Old 07-13-2016, 12:33 AM   #701
lower50's
lower50's's Avatar
Re: Loadmaster '47 COE
I agree with solid!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-13-2016, 12:55 AM   #702
solidaxel
solidaxel's Avatar
Originally Posted by lower50's View Post
I agree with solid!
WE Canucks stick together !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-13-2016, 01:12 AM   #703
mud.man.rj
mud.man.rj's Avatar
Maybe a lexan box to show it off, or smaller wooden box, could put a false bottom in the large box and make the top 1/2 useful.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 07-13-2016, 09:44 PM   #704
Bad Apache
Bad Apache's Avatar
Seeing as you use this truck as a truck, a cover is needed. I'd vote tool box, depending on it's looks. The trunk is cool, but too large. Let me sleep on it and try to come up with something else.
1958 Apache 454ci 4 speed
Bad Apache is offline   Reply With Quote
Old 07-13-2016, 11:48 PM   #705
nvrdone
if you could find an old tool chest and make it fit over the engine, that might look real kool
nvrdone is offline   Reply With Quote
Old 07-28-2016, 07:17 PM   #706
47 Fasttoys
47 Fasttoys's Avatar
OK, with it being so dang hot I haven't been doing a lot of truck work lately. I have on the other hand been doing some research on adding AC to the truck. I have decided to go with the Vintage Air Mark IV under dash unit with cool function only. I will also use the donor truck compressor after moving my alternator to some other location and opening up that space. Keep in mind I am also running an engine driven air compressor (converted York) for the air ride system so space on the front of the engine is at a premium. I will take some pictures and give some details as I go.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 07-28-2016, 09:28 PM   #707
Bad Apache
Bad Apache's Avatar
Always look forward to your work Rob. We have had the same heat/humidity. Very hard to muster motivation. Especially after working on other people's cars for 9 hours!
I think you need to stuff a turbo in there as well!
Old 08-01-2016, 10:46 PM   #708
47 Fasttoys
So my Vintage Air unit arrived today. I was a little hesitant to fork over the extra bucks for this unit when I found quite a few for under $100 on the net. That being said I can see what you pay for: All the units I found for cheep had only a 4 pass evaporator coil and a plastic case, the Vintage Air unit has at least an 8 pass coil (that I can see through the vents) and a metal case. Below is what I received. A few things had to be moved, overall this part was easy to install. I should receive the remaining parts later this week.
Rob
My '47 C.O.E build
Old 08-01-2016, 11:55 PM   #709
lower50's
lower50's's Avatar
I have heard great thing about VA
Look what I found on a FB page.
1951 MG TD
Old 08-02-2016, 07:03 AM   #710
47 Fasttoys
Dang, that looks just like my truck. Yes, on rare occasions I will buy from HF.
Rob
My '47 C.O.E build
Old 08-03-2016, 05:17 PM   #711
47 Fasttoys
Received some more parts for the AC system: a hose kit with 4 foot extra on the hoses and a dryer with switch. I need extra hose due to the engine location. I have been mocking up the new belt routing on a extra Vortec engine, looks like a 110 inch belt will do it. You can see the area I have to work with, things are much easier on the spare engine. You can also see I will need to modify the lower part of the compressor mount.
Rob
My '47 C.O.E build
Old 08-03-2016, 08:28 PM   #712
Advanced Design
Advanced Design's Avatar
The mock up engine sure beats pulling the front end apart. Good idea!
Advanced Design is offline   Reply With Quote
Old 08-03-2016, 11:01 PM   #713
lower50's
lower50's's Avatar
Even in a normal truck that is a great idea.
1951 MG TD
Old 08-09-2016, 05:19 PM   #714
47 Fasttoys
Making more progress on the AC install. You can see why I originally mounted the alternator in the AC compressor location. I also had to move the fuel lines and rewire the alternator. I ended up cutting a bit out of the rear of the seat surround, I have heavy wall 1 inch tubing for support and some other gussets in place so I think it will be OK. I built a mount for the condenser and now have it, the compressor and the evaporator installed. I had to order some additional fitting so it will be at least next week before I can charge and test the unit.
Rob
My '47 C.O.E build
Old 08-18-2016, 10:50 PM   #715
Gokart Mozart
Jerry cans on either side with ammo box in middle. Cans could be storage, not just fluids. http://www.jerrycan.com/shop/jerry-c...lity-tool-box/
Coke cooler http://www.ebay.com/itm/Vintage-Coca...3D331941502721
Gokart Mozart is offline   Reply With Quote
Old 08-21-2016, 07:05 PM   #716
47 Fasttoys
Ta Da! I now have working AC in the truck. I crimped the lines last week and a friend loaned me some gauges and a vacuum pump. I vacuumed the system for about an hour (after adding oil), charged the system with 2 cans of Freon and bingo 42 degree air. During the process I also rewired the fans to run at half speed. I didn't need full speed and the truck never got over 200 degrees. You can see the fire wall is getting a bit crowded with hoses.
Rob
My '47 C.O.E build
Old 08-21-2016, 07:10 PM   #717
Katrina/10
Katrina/10's Avatar
Does it cool the whole cab down well? If you are happy with it, I'm going to buy one of those Mark IVs.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-21-2016, 07:30 PM   #718
47 Fasttoys
So far cools great. I don't yet have and insulation on the main floor, I do have it over the engine covers, and drivers door has a gap issue and I still run the unit on low speed and at about 25 % on the temperature dial. I ran it on high to test it and the fan is not to noisy on high speed. Air temp is a solid 42 degrees at the vents so it does not take long before you want to turn it down. Took it for a 2 hour drive today (90 degrees) and all worked great.
Rob
My '47 C.O.E build
Old 08-21-2016, 08:42 PM   #719
mud.man.rj
mud.man.rj's Avatar
Nice work, very cool, pun intended.
5.0 4spd std.
7" lift w 35's.
Old 08-21-2016, 09:09 PM   #720
Bad Apache
Bad Apache's Avatar
Luckily you have plenty of firewall for all those hoses/tubing. Great work as usual!
Old 08-21-2016, 09:35 PM   #721
joedoh
joedoh's Avatar
way cool! (mud mans puns are contagious)
Old 08-21-2016, 10:10 PM   #722
Advanced Design
Way cool...congrat's!
Old 08-21-2016, 10:50 PM   #723
BlueJeep
BlueJeep's Avatar
I also think it looks cool!
Did you hook up the wire that tells the ECM that the A/C is on? I didn't, yet, and mine pulls the engine down when I kick it on.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-22-2016, 05:40 PM   #724
Katrina/10
Katrina/10's Avatar
Excellent! I'm glad to hear it's working well. That is the unit I want to put in my 51. I was curious about the fit, I see you offset it a little to the passenger side to clear the cowl vent handle. I thought that might work, looks like you bent the right hand bracket a bit to fit the curve of the bottom of the dash in that area. Looks good!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-22-2016, 05:55 PM   #725
47 Fasttoys
Thank all,
Good eye Gary, you are correct on both accounts.
Bluejeep, I do use the ECM to turn on the cooling fans but I do not tell the ECM the AC is on. For any load or change in idle it puts on the engine the engine recovers very fast, I don't notice any real change. I do notice a minor loss in power with the AC on but that was expected.
Rob
My '47 C.O.E build
