Old 10-12-2016, 07:04 PM   #1
HugoV
Help on torque specs for entire rear suspension etc.
Hi guys,
I have been searching all day and found a ton of conflicting information and I am hoping you can help me with the following...
I need torque specs for every bolt on the rear suspension...
1. Where the trailing arm meets the crossmember (pivot bushing)
2. The U bolts that hold the trailing arms to the rear end
3. The upper and lower bolts that hold the rear coil springs
4. The upper and lower bolts that hold he hocks
5. The upper track bar bolt (also does anyone have a stock measurement for this? I purchased and adjustable one and want to get it as close to factory)
Thank you in advance!!
HugoV is offline   Reply With Quote
Old 10-12-2016, 08:29 PM   #2
Clyde65
Clyde65's Avatar
Re: Help on torque specs for entire rear suspension etc.
Have you looked for an assemble manual?
What year ya working on?
https://www.brotherstrucks.com/mobil...tinfo/LFA6066/
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-12-2016, 08:33 PM   #3
HugoV
I was trying to avoid buying one but I will if I can't get the answers from you truck restoring vets!
Working on a 1964 C10.
Old 10-13-2016, 10:05 AM   #4
scoot_mcgrute
1. Where the trailing arm meets the crossmember (pivot bushing) - 140 ft-lbs
2. The U bolts that hold the trailing arms to the rear end - 200 ft-lbs
3. The upper and lower bolts that hold the rear coil springs - 55 ft-lbs
4. The upper and lower bolts that hold he hocks - 50 ft-lbs
5. The upper track bar bolt - I couldn't find this one this morning but I believe I took it to 75 ft-lbs on mine
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 10-13-2016, 02:58 PM   #5
HugoV
Thank you so much!!
Old 10-13-2016, 03:20 PM   #6
scoot_mcgrute
Originally Posted by HugoV View Post
Thank you so much!!
No problem!
Looking again, I found 85 ft-lbs for the frame side track bar bolt.
1966 Army Truck
Old 10-14-2016, 12:21 AM   #7
HugoV
No problem!
I have the same questions for the entire front suspension, any chance you could send me all of those specs? Maybe it would be easier to scan and post?
Or what book are you using for these specs?
Old 10-15-2016, 07:41 PM   #8
scoot_mcgrute
I searched on Google when I was putting mine together.
Are yoy looking for everything from ball joints to control arms?
1966 Army Truck
Old 10-15-2016, 10:15 PM   #9
HugoV
Yes, the entire thing. But I just ordered an assembly manual so I'm hoping it has all those specs. I'll post an update soon.
