Old 08-04-2017, 06:03 AM   #1
ShortCST
ShortCST's Avatar
Simple Trick To Gain 100hp+ For Less Than $200
How about changing your plugs and plug wires more than once every 7 or 8 years? This is cylinder #4, the worst of the bunch by far.
In my (very weak) defense, the headers really take a lot of the fun out of changing the plugs. Pretty much everything else gets regular attention.
ShortCST is offline   Reply With Quote
Old 08-04-2017, 07:55 AM   #2
Shinysideup
Shinysideup's Avatar
Re: Simple Trick To Gain 100hp+ For Less Than $200
Did you mean for less than $20?
I see a tired engine.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 08-04-2017, 08:06 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
I don't think changing the plug on cylinder #4 will make a lot of difference, I agree with Shinysideup, that looks like a plug out of a tired engine. Spark plugs do wear, and therefore need replaced every so often, but they should not look like that.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-04-2017, 08:11 AM   #4
ShortCST
ShortCST's Avatar
The truck sat parked for over a year while I came up with the funds to get her back on the street.
It feels more powerful now than it ever has since I owned it. A cam swap that I was considering doesn't even seem necessary now.
Also, the plug wire going to that cylinder was hidden from view, and when I pulled it out, it was taped in the middle with electrical tape. Didn't unwrap it to see what was hidden.
Old 08-04-2017, 08:17 AM   #5
70STOVEBOLT
That would explain the way it looks if it was not firing properly from a bad wire. It's always a very pleasant surprise when you do a simple thing like a tune up that makes such a big difference. I saw your other thread about the drop springs, nice looking truck.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-04-2017, 08:38 AM   #6
hewittca
hewittca's Avatar
My truck went through similar maintenance a few months ago and it really livened it up and made the engine run smoother. I was ready to toss this 307 anchor overboard before I tuned it up, but it runs well enough now that I think I will hang on to it for a while.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 08-04-2017, 09:18 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Best thing I ever did was ditch headers and go back to stock manifolds. Easy to change plugs, zero exhaust leaks, no more burnt plug wires, able to install factory AC brackets. I'm driving a pickup truck, not a race car and there are way more advantages for me this way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-04-2017, 09:39 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have installed headers on every single rig I have ever owned. No probs for me.
When plugs are oil fouled... it's time to look at rings and/or valve guides and seals.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-04-2017, 11:49 AM   #9
demian5
demian5's Avatar
Cause it needs possible rings and guides...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-04-2017, 12:02 PM   #10
Killer Bee
Killer Bee's Avatar
every self respecting chevy engine burns a little oil.... but dang..
might want to run a compression check for top and bottom wear and proceed cautiously before demanding too much from it..
best time to do this while replacing sparking bolts
good luck!
Old 08-04-2017, 12:30 PM   #11
bill3rail
bill3rail's Avatar
Gary
I on the other hand do NOT install headers but your next statement is dead on! Check the cylinder/rings and valve guides/seals.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-04-2017, 12:45 PM   #12
randy500
Gary
I have taken headers off every single rig I bought that had them, I hate exhaust leaks...
randy500 is offline   Reply With Quote
Old 08-04-2017, 02:11 PM   #13
ShortCST
ShortCST's Avatar
I know that it looks like oil. But it wasn't viscous. It positively reeked of gas as soon as I pulled it out. The smell of fuel from the exhaust was dizzying. A couple of the other plugs were fouled. This one was wet.
I'll definitely perform the compression test, just to be on the safe side.
Old 08-04-2017, 02:17 PM   #14
ShortCST
ShortCST's Avatar
Randy, I have a set of Doug Thorley Tri-Y pieces, and they've never given me a problem. They've got really thick flanges.
Old 08-04-2017, 03:27 PM   #15
70STOVEBOLT
It is running extremely rich then. I would bet there is gas in your oil as well. Since you are replacing plugs/wires, maybe a carb rebuild is in order as well. At the very least, a carb adjustment should be made, along with a a check and/or adjustment of the timing and an oil change. If it's been running that rich for a long time, it could "wash down" the cylinders and cause excessive wear on the cylinder walls and piston rings. That would be an extreme case, but it is possible.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-04-2017, 04:05 PM   #16
ShortCST
ShortCST's Avatar
Stovebolt, it doesn't smell like gas since I replaced the plugs and wires, but the idle speed is a bit fast (around 1k rpm). I wonder if the last time that I brought it in for a tune, if they just advanced the timing to try to burn more fuel, without pulling all of the plugs for inspection.
Should I still rebuild the carb? It's an Edelbrock 1406. I have no qualms, I'm just excited to drive it now that it's running so well. Hate to start the Fedex clock all over again.
Old 08-04-2017, 04:13 PM   #17
leddzepp
Moderator
leddzepp's Avatar
If it is running well and you are happy leave it alone and enjoy driving it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-04-2017, 04:25 PM   #18
70STOVEBOLT
^^What Scott said.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-04-2017, 04:35 PM   #19
AnotherWs6
AnotherWs6's Avatar
Just adjust the idle screws, there are two on the front of your carb, easy peezy.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 08-04-2017, 07:24 PM   #20
ShortCST
ShortCST's Avatar
Thanks for the tip! My pickup definitely isn't burning oil or smoking at all, doesn't smell like gas anymore, and is certainly now producing power close to its factory rating ('67 L79. 325hp), which it hasn't done in the past 10 years.
I do want to fix the idle speed, though. Today. Mostly just to wring as many miles per gallon out of the 327.
Two related questions, and I'll be out of everyone's hair:
1. Does idle speed affect mpg much? Both city and highway, or just in stop and go?
2. Are the idle screws the only/best place to turn the engine speed down a notch, or does the ignition timing change that as well, and how do I know which to change, without an exhaust gas analyzer?
Old 08-04-2017, 09:25 PM   #21
'68OrangeSunshine
'68OrangeSunshine's Avatar
1] Yeah. Sort of. You will be burning more gas waiting for the light to change running 900 RPM than 650 RPM. On the highway, you won't be idling much, unless coasting down hills, so it's not so much a factor.
2] Back in the day -- when we just clubbed and skinned a dinosaur for its gas rather than squeezing its juice from the pump, long before EGAs, A/F meters or OBDs -- we used a device called a 'vacuum gauge'. It's T-ed into the vacuum line from the distrubutor to the carb and reads in Inches of Mercury [X''Hg] . When adjusting the carb set screws, you want the highest number reading on each screw. For my 292 L6, 17-18''Hg is nominal. Easy analog gauge to work with, not hard to find, doubles as fuel pressure meter too, in some applications. Not expensive either. Also an in-dash Vacuum Gauge can indicate best gas-mileage while running, decelleration, bad valves, sticky valves, poor compression, etc. And just looks cool being there.
Big trucks have them as standard.
Tachometer is also handy tune up tool. If you have points, you need a Dwell Meter, too. They used to sell Dwell/Tach/Voltmeters.
Yes, timing affects engine speed.
Old 08-04-2017, 11:13 PM   #22
ShortCST
ShortCST's Avatar
So, after just having come back from a drive, I realized that:
The truck idles at 750 rpm in Drive when warm.
It idles at 1000 in Park or Neutral when warm. Even if I stab the throttle. Settles back down at 1000.
Sorry for the sophomoric questions. Do the above numbers sound right?
Old 08-05-2017, 12:02 AM   #23
'68OrangeSunshine
I'll pass on auto tranny questions. Purely a Stick Man.
They used to tell us in the military: "The only dumb questions, are the ones you don't ask.''
Old 08-05-2017, 12:27 AM   #24
ShortCST
ShortCST's Avatar
So it's a tranny issue, you say? My first clue!
Old 08-05-2017, 10:22 AM   #25
rcazwillis
Not sure you are looking at a tranny issue. Idling at a 1000 and putting it into gear will pull the engine down a bit. Get it idling at 750-800 in park, then make sure it stays running in gear. All good at that point. If you put it in gear and it dies, give it a bit more idle speed.
rcazwillis is offline   Reply With Quote
