Old 03-19-2018, 04:36 PM   #1
Andrevw111
...are my wheels too far in?
Hi,
Could somebody please tell me roughly what the correct measurement is for the distance that the original standard 15" rim sits inside the front guard? ie from the outside of the wheel arch to the outside of the steel rim..
I had 15" rally wheels - and wanted to change back to the originals so got some from a dismantlers - however when I put them on they look WAY to far in like they've got a much different offset..?
Andrevw111 is offline   Reply With Quote
Old 03-19-2018, 04:56 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: ...are my wheels too far in?
Back spacing might be different and your rally's might be wider.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-19-2018, 05:48 PM   #3
VictoriaHardware
VictoriaHardware's Avatar
Original 1965 15" diameter wheels were 5.5" wide with 3.75" backspacing.
VictoriaHardware is offline   Reply With Quote
Old 03-19-2018, 06:53 PM   #4
Andrevw111
Thanks for that, yes I just checked, these ones are 15" diameter, 5.5" wide, and with a backspace of 3.75"
Maybe they're sitting correctly, and I'm just used to seeing the wider rally's..
I thought perhaps the hubs may have been changed at some point!
I would be interested to know if someone could give me their measurement as in the photo though..
Thanks,
Old 03-20-2018, 06:48 AM   #5
PGSigns
PGSigns's Avatar
The wheel will move up and out as you get the truck on the ground. The tire will also fill a good bit of the gap. It will be fine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-20-2018, 02:30 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Jimmy
Good point.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-20-2018, 10:08 PM   #7
Andrevw111
You're right, thanks for that Jimmy. It was the back wheels where I first noticed it though which wont shift out - but possibly because I didn't have tyres on and I'm used to seeing the other wheels.
Cheers,
Old 03-20-2018, 10:56 PM   #8
Nevada51
I reckon you're just used to the wider wheels. Originals do tuck in further like that.
You did well to get a set of original wheels in NZ!
Cam
Nevada51 is offline   Reply With Quote
Old 03-21-2018, 01:10 AM   #9
Andrevw111
I couldn't find them in NZ... got them shipped in from a wreckers in the US.. probably the most expensive 15" steelies in NZ now! 😣
But it's the style I like so will be worth it... I hope!
Old 03-21-2018, 12:23 PM   #10
theastronaut
theastronaut's Avatar
The original wheels are tucked in pretty far. Even with a little bit of width added from the disc brake kit, I spaced my front wheels out 1.5" to fill out the fender opening better.
theastronaut is offline   Reply With Quote
