I have a 1972 K10 long bed, the tail light and L&R signal were working well except for the left front signal light that it was connected to ground, why? I don't know, I bought like that, I already disconnected the positive signal wire from the ground but still not working (any help too will be appreciated).
Now, I installed this aftermarket LED tail lights and the L&R signal light are not working so I got this LED flasher that connects to ground, but still not working if I do the signal sequence manually from the column stick it works. I'm about to rewire the whole truck but it's my daily driver truck, any help on this too it will be appreciated. ![]() Thanks in advance. |
![]() Join Date: Mar 2010
Re: 72 K10 Signal Lights stopped working after LED conversion
Someone smarter than me will probably chime in but i believe if you still have the stock flasher installed the LED lights do not draw enough power to make the stock flasher work. Again someone smart will join in. Check out other posts as well. It looks like you are relatively new to the forum as well. Try a search for LED conversion. I have read about it on the forum before.
1969 Chevy K20 Longbed |
yes...you need a flasher for the leds
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
Who Changed This?
![]() Join Date: Jan 2013
Not trying to be a wise guy- you changed the turn signal flasher, right, not the one for the emergency flashers? Ask me how I thought of that.
Yeah, just the turn signal flasher, I'll get the one for the emergency lights too and I'll update the results.
Thanks Guys... |
