Old 03-30-2018, 09:27 PM   #101
7D2N
7D2N's Avatar
Re: My winter project
Cleaning up the heavy things. I picked up energy suspension trans case mounts and need to get seals for the trans and and case.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 03-30-2018, 10:14 PM   #102
Harold Holbrook
Thanks for the great post, I am just starting my 71 blazer.
Harold Holbrook is offline   Reply With Quote
Old 04-01-2018, 09:37 PM   #103
7D2N
7D2N's Avatar
Jr. post some pictures I would like to see your blazer, starting is the best part and the things I have learned here has helped me a ton. Many people willing to share knowledge.
7D2N
Old 04-01-2018, 10:33 PM   #104
7D2N
7D2N's Avatar
I found out that truck bed liner will come off the the hatch with a little heat, prying and pulling but fairly easy to remove. I was also surprised the hatch was in pretty good shape.
Old 04-03-2018, 10:06 PM   #105
prorat56
prorat56's Avatar
WOW that's crazy
72 Chevy K5 CST
prorat56 is offline   Reply With Quote
Old 04-06-2018, 04:13 PM   #106
maldo
maldo's Avatar
Your project is really coming along and looks great. Keep up the good work,
maldo is offline   Reply With Quote
Old 04-08-2018, 08:54 PM   #107
7D2N
7D2N's Avatar
Thanks maldo, its slower than I would like but I'm having a great time figuring it out.
7D2N
Old 06-28-2018, 10:07 PM   #108
7D2N
7D2N's Avatar
Well after rolling around on my back scraping, grinding, and sanding the underside of the tub and frame it's time to paint. I used a roll-on satin black on the underside of the tub and can spray the frame. Trans and transfer case ready to go back in.
Old 07-09-2018, 09:24 PM   #109
7D2N
7D2N's Avatar
Painted under side of the tub and frame, for a driver truck what do you think white or black firewall?
Old 07-09-2018, 09:39 PM   #110
7D2N
7D2N's Avatar
Moving to engine stuff, looks pretty clean inside but a previous rebuild had the cam break in fail. Need to get to the machine shop.
Old 07-09-2018, 10:15 PM   #111
simicrintz
If it's any help....
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 07-12-2018, 07:33 PM   #112
7D2N
7D2N's Avatar
Yes it does thanks and very nice, any reason you didn't paint the under side of the hood white?
7D2N
Old 07-12-2018, 09:42 PM   #113
simicrintz
Thank you, and glad it helped. No particular reason that I recall, but I think would look nice as well.
-Bruce
1971 K5 Blazer 4WD
Old 08-14-2018, 09:57 PM   #114
7D2N
7D2N's Avatar
The engine went to the machine shop and had a few things done will have it this week. New home is ready.
Old 08-15-2018, 05:05 PM   #115
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Wow... you’ve made a lot of progress since I saw you last!
Tom Vogel is offline   Reply With Quote
Old 08-16-2018, 10:14 AM   #116
wthompson
Looks good like the process.
wthompson is offline   Reply With Quote
Old 08-16-2018, 10:52 AM   #117
simicrintz
So you decided on the white firewall; looks good!
-Bruce
1971 K5 Blazer 4WD
Old 08-16-2018, 09:25 PM   #118
7D2N
7D2N's Avatar
Thanks guys, I know it's a yawning build and nothing like some of the members have done but I'll keep playing.
Old 08-18-2018, 08:44 PM   #119
7D2N
7D2N's Avatar
I have the engine back from the machine shop and will to start cleaning the outside stuff for some paint. I did stumble on this steering wheel and shiftier to replace the custom wheel and late model shiftier that I have now.
Old 08-28-2018, 11:14 PM   #120
7D2N
7D2N's Avatar
Starting to put these back where they go. I'll clean the outside engine for some paint and I'll be ready for the next move.
Old 09-18-2018, 11:08 PM   #121
7D2N
7D2N's Avatar
I've started some motor assembly and have a question, the exhaust manifold is very close to the starter and previous exhaust shop made it work by sizing the pipe to fit around the starter, should I change to different manifold before I break in.
Thanks 7D2N
Old 09-18-2018, 11:56 PM   #122
JackB
Thanks 7D2N
Your Blazer would have come with straight dump manifolds. I believe the correct casting for 1972 is 3989036
JackB is offline   Reply With Quote
Old 09-19-2018, 09:36 PM   #123
7D2N
7D2N's Avatar
Thanks Jack B, the engine is not original to the blazer but 1970 block. I'll look for some straight down type.
thanks again, 7D2N
Old 10-03-2018, 10:49 PM   #124
7D2N
7D2N's Avatar
Engine is painted and on the run stand, cleaning up misc brackets and stuff. I'll need a few little things then I can start it up.
Old 10-09-2018, 10:37 PM   #125
7D2N
7D2N's Avatar
I could use some help or info if I may. I have my motor on the run stand and plan to start soon, question is should I fill the trans and transfer case with fluids until I put the engine in?
7D2N
