Old 08-22-2017, 09:52 PM   #1
68_-c\10
68_-c\10's Avatar
Horn Button Issue
I'm working on a 1950 Chevrolet 3100 for a friend. It's been converted to a 12 volt so I know I need a relay and a 12 volt capable horn. I pulled the center cap off of the steering wheel and found that the horn contact was depressed due to the tightening of the steering wheel nut. Am I missing a part? What do I need to do to correct this?
Thanks in advance.
68_-c\10 is offline   Reply With Quote
Old 08-22-2017, 10:07 PM   #2
mr48chev
mr48chev's Avatar
Re: Horn Button Issue
I'd have to go out and take the horn apart on the wheel in the 51 cab I have sitting out in the yard and take photos just to figure it out. I've had them apart and back together plenty of times but forget how they actually work.
I am pretty sure that the horn button grounds the circuit in the horn relay and that triggers the horn.
My ongoing truck projects:
Old 08-22-2017, 10:17 PM   #3
68_-c\10
68_-c\10's Avatar
That would be great if you have time. I uploaded pictures just now on my post, hopefully that helps
Old 08-23-2017, 09:27 AM   #4
joedoh
joedoh's Avatar
edit 2:
no I go back to what I said before, haha sorry for the multiple edits. the nut goes under that piece and you need a second attachment for that second piece.
Old 08-23-2017, 11:11 AM   #5
68_-c\10
68_-c\10's Avatar
So I need another nut or some piece for the horn??
Old 08-23-2017, 11:57 AM   #6
joedoh
joedoh's Avatar
it occured to me that I have a 49 cab in the back yard.
IMG_6842 by Joe Doh, on Flickr
so I went and tried the operation,. it looks to me that the only way you can compress the horn plate so its on all the time is to either not have enough travel on the brass contact that is seen sticking up, or the hole in your horn back plate isnt big enough and that back plate is pushing up to the front plate.
Old 08-24-2017, 10:52 PM   #7
68_-c\10
68_-c\10's Avatar
Still searching for an answer on what part I need. Any more help would be appreciated
Old 08-25-2017, 01:16 AM   #8
joedoh
joedoh's Avatar
did you check that brass button? does it push down? it should be spring loaded.
it also looks like your steering wheel isnt seated all the way down but that shouldnt affect anything except if the brass button doesnt push down.
