Old 02-16-2018, 05:04 AM   #1
61ChevyPanel
Active Member
61ChevyPanel's Avatar
Difference between 60-62 and 63-66 rear suspension
I like the QA1 setup for 63-66 trucks I saw at SEMA. Anyone know what I'd have to do to make it work in my '61?
61ChevyPanel is offline   Reply With Quote
Old 02-16-2018, 07:35 AM   #2
PGSigns
PGSigns's Avatar
Re: Difference between 60-62 and 63-66 rear suspension
The shape of the frame is the thing you will be fighting. Look in the FAQ section for the frame drawings and that will give you an idea on the differances.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-16-2018, 01:14 PM   #3
LVPhotos
LVPhotos's Avatar
Pic? I moved my shocks with Porterbuilt stuff.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-16-2018, 02:34 PM   #4
Clyde65
Clyde65's Avatar
Lvphotos, is the truck in your pix a 60-62 or 63-66??
Never mind! I see your signature.
Thnx
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is online now   Reply With Quote
Old 02-16-2018, 02:58 PM   #5
LVPhotos
LVPhotos's Avatar
It is a true '62 short bed. Porterbuilt was first to have something for this frame. They do have the notches for this frame. I was not planing on it being this low... the pipe notch I made is useless with my shocks, 2" too long
The big issue is the pumpkin hitting wood. In my case 2 pieces in center that are not attached for opening at shows
Old 02-16-2018, 04:35 PM   #6
Clyde65
Clyde65's Avatar
Are those PB cups and trailing arms??
Clyde65
Rebuild of Clyde
support our troops!
Old 02-16-2018, 07:03 PM   #7
LVPhotos
LVPhotos's Avatar
Pb arms but Air Ride before Ride Tech "cups" with top plate because 62 cover smaller than cup.
Old 02-16-2018, 07:06 PM   #8
LVPhotos
LVPhotos's Avatar
Boxed to pb
Old 02-16-2018, 07:08 PM   #9
LVPhotos
LVPhotos's Avatar
For the notch... 5" pipe 1/4" cut to 2"
Old 02-21-2018, 12:26 AM   #10
61ChevyPanel
Active Member
Thanks LV. I don't want to cut my floor up so mine won't be as low. Photo shows QA1 parts.
Old 02-26-2018, 08:30 PM   #11
rvrfoot
If you get this set up. Show pictures so he all can see.
rvrfoot is offline   Reply With Quote
