Old 04-30-2018, 12:08 AM   #176
Hollow65
Hollow65's Avatar
Re: Big Block Build is what I'm calling mine. New pics inside
What’s the lsa of the cam?
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 04-30-2018, 11:56 PM   #177
Captainfab
60-66 Nut
Going by the lift and duration given, I am assuming the cam is the Comp 268H which has a LSA of 110*.
http://www.compcams.com/Company/CC/c...x?csid=73&sb=0
Old 05-01-2018, 12:33 PM   #178
Chevy Fleetside
Chevy Fleetside's Avatar
It is. I probably won't be on much. I crashed on my moto and broke my right collar bone. I wont' be working on anything for a while.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-02-2018, 01:01 AM   #179
Captainfab
60-66 Nut
Sorry to hear that. I hope you get healed up soon.
Old 05-02-2018, 09:17 AM   #180
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey buddy .... I hope you heal up soon.
I haven't been on here in a long time, I saw this notification and figured I would comment.
How is your son doing ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-05-2018, 12:55 AM   #181
Chevy Fleetside
thanks guys. Just know it hurts type this.haha.
Luca is doing well. He has been playing baseball. He recently pulled a muscle in his back and has not been able to play for a few weeks but will be back at it on Monday. He is as tall as me now so I am hoping he has more growing to do. Ouch .... I'm done. Going in to get a steel plate put on my collar bone Tuesday. Yeah looking forward to it..
Old 10-27-2019, 11:31 AM   #182
1BAD65
Chevy Fleetside
Great build brother, I hope you healed up well and were able to finish the truck.
Your build thread was very motivating to finally get back to work and finish my 65.
Hope to hear from you soon bro.
-David
Fresno/Madera
1BAD65 is offline   Reply With Quote
Old 01-10-2026, 05:35 PM   #183
1919A4
Chevy Fleetside, I am working on a 64 with BBC also and have encountered some problems like I am guessing you have. Noticed what appears to be cut outs in the firewall, am I seeing that correctly? I had to cut two large pieces out for the cab to be able to sit on the frame without contacting the valve covers so I am going to just cut the whole firewall out and put in a custom one that should work better. I am also wondering about the front end of the engine and how much clearance you have between fan (if you are using a water pump driven fan) and the back of the radiator. I have a set of aluminum rectangular port heads and the engine is much larger dimensionally than one with the standard cast heads and this has created most of the problems. I will be able to use an aluminum radiator with attached electric fan but no flex fan. The radiator support (in my case) needs to stay in its original position in order for the inner fender wells to work, I saw a comment suggesting moving the entire assembly forward a little and redrilling mounting holes but that doesn't work if you want too use the inner fenders. Will try to attach a couple photos to better explain what i am trying to say in my next post. Good luck!
1919A4 is offline   Reply With Quote
