Old 10-16-2016, 08:38 PM   #176
c Terris
Re: NAPCO Thread
Hey. Looking to do a 4x4 conversion on a 59 gmc. I was thinking about using straight axles from a small body blazer from around 2000. Only reason im posting here is I couldnt find what I was looking for. Is there a better option for axle choice as far as installation and what will I be in for as far as, hanging steering components, adding a transfer case to a muncie 4spd and such. I would like to use a dana 60 front and rear, but they all look to be full size truck axles and I need a 60". Thanks
c Terris is offline   Reply With Quote
Old 10-19-2016, 11:49 PM   #177
JPBrecheisen
Re: NAPCO Thread
My 57
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 10-20-2016, 12:30 AM   #178
bajabob
bajabob's Avatar
Re: NAPCO Thread
c Terris
I would ask what is your plan for the truck?? The Napco stuff is well built but old technology and can be a PIA to find parts for if you start tearing stuff up. If you want to build an ol skool 4x4 and maybe do some light 4x4 stuff then rock on. If you plan to do some serious boggin or trail running, find some late model running gear and run that. You will most likely have to fab some stuff up but there are lots of guys who have done it and it should be easy to find what your looking for.
bb
bajabob is offline   Reply With Quote
Old 10-20-2016, 09:20 AM   #179
JPBrecheisen
Re: NAPCO Thread
Originally Posted by bajabob View Post
c Terris
bb
Keep serviceable and drive. Tracking the parts difficulties, especially for '57 regarding Studebaker brakes on front axle. Vintage power wagons used a lot of same parts so they're a decent source for knuckle bushings, seals, etc.
I like old trucks as they were. No Mudd truck futures for any of my projects
Old 10-24-2016, 01:14 PM   #180
HO455
HO455's Avatar
Re: NAPCO Thread
A couple 3 Napcos for sale on C/L
http://seattle.craigslist.org/skc/cto/5826120981.html
http://seattle.craigslist.org/sno/cto/5797418588.html
http://seattle.craigslist.org/see/cto/5841277618.html
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 10-24-2016, 10:05 PM   #181
c Terris
Hey,
Really just want to drive it on the street with that tall look. Don't want to just throw a lift kit on the 2wd setup. I'de like to go on some moderate trails (no body bashing trails). The problem im having is figuring which axles to use. The 59 is the sam width as a small body blazer which is 60". I would love to use a dana 60 rear and dana 44 front but they are to wide. Is there a simple way to shorten those axles or if I use a axle that is already 60" how do I know the leaf spring will line up on the axle. I've been told if they don't alighn where originally specified the weight of the car could crush the housing of the axle. Obviously people have done this conversion, just need some help.
Old 10-24-2016, 10:08 PM   #182
c Terris
Re: NAPCO Thread
From there I will need a transfer case different length drive shaft and rearrange the steering mech. Can anyone reccomend a could transfer case and a good way or place to get the right size drive shaft. If anyone wants to lend some knowledge with that it will be much appreciated.
Old 10-25-2016, 01:15 AM   #183
'63GENIII
'63GENIII's Avatar
Re: NAPCO Thread
Originally Posted by c Terris View Post
Hey,
When I broke the kingpin off of the front axle on my 3/4 ton '57, I found that a 1985 corporate 10 bolt (3/4 ton) went right in. Short of having to redo the driveshaft, it was a bolt in deal. IIRC, the original axles were HO72s?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-25-2016, 10:33 PM   #184
HO455
HO455's Avatar
Re: NAPCO Thread
Hey,
I have gone with the Napco look on a 52 ford I have. I also wanted to use a Dana 44 & 60. The rear was easy I got one from a mid sixties F250. And only had to bolt it in. The front had to be narrowed to get the wheels inside the wells like I wanted. The guys who did the axle were able to mix and match parts to get it narrowed enough. So I didn't have to have custom axles made. In addition they were able to get disc brakes to fit too. Although I wasn't planning on having disc's they will be nice over the long run. One observation I will offer up is that it is a lot more work to do the 44, not even counting the narrowing. The 44 is so much beefier that it makes it hard to fit shocks and drag links in. (I have the pumpkin on the drivers side). Going with the early Bronco axle gives you lots more room to work in. And it sounds like you may not need to have the heavier axles to do what you want. I am using a SM 420 gear box with a divorced 204 transfer case. These two are the shortest units and as I'm putting it all under a short wheel base I wanted as much room as possible. But I should stop now before this becomes a build thread. If you want some more info on the project I have that will be nothing like yours PM me.
RIP Bob Parks.
Old 10-25-2016, 11:23 PM   #185
bajabob
bajabob's Avatar
Re: NAPCO Thread
c Terris
I might find some new corporate axles and use them rather than the older stuff and fab in the x-fer case you want. Maybe throw in some power steering and better final gear ratio ??? I wouldn't mind having better brakes on my old stuff but the new brake booster helpful in getting her hauled in...
ps
I still like the old stuff, she is tall....
Old 10-28-2016, 11:37 PM   #186
HO455
HO455's Avatar
Re: NAPCO Thread
Gorgeous Carryall!
http://eugene.craigslist.org/cto/5848163121.html
RIP Bob Parks.
Old 10-29-2016, 08:26 AM   #187
doo142
doo142's Avatar
Re: NAPCO Thread
My entry
72 Cheyenne k/20, Custom Camper
72 Cheyenne k/20
71 blazer K/5 2WD 454, 6 sp.
67 Chevy Napco c30 Dump
56 GMC Napco 4x4 short step
66 Chevy K10
68 Chevy C/30 4x4
doo142 is offline   Reply With Quote
Old 10-29-2016, 07:10 PM   #188
c Terris
Thanks guys, HO thats exactly what I was looking for. Truck is deffinately getting lifted. Weather or not there will be 4wd put in is still up for discussion. You said the rear bolted in do you happen to know if the axle was 60 "?
Old 10-29-2016, 07:38 PM   #189
c Terris
Re: NAPCO Thread
Two more questions ho455. Did you have to do any frame cutting or body chopping and also did you mean a divorced 205. The 204 didnt come up on the internet. Thanks again.
Old 10-29-2016, 08:15 PM   #190
c Terris
Re: NAPCO Thread
Also if anyone has any ideas for wiring harnesses I have another thread going.
http://67-72chevytrucks.com/vboard/s...=1#post7755549
Old 10-29-2016, 11:51 PM   #191
HO455
HO455's Avatar
Re: NAPCO Thread
Yes you are correct it is a 205. No frames or bodies have been cut, chopped or spindled. The whole goal started out to stay as 1950 as possible. I have used the stock (F-1 1/2 ton) springs and hangers but if I can locate a set of rebuildable F-2 or 3 rear spring hangers I would swap some 3/4 ton springs in the rear. The disks were added after I thought about how often I pull a trailer. Crappy photo of the dana 60 rear as installed.
RIP Bob Parks.
Old 10-30-2016, 12:35 AM   #192
HO455
HO455's Avatar
Re: NAPCO Thread
Dhoo! I just realized you asked if it was 60 inches not if it was a Dana 60. From where to where do you want it measured from?
RIP Bob Parks.
Old 10-30-2016, 10:45 AM   #193
c Terris
Between drum or disc and brake flange to the otherside. So from o.d. Of brake flange. I originally did say dana 60 it just happens I need a 60" axle too
Old 10-30-2016, 09:27 PM   #194
RANDY COX
RANDY COX's Avatar
Re: NAPCO Thread
OMG I'm in love this thing is absolutely gorgeous Wowza....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 10-30-2016, 10:42 PM   #195
c Terris
Ho455. I didn't even realize you posted that carryall is that your or did you just find it on craigslist.
Old 10-31-2016, 05:26 PM   #196
HO455
HO455's Avatar
Re: NAPCO Thread
Not mine. If it was it sure wouldn't be up for sale. Passed on a GMC back in 87 before they became valuable and I have been experiencing non-buyers remorse ever since, so now I just look at stuff I can't afford.
RIP Bob Parks.
Old 10-31-2016, 05:56 PM   #197
c Terris
Gotcha, i read the description and it says his friend put the napco kit in it ( its not original). I think I might ask him who his friend is. Bet it costs a pretty penny.
Old 10-31-2016, 06:00 PM   #198
c Terris
Old 10-31-2016, 06:19 PM   #199
c Terris
Re: NAPCO Thread
I tried uploading these pictures before, but it didn't seem to work. So I wouldn't be surprised if you see it up here multiple times. The 59 of course sporting primer gray and Rhino line black it has a 350 out of a 70's caprice and a 4spd. Then my 69 Gmc 2500 original paint 396 with a th350 36,000 original miles. Then in the background my dads car( he's the original owner of that one) Different engine now , but originally 396 with a 4 spd, now its something bigger made by Shafiroff Racing.
Old 11-01-2016, 06:39 AM   #200
Re: NAPCO Thread
Have you considered Jeep Wagoneer/Cherokee Chief/J10/Commando axles? They are narrower and later stuff is 6-lug
