Old 10-09-2017, 05:13 PM   #1
abohler1
abohler1's Avatar
Can't measure rear end pre load, options?
I replaced the pinion oil seal in my rear end and the marks I made to put the nut back on did not hold up. I don't have the ability to take even more apart and measure pre-load. What are my options to get the yoke back on and be in a safe delta to not ruin my rear end?
GM Handbook just says basically, replace seal, and torque nut back down to 270lb ft. No mention of measuring pre load or anything. Wondering if that is my only option at this point. Thoughts? Thanks.
abohler1 is offline   Reply With Quote
Old 10-09-2017, 05:34 PM   #2
B. W.
B. W.'s Avatar
Re: Can't measure rear end pre load, options?
Torque to 270 lb/ft.
I've changed more than I can remember, I usually do not torque the nut, I just tighten it down pretty darn tight. (No, that is not the correct way but it works)
B. W. is offline   Reply With Quote
Old 10-09-2017, 06:07 PM   #3
kwmech
My first question would be is what rear axle you are working on?
Old 10-09-2017, 09:02 PM   #4
Mike C
Mike C's Avatar
I second kwmech. A 12 bolt won't specify torque on the nut because of the crush sleeve. A Dana will and I would assume an Eaton too.
But just use a 1/2" ratchet and tighten it as tight as you can get it. I HIGHLY recommend using a new pinion nut.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-10-2017, 09:00 AM   #5
abohler1
abohler1's Avatar
It's a 12 bolt rear. The handbook doesn't get into which rear end the pinion seal change applies to. Just mentions the torque spec for the nut. Quite vague in my opinion.
Old 10-10-2017, 09:01 AM   #6
abohler1
abohler1's Avatar
My fear in the job was around the crush sleeve. Wanted to get everything tight enough to be safe, without over crushing the sleeve.
Should I get the nut going with an impact and follow with a torque wrench or breaker bar? I know some guys just eyeball with an impact.
Old 10-10-2017, 09:54 AM   #7
B. W.
B. W.'s Avatar
The important point is to NOT collapse the crush sleeve any more (changing pre-load). Tighten until no play & then tighten a little more ( i would go no where near 270 ft lbs)
It takes a lot of torque to crush a sleeve when it is new (i'm talking a BIG cheater bar!) but not so much after is has been "crushed". I hammer the nut on with an impact to approx 130 ft lbs. & call it good. ( apply non-hardening sealant to the splines & loctite to the threads)
Before you remove the nut (too late now) you can measure overall turning torque at the pinion (this includes carrier pre-load & seal drag, etc). this gives you a target to aim for upon re-assembly & you don't have to gut the diff to measure just pinion pre-load. IMO, this is more accurate than marking the nut.
Old 10-10-2017, 10:15 AM   #8
RustyBucket
RustyBucket's Avatar
Be careful with an impact wrench.... just bought a new cheapie Harbor Fright "EARTHQUAKE" model. They claim it's got 800ft.lb. of torque... maybe they've got little feet in China.
That being said I've replaced 2 pinion seals in a lifetime(one 12bolt car & one 12bolt truck) and was always concerned about too tight. Think I didn't get 'em tight enough because I eventually had noisy pinion bearings in both.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 10-10-2017, 10:29 AM   #9
Bigdav160
Bigdav160's Avatar
It's a self locking nut so it's going to hard to turn. However, when contact between the bearing and crush sleeve is made it takes considerably more torque to turn the nut (it's trying to crush the sleeve). STOP!!!
That's the point which you removed the nut.
Like mentioned, other axles use shims instead of crush sleeves to set the bearing preload so the pinion nut is just torqued in place.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-10-2017, 08:49 PM   #10
Mike C
Mike C's Avatar
Get a new nut and tighten it as tight as you can with the 1/2" ratchet. That should be fine and not crush the sleeve any further.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-13-2017, 08:52 PM   #11
abohler1
abohler1's Avatar
Thanks for all the advice. I tightened up the nut until there was no play, and then lined up the paint marks left behind on the nut and pinion. Worst case, I was off by one full turn of the nut. But it seems like I'm dead on. Took the truck for a spin, no leaks, no vibration. Appreciate all the help.
Old 10-13-2017, 09:13 PM   #12
Mike C
Mike C's Avatar
Just be wary that a used nut won't "lock" quite as well as a new one and they are known to work their way loose. Should be good to go now, just check the nut occasionally.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-14-2017, 11:32 PM   #13
abohler1
abohler1's Avatar
Will do. I couldn't find anywhere with a new nut, so threw a good amount of blue loctite. Hoping that will help. Going to take some short trips and make sure everything is holding up still.
differential, pinion, rear end, seal, yoke
