Old 03-21-2017, 05:22 PM   #1
Speedracer39
Speedracer39's Avatar
New rear leafs and flip kit
I have a 72 shortbed and have a DJM flip kit in hand and just ordered a set of new rear leaf springs. My current spring set up is 3 plus the overload the new ones I ordered are 4 plus overload my question is those that have already done this what spring configuration works best --leave the 4+1 or remove a leaf. I'm not going to haul anything just looking for a decent ride and looks. Thanks
Speedracer39 is offline   Reply With Quote
Old 03-21-2017, 06:33 PM   #2
Mike C
Mike C's Avatar
Re: New rear leafs and flip kit
My truck has the HD 4 leaf spring setup with the DJM flip. Effectively lowered the truck 7 1/4". I removed the overload because it was interfering with the CalTrac bars. I used stock length front shocks on the rear moved to the more vertical second position on the upper shock mount plate. I redrilled it and used the new front mounts that came with the shocks.
I am very pleased with this setup and would go this route again.
EDIT: I would NOT modify the leaf pack at all. I do not consider the overload to be part of the main pack so take it of if you need to.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-21-2017, 07:41 PM   #3
Speedracer39
Thanks for the info Mike C. I was also looking at the CalTrac bars online today. Still undecided I am planning on putting a Boyd tank in the rear and was hoping that would help on traction.
Old 03-21-2017, 08:18 PM   #4
KY_GMC
KY_GMC's Avatar
I would agree with Mike C.
I went from HD springs (7+1) to 4+1 flipped and it is a good ride.
Of course, I can't haul as much as I used to, but the ride is good.
I also moved the rear shock a more upright position. This picture does not show it. I figured that out after my build was complete. That made it ride better without hitting the frame as much. I didn't do a c-notch in the rear either.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 03-21-2017, 08:25 PM   #5
Speedracer39
Attachment 1634595
Attachment 1634596
Wow --- That was a stack of springs you had-
Old 03-21-2017, 09:06 PM   #6
KY_GMC
KY_GMC's Avatar
Yeah, I had close to 1 ton of stuff that I took to the scrap yard one time! And the truck is only a half ton! Definitely had to plan on braking sooner than later.
When I bought it in '96, it had 35" tractor tires on it and it would go anywhere,
Build Thread
Engine Thread
Old 03-21-2017, 09:58 PM   #7
volksworld
if you do decide to remove a leaf, take out a long one...due to leverage they act as softer springs...the short ones are the stiffest and are the ones that prevent spring wrap up and wheel hop...dont ask how i found this out...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
