Old 07-19-2018, 10:56 PM   #1
rwade
rwade's Avatar
22” Alcoa’s on a 3/4 ton rear end?
Has anyone used a 3/4 ton single wheel rear end and used the 8 to 10 lug adapters to run 22” or 24” Alcoa wheels on? Or do I need to continue looking for a 1 ton dually rear end?
Thanks, Wade
rwade is offline   Reply With Quote
Old 07-24-2018, 07:35 AM   #2
travlinman
Re: 22” Alcoa’s on a 3/4 ton rear end?
Thats what im using 3/4 ton rear, 8-10 lug adapters with 22" semis. I swapped out my 1-ton rear for a 3/4 suburban rearend. The sub rear is narrower so i can use the factory dually rear fenders and the semi wheels will tuck
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 07-24-2018, 08:59 AM   #3
jjzepplin
jjzepplin's Avatar
Pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-24-2018, 03:42 PM   #4
redsroundeyes
Exactly what i am running.
redsroundeyes is offline   Reply With Quote
Old 07-24-2018, 04:01 PM   #5
cochino12
It followed me home?
cochino12's Avatar
Why not a single 1 ton srw axle? Wouldnt that be easier than having to move spring perch's and shock mounts?
^^ Killer truck!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-24-2018, 04:17 PM   #6
rwade
rwade's Avatar
Awesome truck!👍🏻
Wade
Old 07-24-2018, 04:19 PM   #7
rwade
rwade's Avatar
Did you have to change the wheel studs to be long enough for the adapters?
Wade
Old 07-24-2018, 05:11 PM   #8
redsroundeyes
I replaced because i was there.
Old 07-24-2018, 05:13 PM   #9
redsroundeyes
Yes, that works also. I have done 3.
Old 07-25-2018, 10:03 AM   #10
SCOTI
SCOTI's Avatar
This truck looks familiar.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
