700r4 swap
I've got a 68 c10 long bed with a 350 and th400 transmission, and I want to swap in a 700r4. what all needs to be done to do this swap? I've never done anything like this before so any advice is appreciated. thanks!
#2 | |
The Older Generation
Re: 700r4 swap
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266 LockDoc
Re: 700r4 swap
I just did a 700 r4 swap. The link posted is very good info from my experience save yourself a lot of headaches and get the bowtie overdrives tv cable system. It's $150 for the kit but worth every penny.
Re: 700r4 swap
The original sun shells are weak. If it needs a rebuild I would recommend doing a little research on upgrades. You don't need to build a race tranny, but a couple things to improve durability and reliability.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 700r4 swap
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6 | |
Re: 700r4 swap
I also used and recommend the BowTie Overdrives kit.... LockDoc
Re: 700r4 swap
okay sounds like I'm gonna need that bowtie kit. anything else I should get? and if anyone else has done this swap was it worth it? I mostly just want to be able to cruise at 65 or 70 more comfortably.
![]() ![]() Join Date: Sep 2008
Re: 700r4 swap
What they said.
Is it worth it? Yes. We have done a bunch of these behind big blocks and small blocks. Now I can drive my big block Longhorn on the Interstate at 70 comfortably.
Moderator
![]() Join Date: Jul 2006
Re: 700r4 swap
I have done quite a few 700R4 swaps, even have one behind a healthy 5.3L. Regardless of what linkage system you use, make sure that before you drive the truck you use a pressure gauge to confirm the set-up. There is a 1/8 NPT port on the driver's side, easy access. I have added to another thread or two around here that has the charts of pressures in park, neutral, forward gears and reverse. Basically you want to make sure that when the throttle moves, line pressure is instant. You will want a couple of psi at idle. Where people go wrong is setting up by feel, and they don't realize that line pressure isn't raising until part throttle, or is too high at idle etc...burns em up.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Re: 700r4 swap
Yes it's worth the swap. I'm running 4.56 gears and at 2000 rpms at 55. Very fun to drive with this setup.
#11 | |
Re: 700r4 swap
#12 | |
Re: 700r4 swap
this the board I need to read? |
Re: 700r4 swap
okay reading through that first link on the overview of the swap, he talks about going to a one piece drive shaft... is that something I should do or can I stay at 2 piece?
Re: 700r4 swap
No right or wrong here, but I stayed with the 2 piece in my longhorn.
You could possibly eliminate some vibration with a 1 piece.
#15 | |
Re: 700r4 swap
With the long bed I would stick with the 2 piece shaft.... Just my 2¢ worth. LockDoc
#16 |
Re: 700r4 swap
⬆⬆⬆I agree
#17 | |
Moderator
Re: 700r4 swap
#18 |
Re: 700r4 swap
okay cool, keeping my driveshaft will save me some cash too. okay one last question. how do I wire the torque converter lock up?
#19 |
Re: 700r4 swap
Give the guys at Bowtie a call. They will set you up with everything. Not exactly cheap but the best way to go. I believe you will also have to get your front drive shaft shortened.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
