Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-01-2017, 09:17 PM   #576
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Finished welding up the fuel door. Mocked up the filler neck and test fit the fill tube.
I will need to put the bed on the frame to be sure.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-01-2017, 09:23 PM   #577
First c10
First c10's Avatar
Worked on the passenger side of the bed. Not in good shape. It has body filler on most of the passenger side and the tail light area is bad. Pro ably going to try and find a good bed side or a repop. Anyone have one laying around??? Lol.
GO GO!!!
Old 01-02-2017, 11:19 AM   #578
7dee2
7dee2's Avatar
HOO! High Octane Only, YES!
Making good progress sir! I'm not a painter either and would definitely follow your guys advise with the dark Metallic? Pearl? color you guys have going on.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-02-2017, 12:45 PM   #579
First c10
First c10's Avatar
Custom labels!!! Truck would be nothing without them.
I am going to contact my body guy and have him look at it. 600$ for a bed side damn!!!
GO GO!!!
Old 01-02-2017, 08:36 PM   #580
swamp rat
swamp rat's Avatar
Gas door looks great! I see you shortened the filler tube, did you water test it?, don't want any leaks.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-03-2017, 11:06 AM   #581
7dee2
7dee2's Avatar
Don’t know how bad the rest of the bedside is but original stuff is supposed to fit way better (patch panels?).
If your painter is like my friends he’ll tell ya, the bigger the glob the better the job, then start laughing!
Brett
Old 01-05-2017, 03:49 PM   #582
First c10
First c10's Avatar
I agree Brett I will have him give me his opinion.
Attached are a few pictures he sent me. He said that I did a great job on the metal work. He said he didn't have to do much. Just a tap or two and a light skim coat.
A color change has also happened. The Tri-coat paint color I think was a little much.
What do you think?
Also I think we will be going with no side models just the front and tailgate areas.
GO GO!!!
Old 01-06-2017, 10:24 AM   #583
7dee2
7dee2's Avatar
Beauty! It'll look great w/o trim and probably easier to live with also.
Brett
Old 01-06-2017, 09:36 PM   #584
First c10
First c10's Avatar
Thanks Brett
I made a stop by my local wrecking yard. Found a 72 c20 Cheyenne lwb.
It was hit on the passenger side front. Bent the hood,pass fender, frame,etc
I was able to get the seat belts, ac vents, head liner and trim, visors, coat hook, brake master support brackets, and back of cab paint divider for $100.
Have a chance to get the wood bed which is in great shape with tail gate. It has a dent on the driver side front of tire. Nothing bad. Trim is even in great shape.
Worth 400$ ?
The picture you can see the bed is tweaked a little. It is all frame I think.
GO GO!!!
Old 01-09-2017, 11:14 AM   #585
7dee2
7dee2's Avatar
Score on your parts, looks like that was a pretty nice ¾ ton. Bed looks to be in great shape from your pics and a good price as well. Hopefully, nothing is hiding under that paint (especially the right side), I’d go for it, pull the trim, strip it and use the best parts making a real nice wood bed.
Brett
Old 01-12-2017, 01:30 AM   #586
First c10
First c10's Avatar
We have some color!!!
These are pictures of the cab from my body guy.
GO GO!!!
Old 01-12-2017, 01:47 AM   #587
First c10
First c10's Avatar
So after getting the pictures of the cab it lite a fire under me to get the fenders out and the grill assembly.
The fenders only have 1 dent in each. Not bad for 49 year old fenders.
The grill assembly I disassembled. Not to bad either. I chased the nuts that are welded to the fenders and grill and all were in great shape. Just a little wd40 and a thread chaser.
When the cab is ready we will be getting it on the frame to install and adjust the doors and mock up the rest of the sheetmetal.
So it looks like I am getting a wood floor bed pictured in a earlier post. So now I have to put the fuel filler in the taillight. I don't want to cut a hole in the side and floor.
GO GO!!!
Old 01-12-2017, 01:50 AM   #588
First c10
First c10's Avatar
The fender bottom closest to the door looks like it was cut with a hacksaw. Should I weld this up and maybe install the missing metal?
Or it in ok this way. The other fender looks about the same so I am not sure how much material was trimmed off.
Anyone know or have a picture?
GO GO!!!
Old 01-12-2017, 11:42 AM   #589
7dee2
7dee2's Avatar
Very nice progress! IMO I'm thinking that is close to how your fenders came from GM here's some pics of ours and they had not been cut.
Brett
Old 01-12-2017, 11:59 AM   #590
First c10
First c10's Avatar
Thanks Brett. your fenders look like they be the same. I thought maybe they should be like the attached picture.
GO GO!!!
Old 01-22-2017, 12:11 AM   #591
Nitis
Nitis's Avatar
saw this wasn't too far from you might be worth it
http://fresno.craigslist.org/pts/5955783591.html
Nitis is offline   Reply With Quote
Old 01-22-2017, 01:40 AM   #592
First c10
First c10's Avatar
Thank you Nitis. Great info. I have text him to see if he is interested in selling the passenger side if it is for a steel bed.
How is your truck coming along?
Update. They are sold already. Damn.
GO GO!!!
Old 01-24-2017, 07:26 PM   #593
First c10
First c10's Avatar
I thought "what the hell" and ordered a Hayden Transmission cooler. Its not a large one but something is better than nothing.
I made a bracket with standoffs and will mock up and powder coat at a later date.
now I will run the lines to the passenger side and drill a hole in the radiator support under the battery box.... like the A/C lines.
GO GO!!!
Old 01-25-2017, 12:14 AM   #594
First c10
First c10's Avatar
I got a call from the body shop. Cab is ready to be picked up and put on the frame.
So tonight I worked on getting the trans lines installed. I am using Russell powerflex. It is the same line they use for power steering lines.
I think it can handle more psi than the proflex line.
We will see.
GO GO!!!
Old 01-26-2017, 06:12 PM   #595
First c10
First c10's Avatar
I ordered a larger grommet to run the trans lines through the radiator support be here Tuesday so I can finish up the route of the lines.
I just need to put a clamp to secure the lines in the frame
GO GO!!!
Old 01-26-2017, 07:27 PM   #596
DWilbur
Trans cooler looks good. What lower radiator hose did you use. I having a hard time finding one that works.
DWilbur is offline   Reply With Quote
Old 01-28-2017, 11:12 AM   #597
7dee2
7dee2's Avatar
Very nice plumbing Scott, I would think the smaller new style high fin count cooler will do a really good job vs a radiator only cooler.
Brett
Old 01-28-2017, 11:44 AM   #598
First c10
First c10's Avatar
Hey David, the lower radiator hose I used on my sons 70 I found one that worked but will have to find the number for it as I need another one. Give me a little to find it.
Thanks for the compliments guys.
GO GO!!!
Old 01-28-2017, 11:45 AM   #599
First c10
First c10's Avatar
Brett, I figured what the heck cant hurt!!!!
GO GO!!!
Old 01-31-2017, 11:50 AM   #600
First c10
First c10's Avatar
David
I am going to pick up a Gates 20687. this is the number I have but not sure if it will fit this project. I will let you know
Update for the day.
I will be picking up the cab today if everything goes well today and I get off early enough...
GO GO!!!
