Old 04-03-2018, 03:25 AM   #1
Cheyenne73
Cheyenne73's Avatar
4wd conversion?
Anyone tackled a 4wd conversion??
Cheyenne73 is offline   Reply With Quote
Old 04-03-2018, 06:08 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: 4wd conversion?
Lots of people here have. You have to be more specific
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-03-2018, 07:10 AM   #3
sweetk30
sweetk30's Avatar
Re: 4wd conversion?
here is my build right now. http://67-72chevytrucks.com/vboard/s...d.php?t=755514
its fairly easy to do if you have the parts and time.
also there is a few ways to do it . but best way if you ask me is 4x4 frame swap .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-03-2018, 07:19 AM   #4
Bandit130
Bandit130's Avatar
Re: 4wd conversion?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 04-03-2018, 07:02 PM   #5
pointbreak
pointbreak's Avatar
Re: 4wd conversion?
I've been thinking about it. From the research I've done and the advice from around here. The best plan of attach seems to be find a 4x4 chassis that fits your needs. That being said I'm wondering if anyone knows what frames I may be able to stuff under a 3x3 2wd from 84. I got my eye on one for cheap haha.
Acknowledge and move on
1976 Chevy Silverado 454BBC
1966 Chevy Impala 4 Door Hardtop
pointbreak is offline   Reply With Quote
Old 04-03-2018, 08:28 PM   #6
sweetk30
sweetk30's Avatar
Re: 4wd conversion?
you need a 4wd version of the 2wd truck you have .
i just cut a crew cab 4wd frame down to a std cab frame spec and welded it up .
Old 04-03-2018, 09:14 PM   #7
pointbreak
pointbreak's Avatar
Re: 4wd conversion?
That'd be the easiest. Unfortunately 4x4 crew cab frames are tuff to find where I am. Decent ones anyways. Might have to get creative haha
Anyways I've heard of guy converting a 2wd frame to 4x4 but that seems like waaaay more hassle than it's worth
Old 04-03-2018, 11:12 PM   #8
rideair
Re: 4wd conversion?
I would think you could take a 3/4 ton 4x4 Suburban, cut the frame behind the second seat (but before the rear wheels) add metal and you're done.
Here's a picture of my 3+3 when I took the bed off. I'll look at my 1988 Suburban (putting in a new trans) this weekend to see if it's the same just shorter. I looked on the web, and the images look very close.
rideair is offline   Reply With Quote
Old 04-23-2018, 04:49 PM   #9
NastyBuzzard
NastyBuzzard's Avatar
Re: 4wd conversion?
I have actually designed a kit for 1 tons and crew cabs. However, I gotta say it is definitely easier to just do a body swap if you can find a good frame.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 04-23-2018, 07:29 PM   #10
franken
Re: 4wd conversion?
Short answer: Buy a 4x4 unless you like misery.
Get one w/ the trans you want and an NP205. 203 and 208 not so good.
Old 04-24-2018, 12:19 AM   #11
kwmech
Re: 4wd conversion?
I've done at least a dozen over the years both 67-72 body and the square bodys. I don't think it's such a big deal. Last one I tackled was for my son-in-law. Had a 72 longhorn frame, shortened it 6'' and converted to 4x at the same time. He took a rolling frame out of here just this past weekend. Custom front springs, partially set-up for a big block. He's going to finish the fabrication of the front x-member and the trans x-member once he gets the drivetrain installed. 454, turbo 400, 241.
Old 04-24-2018, 12:27 AM   #12
kwmech
Re: 4wd conversion?
couple more
Old 04-24-2018, 12:34 AM   #13
kwmech
Re: 4wd conversion?
Lost a file in the computer somewhere with the springs installed. Only going to need about a 2'' block in the rear to level it out. I'll look for the other picture file tomorrow.
Old 04-24-2018, 12:45 AM   #14
kwmech
Re: 4wd conversion?
Found the pics of the steering box reinforcement
Old 04-24-2018, 07:08 AM   #15
NastyBuzzard
Re: 4wd conversion?
I wouldn't say its too much of a hassle. Ours is almost a completely bolt on affair. Uses almost all factory 2wd holes. Minimal drilling to be honest. We tried to make it so almost anyone who can operate a drill and tape measure can do it.
Here are a few pictures. One showing the dually before and then after.
We are even working on a trans xmember for the swap as well as a new front xmember to allow factory sway bar to be mounted up, or even an aftermarket one if someone is running xover.
Old 04-26-2018, 01:14 PM   #16
erichevy
erichevy's Avatar
Re: 4wd conversion?
Cool kit! I have considered converting my 79 C35 SRW to a 4X4. A kit sure would make it easier I would think.
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 04-26-2018, 01:25 PM   #17
NastyBuzzard
Re: 4wd conversion?
Yeah I can tell you first hand it definitely makes it easier. I designed it just bc how much of a pain it is to do it using factory parts or donor parts from a factory 4wd. I still say frame swap is easiest if you can find a frame but they are hard to come by around me.
We designed it to use as many factory holes as possible so minimal drilling. We even made some youtube videos going through stripping off the 2wd hangers and such and installing our kit. We tried to make it so everyone could do it and not just people who have a lot of fabrication skills.
4wd conversion
