Old 07-26-2017, 10:26 AM   #576
chtr65
Re: 60-66 Tire/Wheel Pics
jac70ss You have an absolutely gorgeous truck. Any chance you would be willing to give out the information on what you did to get it to that ride height. I have a very nice stock short bed fleet side big window cab truck with the stock suspension. I have been thinking about bringing her down a bit. Thanks in advance
chtr65 is offline   Reply With Quote
Old 07-26-2017, 03:19 PM   #577
jac70ss
No problem. As stated earlier, it is a 5 lug conversion. 2.5 drop spindle with one coil cut out of old front springs, frt sway bar out of a later 70's model truck. The rear has a 5 inch drop spring, 1 inch lowering block, relocated spring perches and adjustable sway bar. (I may lower the rear one more inch).
jac70ss is offline   Reply With Quote
Old 12-30-2017, 06:33 PM   #578
ol_skool_chevy
ol_skool_chevy's Avatar
285-70-15 rear
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-04-2018, 11:47 AM   #579
Dhaak64
Originally Posted by rvrfoot View Post
What’s the specs on those? Rim size and tire size? They look good on your truck.
Dhaak64 is offline   Reply With Quote
Old 02-04-2018, 11:53 AM   #580
The Rocknrod
Moderator
The Rocknrod's Avatar
Also lots of good information on the many pages of the static drop thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=507575
Old 02-04-2018, 11:57 AM   #581
rvrfoot
18 inch rims. The front tire is a 235 50 18. The rear is 255 55 18.
rvrfoot is offline   Reply With Quote
Old 02-04-2018, 12:05 PM   #582
Dhaak64
Thank you, I’m in the process of getting tires for my new 18 inch wheels, and needed a reference. I like what you’ve done with your truck, it’s looking good!
Old 02-04-2018, 12:53 PM   #583
rvrfoot
Thanks, The truck is going up for sale.
Old 02-06-2018, 12:03 AM   #584
cwcarpenter98
cwcarpenter98's Avatar
255/70r15 on 15x8 truck rallies
The two slots are 15x7 Western Wheel. Once I find another pair of the slots, I'll run those, but finding two more is my problem.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-08-2018, 11:31 PM   #585
Cris
Just installed today! 275/55-17 tires on a 17x9" wheel with 4.75" back space. The truck is dropped 4.25" in front and 6" in the rear. I was surprised to see how well everything fit. No rubbing issues so far with good (adequate) clearances. I'll post if I have a problem with rubbing while turning AND hitting a bump. But so far so good.
Cris is offline   Reply With Quote
Old 02-08-2018, 11:50 PM   #586
mfm3
Active Member
Cris - nice job maxing out the wheel/tire fitment. Looks great...respect!
mfm3 is offline   Reply With Quote
Old 02-09-2018, 12:07 AM   #587
rvrfoot
What color green is that? I like it i was going for something like that but maybe a few shads lighter.
Old 02-09-2018, 01:59 PM   #588
Cris
mfm3, thanks for the props. I was pleasantly surprised at how well these tires squeezed in there.
rvfoot, I believe that is Glenwood Green. The truck was painted by a PO, but that color matches the firewall color (unpainted) very closely. As you suggested, it is maybe a tad darker.
Old 03-20-2018, 09:08 AM   #589
Burb66
The 15s that came on the burb
Burb66 is offline   Reply With Quote
Old 03-20-2018, 11:15 PM   #590
Captainfab
60-66 Nut
What is the width and tire size?
Old 06-22-2018, 08:39 PM   #591
Philipschttr
Philipschttr's Avatar
Do you know your backspace or offset?
Philipschttr is offline   Reply With Quote
Old 06-23-2018, 06:16 AM   #592
Shaky
Six in a row makes it go...
Shaky's Avatar
Too big?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-23-2018, 11:15 AM   #593
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by Shaky View Post
Too big?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-23-2018, 03:27 PM   #594
cru_zn_29
cru_zn_29's Avatar
I think the left side tires need a little air.
cru_zn_29 is offline   Reply With Quote
Old 02-23-2019, 01:11 PM   #595
Cohi
Cohi's Avatar
20 rear, 18 front. truck under construction..
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is offline   Reply With Quote
Old 02-23-2019, 03:23 PM   #596
cwcarpenter98
Same wheels as before, but found a set of center caps and trim rings
Christian Carpenter
Old 02-23-2019, 09:31 PM   #597
62chevy302
hillbilly
62chevy302's Avatar
I have 6 inches to my inner fenders. If I figure 1/2" for the lip of the rim and 1" for tire clearance I would need a 4 1/2" backspacing. Im looking for a 9.5 or 10 inch rear wheel. All the backspacing is 5.5 or above. What are you guys doing with the 10 inch wheels? Spacers?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 02-23-2019, 10:27 PM   #598
DLW
I did custom 4.5" backspacing for my 10" wide wheel as there are not many off the shelf wheels that come in 4.5" BS.
It will be very close to the inside fender lip, I did some trimming there just get a bit more clearance. 9.5" wide wheel would work well.
DLW is offline   Reply With Quote
Old 02-24-2019, 08:27 PM   #599
62chevy302
hillbilly
62chevy302's Avatar
Even with a 9.5" wheel I am going to have to buy a wheel with 4.5" of back spacing or use 1" spacers in the rear.
-1962 C-10
Old 02-24-2019, 09:43 PM   #600
DLW
Yes, I was not trying to imply you would not. As I was saying a 9.5" wheel will give a bit more room from the fender lip over the 10" wide wheel where it was pretty close (for me) with my 4.5" BS 10" wheel.
