up a piece of 3/4" steel rod...
...cut to length, 3 &1/2", drilled each end and tapped to 3/8x16 threads...
Painted and ready to install on clutch pedal...
DON
Proverbs 27:17
Old 07-18-2016, 08:53 PM   #2097
Ta2Don
Ta2Don's Avatar
Originally Posted by rusty76 View Post
Looking good Don.
Thanks Brother!!! Gonna try and get the resistor wired in for the Alternator feed one evening this week, plus run the sensing wire, that will be all the cab and engine wiring complete... next step, finish the clutch linkage and focus on brake lines... will be ordering my fuel tank sender soon, then get this thing road worthy...
DON
Proverbs 27:17
Old 07-18-2016, 10:16 PM   #2098
Bomp
Bomp's Avatar
Way to be on it. Even through the heat.
Bomp is offline   Reply With Quote
Old 07-19-2016, 12:49 AM   #2099
Grizz1963
Grizz1963's Avatar
You certainly are all over it now Don.
Looking great.
Old 07-19-2016, 08:40 PM   #2100
rusty76
rusty76's Avatar
Friend of mine lives in Siberia. The weather is a lot cooler right now than here. Lol. But I'll pass on winter there. Brrrrrrrr. But summer seems nice.
My build thread
Crossmembers CC
65 swb, c10, step side, tattoo
