Old 06-25-2018, 11:13 PM   #451
ls1nova71
ls1nova71's Avatar
Re: 67-72 Electric speedo
Originally Posted by lutronjim View Post
What is the XF21
It looks like a standard Tamiya model paint, generally used for air brushing.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-26-2018, 10:45 PM   #452
Caustik
Caustik's Avatar
That, I just grabbed a bunch of colors while at a hobby shop, and this seemed the closest. I wish I would have bought an air brush though.
Caustik is offline   Reply With Quote
Old 07-11-2018, 10:28 PM   #453
lutronjim
bump
lutronjim is offline   Reply With Quote
Old 07-24-2018, 06:09 AM   #454
Bay67C10
Are these kits still available? If so I’ll take a stencil and a back cover template. Thanks
Bay67C10 is offline   Reply With Quote
Old 07-24-2018, 08:53 PM   #455
Hidesertchevy
I'll take a set also
Hidesertchevy is offline   Reply With Quote
Old 07-25-2018, 11:05 AM   #456
ls1nova71
ls1nova71's Avatar
PM's sent
Old 08-03-2018, 01:48 AM   #457
Bay67C10
Got mine already. Great stuff. Super fast shipping
Old 08-14-2018, 03:44 PM   #458
michael bustamante
michael bustamante's Avatar
For anyone thinking about doing this, I thought I would update the pics a little bit. These are the pics of the finished cluster, the backside showing it all hard wired with no printed circut, and you can also see the plugs I put on it so I can unplug the whole cluster to remove it. The last pics are of the back tin where the speedo mounts. This is on the one I am currently working on and I changed how it's mounted, works out better this way.
so. question for ya. this threads super long now so i'm its been asked before but what would you charge a guy to do this to his cluster if he sends it to you minus the cluster cover face?
ive got a 67 tach cluster and am doing an ls swap and your quality looks way better than what I could do im sure
1967custom
michael bustamante is offline   Reply With Quote
Old 08-15-2018, 12:00 AM   #459
ls1nova71
ls1nova71's Avatar
Well, you're right, it has been asked before and the answer is always the same, I cant do it. The problem is it's only really a cost effective way to go if you do it yourself. It is a bit labor intensive, so by the time I charged you to do it, you would be able to just go out and buy a new set of gauges. If I wasn't super busy all the time I would maybe consider doing a few, but really just don't have the time. Sorry.
Old 08-19-2018, 10:08 PM   #460
dec010974
dec010974's Avatar
trickey, trickey, trickey. this not fun.
dec010974 is offline   Reply With Quote
Old 08-21-2018, 10:24 PM   #461
ls1nova71
ls1nova71's Avatar
No, that's not it. It goes more like.....It's Tricky to rock a rhyme, to rock a rhyme that's right on time
It's Tricky, it's Tricky (Tricky) Tricky (Tricky)
It's tricky, tricky (Tricky) tricky
But seriously, what is your issue?
Old 08-22-2018, 07:10 PM   #462
dec010974
dec010974's Avatar
ill provide pics when i can. Excuse my car, tech part talk. its bad. i am trying to swap gauge parts, the motorized part, that actually function and moves the needles to the numbers on face plate. They are hard to remove. did you use any special tools? what is the procedure? How do i get the needle centered back correctly, so that gauge reads perfect? also, where can i find decals or face plates. i saw where your battery or volt meter display was numbered? if you can help me out. thanks in advance, Clark.
Old 08-29-2018, 10:02 AM   #463
diegos72
I am having issues rubbing the numbers of the plastic face using Mothers mag cleaner. Any tips on how to rub those off?
diegos72 is offline   Reply With Quote
Old 08-29-2018, 10:36 AM   #464
gringoloco
A guy with a truck
gringoloco's Avatar
Use a more aggressive compound, then polish it out with mothers. The blue magic or whatever worked for me. Barkeeper’s Friend works magic, too
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 08-29-2018, 11:08 AM   #465
ls1nova71
ls1nova71's Avatar
I didn't use any special tools to remove the needles, just pull them off with your fingers. What needles are you trying to remove? The '96 S10 needles are not hard to remove at all. To get the needle back on in the right spot, you need to power the speedo up which will move the stepper motor to what would be 0mph, then put the needle on in that spot, otherwise the needle will be off unless you just get lucky and happen to get it on in the right spot.
As for the voltmeter overlay with the numbered face that looks like what a 67-72 would have had if they had voltmeters, I pretty much gave that to Tom, Tbone1964. http://67-72chevytrucks.com/vboard/s...=653967&page=3 He sells the whole kit to install it, or you can just get a gauge out of a square body from like '78-87 or so and use the face that comes on it, but to me looks out of place.
Old 08-29-2018, 11:10 AM   #466
ls1nova71
ls1nova71's Avatar
I would just try rubbing harder, with a finger tip in a towel and the Mothers on it. Rub in one spot until it comes off, it eventually will.
Old 08-29-2018, 11:17 AM   #467
gringoloco
A guy with a truck
gringoloco's Avatar
-Chris
Old 08-29-2018, 09:50 PM   #468
diegos72
10-4 will keep on rubbing.
Old 10-12-2018, 07:40 PM   #469
cebra
Where are folks buying their 5/8” wired bulb sockets? I bought the ones referenced here (T3.25 from Super Bright LEDs) and they were 1/2”. I have since bought 3 other sets over the course of a month and 1 set of 5 fit but the guy doesn’t have anymore. I still need 4 and have searched to the wnd of the internet I feel. Thanks for any info.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 10-12-2018, 10:30 PM   #470
lutronjim
I bought these. They pop in but are pretty tight on the holes that have tabs for tubes - like turn signals.
http://www.classicpartsusa.com/produ...xoCzQgQAvD_BwE
Old 10-16-2018, 12:28 PM   #471
cebra
The guy I bought my set that fit from has more available now. They are 2 wire which I preferred. The only "modification" needed is that they are loose as the space between the tabs and the round part of the housing is too far apart. I bought a pack of rubber water hose seals for $2 at Tractor Supply that fit perfectly to keep the tabs snug against the underside of the housing. Good guy to work with and he notified me as soon as he got more in:
https://www.ebay.com/itm/5-T10-Twist...784e:rk:1:pf:0
Old 10-23-2018, 07:33 AM   #472
68lsc10
Pm sent about purchasing the printed gauge face stuff to do the mod.
68lsc10 is offline   Reply With Quote
Old 10-25-2018, 02:14 PM   #473
68lsc10
Payment sent to ls1nova71
Old 11-29-2018, 11:48 PM   #474
69c10phil
How do I get the kit
69c10phil is offline   Reply With Quote
Old 11-30-2018, 06:26 PM   #475
ls1nova71
ls1nova71's Avatar
PM sent
