07-05-2016, 10:27 PM | #1 |
1960 gmc sub
Started 2 years ago and h I have asked a few questions along the way. questions along but here is a photo line of where I was and
where i am at. |
07-05-2016, 10:29 PM | #2 |
Re: 1960 gmc sub
here are a few steps along the way
07-05-2016, 10:32 PM | #3 |
Re: 1960 gmc sub
putting frame together
07-06-2016, 02:14 AM | #4 |
Re: 1960 gmc sub
Any plans to get an original hood?
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
07-08-2016, 12:18 AM | #5 |
Re: 1960 gmc sub
not really sure what I'm going to do with the hood? about a year away from there
07-08-2016, 12:20 AM | #6 |
Re: 1960 gmc sub
here is where I am at with the body
07-12-2016, 09:35 PM | #7 |
Re: 1960 gmc sub
sub floor
11-21-2016, 11:19 PM | #8 |
sub floor
building the floor should have time to stain it this weekend still looking for rubber floor. Any ideas
05-29-2017, 11:26 PM | #9 |
Re: 1960 gmc sub
Got the bed reinstalled today!!
05-30-2017, 12:20 AM | #10 |
60-66 Nut
Re: 1960 gmc sub
Looks good
What did you use for the rubber on the floor?
05-30-2017, 09:10 PM | #11 |
Re: 1960 gmc sub
ended up using vinyl flooring 1 solid roll really couldn't find the rubber flooring anywhere. and I am sill having trouble finding the rear bolts any ideas.
05-31-2017, 12:42 AM | #12 |
60-66 Nut
Re: 1960 gmc sub
Which rear bolts are you needing?
05-31-2017, 09:51 PM | #13 |
Re: 1960 gmc sub
the tapered flat head carriage bolts that bolt the back plate on the rear of the floor.
02-21-2018, 10:37 PM | #14 |
Re: 1960 gmc sub
been working on it when I can and here is some photos along the way
02-21-2018, 10:39 PM | #15 |
Re: 1960 gmc sub
Donor truck
02-21-2018, 10:40 PM | #16 |
Re: 1960 gmc sub
and where I am at now
02-21-2018, 10:43 PM | #17 |
Re: 1960 gmc sub
Good progress!!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-16-2018, 11:08 PM | #18 |
Re: 1960 gmc sub
test fitted rear windows and frames today
09-17-2018, 12:19 AM | #19 |
60-66 Nut
Re: 1960 gmc sub
Looks good!
Did you buy the glass pre-cut or did you have it cut locally?
09-17-2018, 09:08 PM | #20 |
Re: 1960 gmc sub
had glass, might have to replace a few pieces though due to some welding slag not sure how it got on the glass. but not worried about that just yet.
thanks |
09-17-2018, 11:31 PM | #21 |
60-66 Nut
Re: 1960 gmc sub
Both welding spatter and grinding particles will stick to glass as they melt the surface.
02-17-2019, 11:38 PM | #22 |
Re: 1960 gmc sub
got to bolt up tailgate and lift gate, currently rebuilding some extra latches any on the latches would be great.
