Old 04-03-2018, 10:39 AM   #551
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What did you do to your truck today part IV
Originally Posted by 1hihum View Post
please let us know how it goes and how well they work! I am interested in trying these.
I installed them on my 64 before paint and they work like butter, the doors close so easy I have to be careful not to slam them.
Old 04-03-2018, 11:31 AM   #552
Indian113
Indian113's Avatar
Now that Spring is close, I hope! I ordered a 63 and 64 Shop Manual so I can have a visual back up. Time to bust butt and get the 64 street ready again.
Indian113 is offline   Reply With Quote
Old 04-09-2018, 12:10 AM   #553
allchevy58
allchevy58's Avatar
My wife has been working on the paint, I installed the hitch, brake controller, trailer plug, LED taillights and cut a piece of diamond plate for the rear license plate.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 04-09-2018, 07:32 AM   #554
Old 04-10-2018, 01:54 AM   #555
studeclunker
studeclunker's Avatar
Love that green truck!
We have a new Old Man on our ranch. The boss added a '58 One-Ton flatbed. Top speed, fifty going down hill with a stiff tailwind. I wonder how difficult it would be to put a V8 in this thing?
studeclunker is offline   Reply With Quote
Old 04-10-2018, 10:20 PM   #556
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Originally Posted by jbgroby View Post
Mat, what bracket did you use to mate of the P/S pump. I added one to mine and was able to find an original V-6 bracket, yours looks different from the photo angle.
original bracket, from a 65 I bought a parts truck just for that pump.and pulleys
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 04-11-2018, 07:47 AM   #557
jbgroby
jbgroby's Avatar
Thank You Mat, they must have changed the design.
jbgroby is offline   Reply With Quote
Old 04-16-2018, 08:29 AM   #558
highwinger
highwinger's Avatar
I got my speedometer working! The set screw came out in the elec/mech converter box that grabs the inner cable. I'm really enjoying the simplicity of this model ('63). I watched a youtube on removing the cluster on a 64 and it seems a lot more complicated since all the switches mount thru the cluster.
I also got my retro radio system installed with exception to the antenna. I couldn't find the cable hole into the cable and the antenna wouldn't fit anyway. Guess what I have to order today?
My 'ol frame is a little sore from a couple days of truck yoga
highwinger is offline   Reply With Quote
Old 04-16-2018, 08:40 AM   #559
jbgroby
jbgroby's Avatar
I finally hooked up my speedo last week as well, I still need an adaptor because the speedo is off by 12-13 mpg (truck shows slower than real speed). I have to do the tire/pumpkin calculation and order one. I had to get the truck lifted up so I could connect the cable. No way to bend my arm the way it needed while the truck was on the ground, without breaking something .
Old 04-16-2018, 11:13 AM   #560
rvrfoot
Getting some welding done.Name:  DSCN1093.jpg
rvrfoot is offline   Reply With Quote
Old 04-16-2018, 11:39 AM   #561
forestb
forestb's Avatar
I installed my speaker boxes/cups on Saturday and ran all the cable to behind the seat. Next step is getting the interior done
forestb is offline   Reply With Quote
Old 04-18-2018, 11:02 PM   #562
hevymetl
Got the power steering pump and all pulleys and belts installed for my power steering conversion. It seems that the pump pulley is slightly out of alignment though. Do you guys think this will be a problem? Not sure exactly how to get it perfect.
hevymetl is offline   Reply With Quote
Old 04-19-2018, 11:37 AM   #563
forestb
forestb's Avatar
Yes I think it will be a problem. At best it will cause the belt to wear out fast at worst it will throw the belt. I don't know how your pump bracket bolts on but you might be able to add spacers between the pump and the bracket or you can put a spacer between the alternator bracket and the block but then you will have to get a spacer to push out the pulley on the water pump.
Old 04-19-2018, 12:25 PM   #564
pdxhall
pdxhall's Avatar
I made a bracket for my fuse box and my fan temp controller and got them mounted. I'm ready for the fun to begin
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-19-2018, 02:26 PM   #565
hevymetl
I was thinking it was as well. Weird because everything else lines up mint. The top bracket that bolts to block is pretty substantial, not sure how I can tweak that enough to get it where it needs to be. I do have another “adjustment” bracket that has more of an offset on it. Gonna try that first. Thx for the input.
Old 04-20-2018, 12:13 AM   #566
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 64 rust View Post
Got the engine and transmission pulled and old xmember dropped out, not enough time to put the new xmember in though...also tried my hand in the fauxtina paint job(all rattle can). Started with cream or black depending on where I was on the truck, then red oxy primer, then the color and wet sanded off to my liking. The body on my truck was far from perfect and my pockets aren't deep, $51.00 in paint and sanding blocks is what I have in it. Only got the doors and one fender sanded so far. Hopefully will get the rest sanded and paint logos on this week.
Keep it very subtle like you have it.
The ones where they sand out too many random spots just doesn't look right.
Some knock fauxtina, but I like the practicality of it.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-20-2018, 12:24 AM   #567
TJ's Chevy
TJ's Chevy's Avatar
Seat cover that I had for about 2 years on my 64 GMC was torn up beyond use from daily driving. New one showed up today and I am quite happy with it.
Old 04-20-2018, 09:37 AM   #568
Macdaddy1
Heavymetl
I had to add Shims (washers) to my power steering bracket to get it to line perfectly. The guys at the parts store said that was very common when you modify things.
Macdaddy1 is offline   Reply With Quote
Old 04-20-2018, 09:38 AM   #569
Macdaddy1
pdxhall
Way cool brackets. Would you be interested in making and selling a fuse box bracket? PM me if you are.
Old 04-20-2018, 01:29 PM   #570
The Rocknrod
Moderator
Originally Posted by macdaddy1 View Post
pdxhall
way cool brackets. Would you be interested in making and selling a fuse box bracket? Pm me if you are.
+1
Old 04-20-2018, 05:01 PM   #571
The Rocknrod
Moderator
Okay I made the clips for my radio delete plate.
Old 04-20-2018, 09:24 PM   #572
rvrfoot
And you did that this weekend.
Old 04-20-2018, 09:26 PM   #573
hevymetl
Originally Posted by Macdaddy1 View Post
Heavymetl
Thank you Mac. I will be trying that in the very near future. Today I got the old steering box out, and new one drilled and mounted. Big shoutout to Capnfab for making an amazing bracket. Thing is perfectly precise in alignment with power steering box and template worked flawlessly.
Old 04-20-2018, 10:00 PM   #574
The Rocknrod
Moderator
No today in about an hour in my little shop, burned my hand.
Old 04-21-2018, 01:08 PM   #575
CRGRS 66
CRGRS 66's Avatar
Originally Posted by vin63 View Post
The last couple of horn parts came in from Ididit last night, so I finally got to install my reduced diameter deluxe steering wheel for the last time.
Hey Vin, do you have any detail on how you went about reducing your steering wheel diameter?
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
