05-21-2018, 10:01 AM | #1 |
Temp gauge reads too high - hack/fix?
My temp gauge reads about 20F higher than actual, and it's at the intake. If it were in the head it'd be more like 40F.
When the thermostat opens at 180, the gauge reads 210. I'd like to fix that, but the way they work is they read a higher number with more resistance, so I can't add inline resistance, as that'd make it read higher! I can't think of a way to remove resistance. It's well grounded, that's a grounded as it's going to get! Anyone know or think of a way to make a gauge read a little lower?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-21-2018, 10:38 AM | #2 |
Re: Temp gauge reads too high - hack/fix?
The problem with adding resistance is you will only get the guage to read correct at one temperature and the error above and below that temperature will grow larger the farther the water temperaure gets from the point you corrected it to. I have a great write up on this but it is a PDF and I can't post it as it is too large. The basic idea is correct senders are hard to find. But here is the link to the page. Fortunately I got my copy before the photo sharing greed event occurred which is lucky for me but no so for everyone else. Unfortunately at this point not all of the information is present, but enough of the information is there to maybe help you.
https://www.corvetteforum.com/forums...t-problem.html
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-21-2018, 10:57 AM | #3 |
Is the sender and temp guage original or aftermarket? original gauges only read C to H.
I'm assuming you are checking with a IR gun? if original the replacement sender is NAPA TS6469, replace it and see if that solves the issue. if aftermarket google name brand for replacement sending unit. RRM.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
05-21-2018, 11:01 AM | #4 |
Just like a gas gauge, you know what the temp is (or how much fuel). Just do the math when looking at it.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
