Old 03-05-2016, 08:17 PM   #1
irishtrucker
irishtrucker's Avatar
67' C20 manual to auto trans, Turbo 400 conversion, drive shaft length??
New here, so hopefully I'm posting in the right forum. I have a 67 Chevy C20. Originally 3 speed transmission (3 on the tree). I've purchased a TH400 (automatic) for conversion. I have the trans installed. Now comes the hard part - the drive shaft. Since the truck obviously isn't drive-able, wondering A. Do drive shaft specialist come out to measure? If so, does anyone know of a trust worthy operation in Los Angeles (323 area) or B. Can I measure it myself?... and how do I do so with accuracy (starting point, ending point)? Help. I'm lost.
irishtrucker is offline   Reply With Quote
Old 03-05-2016, 08:38 PM   #2
joeminnesota
joeminnesota's Avatar
Re: 67' C20 manual to auto trans, Turbo 400 conversion, drive shaft length??
I found this website. Looks like good information here. I know nothing about the company.. Good luck as i will be in the same boat in a year or so when i do that swap!
http://www.dennysdriveshaft.com/how_to_measure.html
joeminnesota is offline   Reply With Quote
Old 03-05-2016, 09:16 PM   #3
hugger6933
The one posted on that link in the last post is a good reputable company. They will tell you how they want the measurements. Would looking for a stock front half of a driveshaft not be a viable option? I know EVERYONE says to change out thew halves together but I just thought if you could find a used shaft it might be OK to use.
Welcome to the forums there is lots of good people and some really good truck help here too. Jim
hugger6933 is offline   Reply With Quote
Old 03-05-2016, 09:42 PM   #4
EARNHARDT#3
EARNHARDT#3's Avatar
For mine I measured the original trans (and bell housing) from where it mates to the engine to the end of the output shaft. I measure the new on the same way and subtracted the difference. In my case it was 5-3/4". I dropped the DS off and said shorten the transmission side 5-3/4". A few days later I picked it up and viola...perfect.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 03-06-2016, 01:31 PM   #5
irishtrucker
Many Thanks for ALL the great info guys! HUGE help! I guess I'm in the right place.
Old 04-24-2016, 08:46 PM   #6
396C-10
How To Measure A Drive Shaft
If you have changed transmissions and need to measure for a new one, it is important to measure from the face of the seal on the tailshaft to the flat surface on the pinion-yoke with the pinion-yoke installed and the car sitting at ride height. Changing to a billet pinion-yoke can alter the length by as much as 3/4 inch. maintenance
With this measurement, the driveshaft shop can create the complete shaft with the required slip-yoke and predetermined play for the slip-yoke. For most applications, 1 inch is more than enough for suspension travel. Do not let a shop talk you into leaving more play than that. Some transmission shops will insist on running 1.5 inches, which would be disastrous. With that much of the slip-yoke hanging out of the tranny, there could be less than 3 inches of splined yoke in the tranny, thus creating a wobble in the yoke, which would cause a heavy vibration at various rpm. Stick with the 1-inch rule and you will be good to go.
Source- http://www.hotrod.com/how-to/transmi...alancing-tips/
396C-10 is offline   Reply With Quote
Old 04-24-2016, 08:54 PM   #7
396C-10
I have done this last month. Just know, your yokes will probably different on the T-400 transmission than the end of the drive shaft. You can use crossover U-joints. "While it can be done, using crossover U-joints is not suggested as a long-term solution. The smaller size basically becomes a fuse, and it will eventually fail." Is what I am finding.
Be prepared to replace the yoke on either the transmission or the drive shaft.
Mine is a 67' which had 3 on the tree. I went with a 396BBC / T-400 automatic. This is what I ran into. Hope it helps!!
Old 09-18-2016, 03:39 AM   #8
396C-10
This is where I am at. The yoke is different than the shaft. Any idea on a part number on that particular cross-over u-joint or will they know what I am talking about?
c20, driveshafts, turbo 400
