Old 08-24-2016, 01:53 AM   #326
AJCK87
Re: My 1961 crew cab- XRMYCRU
Beauty Job! I'm no stranger to the difficulties of the working the firewall around the steering column, my sympathies! Your rig is awesome! I can't wait to put my hands on a 60-63 crew definetly next on the project list, the panel is getting finished first hahaha
AJCK87 is offline   Reply With Quote
Old 08-25-2016, 11:51 PM   #327
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I got the cab on the frame today!
my friend that helped with putting the cab on also brought by a bunch of bodywork supplies, and helped for about 4 hours getting me started on doing the roof.
Old 08-26-2016, 05:13 AM   #328
Looking good!
Old 08-26-2016, 06:15 PM   #329
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Looking great jon. I can't wait to see this thing together. Roof looks good.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 08-27-2016, 01:56 AM   #330
piratexpress1369a
piratexpress1369a's Avatar
Looks awesome
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 08-27-2016, 07:36 AM   #331
DPowers
One foot in front of the other
DPowers's Avatar
Congrats. Looking good.
DPowers is offline   Reply With Quote
Old 08-27-2016, 09:47 AM   #332
Bomp
Bomp's Avatar
Factory looking, you hit it spot on.
Bomp is offline   Reply With Quote
Old 08-27-2016, 10:22 PM   #333
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Nice work as usual.
Old 09-28-2016, 12:13 PM   #334
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
I have lurked, but I haven't logged in here for a few years and I feel like I might start doing so more with all the crew cab builds popping up. Your truck is absolutely amazing, sub'd to see the out come of this beauty
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline   Reply With Quote
Old 04-27-2017, 10:31 PM   #335
61Chevy454
Went and visited the truck today! Jon has a ton of cool stuff in his garage!
61Chevy454 is offline   Reply With Quote
Old 09-09-2017, 09:28 AM   #336
aerotruk63
aerotruk63's Avatar
I went and visited Jon last month and captainfab as well. Both are inspiring. But now I've got the 4 door itch. Re-thinking the 4wd project now. Now have parts and pieces to convert and this thread as a great reference source. Thanks Jon.
Old 02-12-2019, 01:42 AM   #337
jonzcustomshop
1961 crewcab
I'll have to come up with some pics, but I spent a couple weeks this summer working on the stepside bed: I got all the mounts lined out and fabricated, and then worked on putting a steel floor form a 73-87 fleet in it. I also started on a custom rear bumper...then other stuff came up, and then it got cold!lol
Old 02-12-2019, 03:09 PM   #338
Android04
Android04's Avatar
It's come a long way, can't wait to see it done.
Android04 is offline   Reply With Quote
Old 02-12-2019, 04:03 PM   #339
Cold in Montana, who would have thunk.
I feel bad not going to the shop when it is cold down here, probably like your fall temps.
Old 02-12-2019, 07:43 PM   #340
jonzcustomshop
1961 crewcab
Here are a couple quick pics, I will have to take some more detailed ones the next time I take it apart.
I just used angle iron to bolt the floor to the bed sides and front bed panel. I spaced the bolts on the side so they either go through the fender, behind the fender, or into the stake pocket.
Underneath there are some factory "U" supports from the 73-87 floor that sit down onto the frame, I did have to move one of them.
The floor sits above the step notch in the frame , and is only raised about 3 inches from stock.
In the back I bent a piece of sheet metal to space between the floor and bed when the tailgate is open.
Old 02-13-2019, 12:51 AM   #341
Captainfab
60-66 Nut
Looking good Jon
Old 02-25-2019, 07:24 PM   #342
awbrown
This thread almost motivates me to warm the shop up and do some work on the 63 , but then again , spring is around the corner , plus I have too much stuff stacked on my project truck right now....lol
awbrown is offline   Reply With Quote
Old 02-26-2019, 11:57 PM   #343
cwcarpenter98
cwcarpenter98's Avatar
Just finished reading through the whole thread, and I must say that you do some great work Every crew cab build on this thread makes me want to turn my 63 into a crew so bad. One day I'll get there
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-28-2019, 08:41 PM   #344
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Shes looking great
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-02-2019, 11:21 PM   #345
jonzcustomshop
1961 crewcab
Finally got around to sorting out the steering.... I used a 62/63 column since I am going to use a 62 wiring harness, and I don't have a good 60/61 column and turn signal cup.
Since the crossmember is pancaked, and the steering box is moved up I needed a universal joint, a friend had one laying around, and since it was a double, and the rag joint is still there I needed to make a bracket for a support heim joint so the column wouldn't flop. I bolted it to the upper crossmember holes, and had to notch the motor mount to clear the bolt.
Now on to the dash and wiring harness...
Old 04-02-2019, 11:58 PM   #346
Captainfab
60-66 Nut
Glad to see you back to making some progress
Old 04-18-2019, 03:19 AM   #347
jonzcustomshop
1961 crewcab
Well,, there is a little bit to report, I finished trimming the inner fender wells to clear the pancaked crossmember, steering heim joint, and steering box. the pass side was a quick and easy clearance over the A arm, the drivers side a bit harder. I had to trim around the new power steering box location, and decided to just put a hole for the power steering pressure line, and hook that up after the inner fender is mounted.
I cut off way too much to clear the heim joint, and ended up welding almost all of it right back where I cut it, I finally ended up with a notch for the joint, and there is a separate lower piece that covers the hole that now bolts on.
Next I was on to electrical fun!! I ended up mating a 63-64 column to a 62 harness, and a 60/61 instrument gauge cluster. My friend Chris was invaluable with a couple 62 (b/w) and 63 (color) wiring schematics and some input. The hand written one is the final cross reference for the 61/2 column wiring to the 63/4 column. I pretty much traced and discovered the use for each wire in each schematic to make sure everything would work as it should, I only had to add 1 wire to the harness since the 62 must have still been a generator harness, and the 63/66 is an alternator harness
All this was me just using what I had on hand, I had actually bought a 63 that had the gauge package and a complete uncut harness, and I was going to pirate all of that and the column out of it, but I went and got the silly thing running, and now with a different box, doors and hood it is too nice to part out. So I found I had a good 62 harness, a 66 front and engine harness, and a 63 or 64 steering column.
Old 04-18-2019, 06:49 PM   #348
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Nice job Jon
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
