10-13-2016, 10:41 PM | #1 |
drool, oh my
10-13-2016, 11:42 PM | #2 |
Re: drool, oh my
Absolutely gorgeous. I can see an insane final bid for that.... and it would be worth every penny. Someone put a whole lot of time into that!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-13-2016, 11:52 PM | #3 |
60-66 Nut
Re: drool, oh my
Yes I agree that is an absolutely gorgeous truck. It appears to be a painstakingly perfect restoration.
Only thing I am curious about is that it has a hydraulic clutch. I have not seen a '63 C10 or C20 with a hydraulic clutch. Maybe it is a K20 thing? I see it also has a generator. A '63 should have an alternator. Maybe this is a very early production '63?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-13-2016 at 11:57 PM. |
10-14-2016, 12:33 AM | #4 |
Re: drool, oh my
Good question Captain. Agreed, I though the slave cyl went bye bye after 62.
This is one of those trucks were you can look and look and say to yourself - yep, the builder did THAT right, and did THAT right, and did THAT right. The white grille surround is there. The black background. The details. The lamp post black wood. Wow. Anyone else seen a master n slave cyl setup on a 63 k20 before? Same same on generator. |
10-14-2016, 12:43 AM | #5 |
Re: drool, oh my
Yes, that truck is beautiful, I would love to have it. I will definitely be painting my bolts in the bed though.
10-14-2016, 12:28 PM | #6 |
Re: drool, oh my
I almost think that's a '62 with a '63 grille and badges.
Generator, hydraulic clutch on the master cylinder, and '60-'62 radiator and fan shroud. Also, would the non-Custom Cab have chrome around the vent window? Finally, the bed floors were painted after assembly--the hardware should all be painted black. GREAT truck, but something doesn't add up with the grill, clutch and radiator. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
10-14-2016, 01:09 PM | #7 |
Re: drool, oh my
10-14-2016, 01:09 PM | #8 |
Re: drool, oh my
The k trucks had the 235ci in 63, maybe why the gen. Also i thank the k's had the hyd clutch also in 63. Only thing it doesn't have is the org spicer hubs? I think jon on here has a 63 ktk?
1961 chevy K10 my build is------------61K10 build |
10-14-2016, 03:09 PM | #9 |
Re: drool, oh my
I like that seat material. Does anyone know where to find that in different colors?
10-14-2016, 05:01 PM | #10 |
Re: drool, oh my
Truly an original restoration.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-14-2016, 09:07 PM | #11 |
Re: drool, oh my
Would have to be very early 63 to have YELLOW plates ....I have 63 C20 with 283, alternator, steel tube offset upper hose,fiberglass shroud, clutch linkage and BLACK calif plates ....Looks like a factory half bred... Love to know what the cab mount spacing is .. As said above bumper says 62, HYD. clutch says 62, gen says 62 and yellow plates say 62
10-14-2016, 10:01 PM | #12 |
Re: drool, oh my
posted VIN looks like a 63 and there is no claim those are original yellow plates that I can see. Pretty sure one can get yom plates in CA, but it's been a while since I lived there. frame comments may be onto something though, good detective work!
10-14-2016, 10:20 PM | #13 |
Re: drool, oh my
X2! These trucks deserve the same attention to authenticity in restoration as any other GM product.
10-14-2016, 10:27 PM | #14 |
Re: drool, oh my
Yes, this '63 appears to be early production. Early production first design '63 4x4's used carryover '62 4x4 componets, including the 235, 261 etc, until the regular production second design was released.
10-15-2016, 03:25 AM | #15 |
Re: drool, oh my
My understanding YOM plate would have to be stamped or tagged 63 (as it is registered as a 63) and 63 is first year of black plates. The yellow plates could or would have been issued in late 62 (early 63 year model)
10-15-2016, 10:37 AM | #16 | |
Re: drool, oh my
I can't tell bumper bolt spacing differences unless they're side-by-side, but the firewall is different for the hydraulic master cylinder. The VIN number IS a '63... However, according to the decoders I've found, a couple things don't make sense; The listed VIN is: 3K2530103250 So, two things: All the VIN decoders I see list the 5th digit as a 4 for pickup truck, this is a 3, and I found a page that lists that as "Cab and Chassis," not a pickup. The number after that should be a letter for the assembly plant. I didn't see a "O" assembly plant listed, though the same spot on my Suburban's VIN is a 0. I don't know if it would make a difference, but my Suburban was originally a Forestry Service truck. A Cab And Chassis 4x4 could have been a fire truck or other government vehicle. Does anybody know if a 0 or O in the vin for assembly plant designates government vehicle? But finally, the last four digits are the production number of the truck--in this case, 3,250th to roll off the assembly line. By the time they got to the 3,250th truck, I strongly doubt they were still using hold-over parts. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School Last edited by Brad54; 10-15-2016 at 10:58 AM. |
10-15-2016, 12:42 PM | #17 | |
Re: drool, oh my
10-15-2016, 12:50 PM | #18 |
Re: drool, oh my
The 60-63 k trucks do not have the early wide x frame. the frame is similar to a c30-40 frame. The plates could be just add on yom here in ca. The 0 in the vin after the 3 i Oakland ca assm plant. still very nice tk.
10-15-2016, 01:04 PM | #19 | |
Re: drool, oh my
What does the "3" in the VIN indicate, for body style? Other sources I've seen indicate a pickup truck has a "4" in that spot. Definitely a nice truck, either way. I didn't know there was a First and Second series for the '63s, which is awesome information. -Brad
10-15-2016, 01:42 PM | #20 |
Re: drool, oh my
YES they do NOT have X frame they have a ladder frame... BUT the bumper bolt pattern im sure would be the same as the X frame and DID they make a special cab for the 4X4? or is the front cab mounting points wider on 60/62 4x4 also? like it is on C10/20s
10-15-2016, 04:46 PM | #21 |
Re: drool, oh my
For Anyone doing a 100% resto, the beds were done like this.
10-15-2016, 04:47 PM | #22 |
Re: drool, oh my
Note how the beds were papered and painted.
10-15-2016, 06:58 PM | #23 |
Re: drool, oh my
The fact that it has the hydraulic clutch makes perfect sense to me. If the 63 k series trucks were using older equipment like the 235/261 then they would also need to use the hydraulic clutch because they couldn't have a 235/261 with a mechanical clutch since they would need a different Bellhousing and therefore changing the motor mounts so it probably made more sense to just use the hyd clutch
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
10-15-2016, 08:26 PM | #24 |
Re: drool, oh my
I think it's a truck that sold a Barret Jackson last year. With 62 grill. Maybe someone found a stash of fleet vehicles.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-15-2016, 09:28 PM | #25 |
Re: drool, oh my
LV, this is a picture of that same 62 from barret Jackson, it has 6 lugs making it a k10 so I didn't think it's the same truck as the 63 k20
