Old 07-15-2016, 02:20 PM   #1
Lugnutz65
Lugnutz65's Avatar
Brake Booster interferes with Inline 6 Air Cleaner
I was afraid of this.
So my brake booster interferes with my air cleaner. Options?
1. smaller air cleaner housing. Suggestions?
2. Fabricate a new air cleaner housing.
3. Swap to the weber 32/36 I have sitting in the box. (I hate this option at this point of my build because the Rochester B is rebuilt and runs perfect).
So, I'm installing a 1995 Blazer power brake booster and MC with a CatainFab firewall bracket (Nice product BTW!).
The air cleaner housing is not going to fit because the booster is in the way.
I bought (and returned) the really small Mr Gasket air cleaner part #4354 because it didn't fit properly on my Rochester B carb. It said it was for 1 barrel carbs but the base ID was too small (barely).
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-15-2016, 05:17 PM   #2
jayoldschool
Moderator
Re: Brake Booster interferes with Inline 6 Air Cleaner
#4
Send me that air cleaner base to replace mine with the chopped off horn!
lol
jayoldschool is offline   Reply With Quote
Old 07-15-2016, 06:43 PM   #3
62stepside longbox
62stepside longbox's Avatar
Yeah I'm running into this same issue on my 62 with a 261 and an oil bath aircleaner. I think I'm going to have to get a smaller aircleaner
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-15-2016, 08:07 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
There was an offset lowered air cleaner that was optioned for this reason.
Something like this:
Old 07-15-2016, 08:11 PM   #5
aerotruk63
aerotruk63's Avatar
Originally Posted by jayoldschool View Post
#4
lol
See I wanted more air inlet so I took a piece of 3" exhaust pipe and made a new snorkel. Changed the cover to the correct concave 63 style.
Old 07-15-2016, 08:28 PM   #6
64shortbox
64shortbox's Avatar
Would using a smaller dual diaphragm vacuum booster help? Like one from a 92 Chevy Astro Van or S10?
64shortbox is offline   Reply With Quote
Old 07-15-2016, 08:38 PM   #7
slepysal
slepysal's Avatar
I went with a small inch dual diaphragm booster for clearance issues with my Clifford intake. as mentioned they used an offset air cleaner for six's with power brakes.I will try to find a picture here is mine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-15-2016, 08:44 PM   #8
slepysal
slepysal's Avatar
This is how the offset filter looks installed
http://67-72chevytrucks.com/vboard/a...1&d=1278277083
Old 07-15-2016, 08:52 PM   #9
aerotruk63
aerotruk63's Avatar
Old 07-15-2016, 09:21 PM   #10
rickoner
As others have said, the offset air cleaner is what was used. I have a setup from a 67-72 that I tried to install in my 65 with a 292, but unfortunately it interfered with the heater box. If you don't plan on running the factory heater you could go that route too. If you can't find one out there, I'd be willing to offer mine up.
rickoner is offline   Reply With Quote
Old 07-15-2016, 09:53 PM   #11
Lugnutz65
Lugnutz65's Avatar
Good idea. I have extra factory air cleaners but shipping to Canada might prove to be too expensive.
Yes, I suppose it would solve the problem.. However I really want to keep the budget down and using this booster and MC helps.
Attachment 1552936
I think I'll have trouble finding an offset air cleaner setup. I had forgotten about that option. I may just cut up one of my factory air cleaner.
Thanks for the helpful picture.
